Do scientists think black holes have singularities
In summary, scientists think black holes have singularities and event horizons, but they are not anything more than a dark massive body.
wolram
Dearly Missed
4,446
558
Do scientists think black holes have singularities and event horizons or
think they are as described, why think they are nothing more than a dark
massive body?
Astronomy news on Phys.org
they were predicted mathematically
And there is not a chance the prediction was wrong?
seeing as black holes have been observed, i doubt it is wrong.
Do you have a reference?
massive body?
We would need to identify some mechanism that can counteract the collapse of all that matter/mass/gravitational force. Under Relativity, there is none...hence the singularity.
But I think one application of string theory has an alternate model that does not include a singularity (check out topics on information retrieval from a black hole).
IIRC, a few years ago there were also discussions about a "gravastar" model of the black hole which did not include singularities (some kind of exotic space instead).
But the current model has the best support so far.
http://hubblesite.org/newscenter/newsdesk/archive/releases/1995/47/
How did they mathematically discover black holes? Is it explainable in a post or should i go find a book...
it is a prediction of GR. i don't specifically know how they did it, though.
This is a nice enhanced photo Russ.
massive body?
The theory of general relativity is what predicts that massive enough bodies will have event horizons and singularities. It is expected that quantum gravity will replace singularities with something else, but since the singularities are "hidden" behind the horizon, this doesn't make a great deal of difference - we are not expecting to be able to observe naked singularities.
As to why we believe GR is the right theory of gravity a short and very partial recap goes something like:
The observed magnitude of bending of light by the gravity of the sun and other objects (gravitational lensing).
The recession of the oribit of mercury
Radar time delay meausrements of venus (the Shapiro effect).
Observations of the rate of slowing of binary pulsars. This last result is one of the few results in the "strong field" regime, so it's especially important for black holes.
Soon, we will have results from gravity probe B, which will confirm (or deny) the frame-dragging predictions of GR (the Lense-Thirring effect).
soon? we still have a few years for GPB to give results
It seems LIGO is quite negative.
I think black holes are obvious phenomenons. If you think 'escape velocity' then it seems much more realistic than simply stating 'black holes', as though it is some mysterious object. However the point of convergence or 'singularity' in a BH is quite speculative. They say that can lead to another Universe etc etc...
Not discover, predict. Its kinda a two-part prediction:
-First, if you get enough force (pressure) due to gravity and, say, the collapse of a dying star, it was calculated that the pressure developed was greater than the structural integrity of a neutron, causing the neutron to collapse. I'm a little fuzzy on how this leads to a singularity, and I know there is still some debate over whether the result of the collapse is a singularity or just a lump of dense matter of an unknown form. Regardless, that leads to the second part:
-If there is enough mass in a small enough volume, the excape velocity of the object will be greater than C. With an escape velocity greater than C, not even light can escape. Hence: black hole.
Now, the usual question: if light can't escape, how can we find them? Well, further calculations revealed that matter falling into a black hole would accelerate, get hot, and start emitting electromagnetic energy (light) before it passed that point of no return (the event horizon). The calculated frequency of the em radiation was in the range of X-rays. So the first black holes were found by looking for stars with invisible binary companions, sucking matter from them and emitting x-rays as that matter disappears into oblivion.
This has been discussed before - LIGO's results (non-results) are consistent with GR.
What does binary mean
Binary star system - two stars orbiting each other.
Initially, Subramanian Shandrashakar calculated that a star of 3.2 Solar masses would not be able to halt its own gravitational collapse at the neutron star stage. His predictions, however, were based upon a static black hole. Karl Schwartzchild later refined the formulae to work for rotating holes. Even further refinements dealt with electrically charged holes. Hawking then got into it with the 'evaporation' prediction. Newer theories are continuing to investigate and speculate. One initial prediction, in Schartzchild's time, was that if a hole had too much spin or charge, the event horizon would split at the equator and allow something to navigate through the hole without hitting the singularity. (Don't get excited about space-travel through one, though; the tidal forces would still rip the matter into subatomic particles.)
Related to Do scientists think black holes have singularities
1. What is a singularity in regards to black holes?
A singularity is a point of infinite density and zero volume at the center of a black hole. It is where the laws of physics, as we know them, break down.
2. Do all scientists agree that black holes have singularities?
While the majority of scientists believe that black holes have singularities, there is still ongoing debate and research about the existence and nature of singularities within black holes.
3. How do we know that black holes have singularities if we cannot observe them directly?
The existence of black hole singularities is based on mathematical equations and theories, such as Einstein's theory of general relativity. While we cannot directly observe singularities, the effects of black holes on surrounding matter and light support the idea of singularities at their centers.
4. Are there any alternative theories to the singularity concept in black holes?
Some scientists have proposed alternative theories, such as the "fuzzball" theory, which suggests that black holes are actually made up of a dense, tangled web of strings rather than a singularity. However, these alternative theories are still being studied and debated.
5. What implications do singularities in black holes have on our understanding of the universe?
The existence of singularities in black holes raises questions about the laws of physics and our current understanding of the universe. It also has implications for theories such as the Big Bang and the nature of space and time. Further research and study into black hole singularities can help us gain a deeper understanding of the universe we live in.
