Do slits absorb photons at the edges?
  • I
  • Thread starter Swamp Thing
  • Tags
    Photons
In summary, Xiao et al discuss the interaction between spatial masks and Gaussian beams, which can be described as a unitary transformation of quantum states. However, the issue of lossiness in spatial masks, such as an iris, needs to be addressed. The conversation also touches upon the concept of reflective screens absorbing photons, which may affect the output.
Swamp Thing
Insights Author
920
621
Xiao et al say the following here: https://arxiv.org/pdf/1703.03818.pdf
When a spatial mask such as an iris is applied to the Gaussian beam, the quantum states of different modes
will interact. The interaction can be described as a transformation of annihilation or creation operators of input
modes into operators of output modes. This transforma-tion should be unitary, which preserves the commutation relations of the annihilation or creation operators. However, one problem needs to be solved. Generally, spatial masks (or other optical devices) are lossy. For example, an iris will absorb part of the input signal at the rim.
Is this correct? I'm finding it hard to believe that there is a probability that some irreversible events will occur that would ultimately result in heating up the mask (screen with slits). I mean, we could always make the screen out of highly reflective material that would either reflect most photons back towards the source, or let some pass with a small amplitude of detection on the other side.
But a reflective screen actually absorbing photons? With the absorption events clustured near the edges?
There is no such thing as a perfectly reflecting material. Some of the photons will ultimately be absorbed. In any case, I'm not sure why this would matter here: reflected photons will also affect uoutput.
Related to Do slits absorb photons at the edges?
1. Do slits absorb photons at the edges?
Yes, slits do absorb photons at the edges. When photons pass through a slit, they interact with the edges of the slit which causes them to either be absorbed, transmitted, or scattered.
2. How does the absorption of photons at the edges of a slit affect the resulting diffraction pattern?
The absorption of photons at the edges of a slit can decrease the intensity of the resulting diffraction pattern. This is because some of the photons that would have contributed to the pattern are absorbed by the edges of the slit instead of passing through and contributing to the diffraction pattern.
3. Do wider or narrower slits absorb more photons at the edges?
Narrower slits tend to absorb more photons at the edges compared to wider slits. This is because narrower slits have a higher surface area to volume ratio, making them more likely to interact with the passing photons.
4. Is there a way to reduce the absorption of photons at the edges of a slit?
One way to reduce the absorption of photons at the edges of a slit is by using anti-reflective coatings on the edges. These coatings can help minimize the amount of light that is absorbed and increase the transmission of photons through the slit.
5. Can the absorption of photons at the edges of a slit be used for any practical applications?
Yes, the absorption of photons at the edges of a slit can be utilized in various applications such as photovoltaic cells and solar panels. By controlling the absorption of photons at the edges, the efficiency of these devices can be improved.
12K
