Do Spin-Orbit Interactions change the Orbital of an Electron
In summary, the orbital of an electron does not change when it experiences a spin-orbit interaction, but the presence of the spin-orbit term causes the quantum numbers ##m_l## and ##m_s## to no longer be good quantum numbers. Instead, the total operator ##J_z = L_z + S_z## must be used, with the eigenstate being specified by ##m_j## and its magnitude ##j##. This new eigenstate is a linear combination of spherical harmonics and spin vectors. The radial part is also affected, with a scaling towards the nucleus due to relativistic effects.
Ryan Reed
51
Does the orbital of an electron change when it experiences a spin-orbit interaction, and if so, how?
The principal quantum number doesn't change. but any change in the energy level changes the wavefunction, thus slightly alters the spatial distribution of the electron.
The presence of spin-orbit term which is proportional to ##\mathbf{L}\cdot \mathbf{S}## makes the quantum number ##m_l## and ##m_s## no longer good quantum numbers because ##L_z## and ##S_z## do not commute with ##\mathbf{L}\cdot \mathbf{S}##. Instead, it's the total operator ##J_z = L_z + S_z## that commutes with the spin-orbit term. Therefore, the eigenstate of the Hamiltonian must be specified, among others, by ##m_j## associated with the operator ##J_z##. Actually a more complete picture of the effect of spin-orbit coupling is provided by Dirac equation, where the eigenstate has the form of a 4 element column vector, the first two being called "large component" and the last two "small component". But for perturbative effect, such as in low Z hydrogen like ions, the large component dominates the eigenstate and thus we can regard this as the "true eigenstate". As stated before, one of quantum numbers used to specify the state is now ##m_j##, along with its vector's magnitude ##j##, so the spin-angular part of the eigenfunction looks ##\langle \theta,\phi |l,s,j,m_j \rangle## (as in the usual theory of angular momentum quantum numbers, ##m_j## runs from ##-j## to ##j## with unit increment). This new eigenstate ##\langle \theta,\phi |l,s,j,m_j \rangle## will be a linear combination of the product between spherical harmonics (eigenfunction of ##L^2## and ##L_z##) and spin vector (eigenfunction of ##S^2## and ##S_z##). For example for ##l=1##, ##s=1/2## (obviously for electron), ##j=3/2## and ##m_j=1/2##,
$$ \langle \theta,\phi |1,1/2,3/2,1/2 \rangle = \sqrt{2/3} Y_{10}(\theta,\phi ) \chi_+ + \sqrt{1/3} Y_{11}(\theta,\phi ) \chi_- $$
We see that as a consequence of taking the spin into account, we now have splitted probabilities to find the electron in either spin up or spin down and for our example it's more likely to find the electron in spin up state.
As for the radial part, the exact form of this function for hydrogen like ions looks very complicated despite can be found analytically. But for perturbative effect, the radial part looks just like the usual radial part without spin orbit effect but scaled down toward the nucleus. This shrinkage might be thought of the result of relativistic effect in increasing the mass of the electron.
Likes vanhees71 and e.bar.goum
Related to Do Spin-Orbit Interactions change the Orbital of an Electron
1. How do spin-orbit interactions affect the orbitals of electrons?
Spin-orbit interactions are a type of coupling between the spin and orbital motion of an electron. This means that the spin and orbital angular momenta are not conserved separately, but instead interact with each other. This interaction can cause a splitting of the energy levels of electrons, resulting in a change in the orbital of the electron.
2. Can the spin-orbit interaction change the energy of an electron's orbital?
Yes, the spin-orbit interaction can cause a splitting of the energy levels of electrons, resulting in a change in the energy of an electron's orbital. This is known as the spin-orbit coupling effect.
3. How does the strength of the spin-orbit interaction affect the change in orbital of an electron?
The strength of the spin-orbit interaction depends on the strength of the electric field at the location of the electron. The stronger the electric field, the stronger the spin-orbit interaction, and the greater the change in the electron's orbital. However, the strength of the spin-orbit interaction also depends on the properties of the electron, such as its spin and angular momentum.
4. Can spin-orbit interactions change the shape of an electron's orbital?
Yes, spin-orbit interactions can change the shape of an electron's orbital. The splitting of energy levels caused by the spin-orbit interaction can result in a change in the electron's orbital shape. This is known as the spin-orbit coupling effect.
5. How do spin-orbit interactions affect the behavior of electrons in atoms?
The behavior of electrons in atoms is greatly influenced by spin-orbit interactions. These interactions can cause a splitting of the energy levels of electrons, resulting in different energy states and orbital shapes. This can lead to changes in the chemical and physical properties of atoms and molecules, as well as affecting processes such as electron transitions and emission of light.
  • Quantum Physics
  • Quantum Physics
