Do physical (macroscopic) waves consist of matter?
In summary, sound is a form of wave that propagates through a medium and does not involve the emission of matter. It is the oscillation of particles around an equilibrium position, and can be either electromagnetic or mechanical in nature.
Vitani1
51
TL;DR Summary
When I think of a wave propagating through space I think of a geometric wave-like structure propagating through the matter in the surrounding environment. If someone yells and you hear their voice is it actual matter that is emitted and that your ears pick up on? If this were the case there would be a lot of "clutter" in your ears from all the noise... what is the answer?
Thanks
  • Skeptical
Likes PeroK
Try googling for "what is sound".
Likes Vitani1
Vitani1 said:
Summary:: ]
Thanks
Waves are oscillations of something. They may be the oscillation in position of air molecules in the longitudinal direction as sound propagates from the source to the receiver (the waves propagate, but the air molecules stay mostly in place), or they can be the transverse oscillation of water molecules as gravity waves propagate across the ocean or a lake. Or they can also be electromagnetic in nature, which does not require a medium at all.
You can start with the Wikipedia article: https://en.wikipedia.org/wiki/Wave
The particles (of water or air or string/rope molecules, etc.) that oscillate tend to oscillate around an equilibrium position. That is why the air molecules don't move from your mouth to the ear of your listener. When you speak, that "bangs" the air molecules outside your mouth together, and that bangs molecules together a little farther away from your mouth, and so on, all the way to the air molecules outside and inside the listener's ear canal.
Likes Vitani1
We all have heard about photons, which are totally massless 'particles' that are associated with electromagnetic waves. There are less well known particles that are called Phonons and they are associated with mechanical vibrations (sound) in materials. They travel but are not regarded as having mass; the air / water / metal doesn't go anywhere when sound travels through.
Likes Vitani1
You already have got good answers above, but I want to comment too:
No matter is emitted that travels from source and outwards.
If that was the case we could lose weight (mass) by simply talking. :)
And loudspeakers would also lose mass over time if matter was emitted. :)
What is propagating is sound, and sound is differences in air pressure/density which can be modeled as waves.
Likes Vitani1 and davenn
Thank you.
Likes berkeman
Related to Do physical (macroscopic) waves consist of matter?
1. Do physical waves consist of matter?
Yes, physical waves do consist of matter. Waves are disturbances that travel through a medium, which can be a solid, liquid, or gas. The matter within the medium is what allows the wave to propagate.
2. How do physical waves transfer energy?
Physical waves transfer energy by causing the particles within the medium to vibrate. As the wave travels through the medium, it transfers this energy from one particle to the next, creating a ripple effect.
3. Are all physical waves visible to the human eye?
No, not all physical waves are visible to the human eye. Some waves, such as sound waves and radio waves, are invisible to the naked eye. However, they can still be detected and measured using specialized equipment.
4. Can physical waves travel through a vacuum?
No, physical waves cannot travel through a vacuum. A vacuum is a space devoid of matter, so there is no medium for the wave to propagate through. This is why sound cannot travel through outer space.
5. How do physical waves differ from electromagnetic waves?
Physical waves require a medium to travel through, while electromagnetic waves do not. Electromagnetic waves can travel through a vacuum because they are made up of oscillating electric and magnetic fields, rather than matter. Additionally, electromagnetic waves can have a wider range of frequencies, while physical waves are limited to the properties of the medium they are traveling through.
  • Quantum Interpretations and Foundations
  • Astronomy and Astrophysics
  • Other Physics Topics
