Do the Bananas Move When the Monkey Climbs?
  • Thread starter moondawg
In summary, a 20kg monkey climbing a rope to reach a bunch of bananas attached to the other end will result in the bananas moving up as the monkey moves up, and the distance between the monkey and the bananas decreasing. This is due to the force exerted by the monkey's motion on both the monkey and the bananas, causing them to move in the same direction. However, if the monkey is simply hanging on the rope, there will be no change in the position of the bananas.
moondawg
46
A 20kg monkey has a firm hold on a light rope that passes over a frictionless pulley and is attatched to a 20kg bunch of bananas. The monkey looks up, sees the bananas, and starts to climb the rope to get them. a.) As the monkey climbs, do the bananas move up,down, or remain at rest? b.) As the monkey climbs, does the distancebetween the monkey and the bananas decrease, increase, or remain constant?
a.)I thought that the bananas would move up because if the monkey is in motion it will make the bananas overcome any force keeping it at rest.. but I'm not sure if that's correct?!
b.) I thought that the distance decreases because the monkey being in motion will apply a force to the bananas making them move up as the monkey moves up.
Idk if my logic is correct so please help!?
well, if monkey just hangs on the rope what forces acts on monkey and on bananas box? Does net force on banana box or on the monkey change when monkey climbs with constant velocity?
If monkey moves up with acceleration, acceleration requires a force, but force always comes in pair from interaction and in equal magnitude but different directions. here you have only monkey and bananas. So the force that makes monkey go up with acceleration, will also make bananas come up.
About distances i don't understand if it is meant to be distance along rope, or just distance between monkey and bananas (that is straight line). In first case distance decreases, but in second...
Related to Do the Bananas Move When the Monkey Climbs?
What is "The Monkey and Bananas Problem"?
The Monkey and Bananas Problem is a classic mathematical puzzle that involves a monkey trying to reach a bunch of bananas hanging from the ceiling using a set of given tools. It is often used as a problem-solving exercise in computer science and game theory.
What tools does the monkey have?
The monkey has a set of tools that can be used to reach the bananas, including a stick, a box, and a chair. The monkey can also use its own body to climb and jump.
What is the objective of the problem?
The objective of the problem is for the monkey to successfully reach the bananas using the given tools. The monkey must use its problem-solving skills to figure out the most efficient way to reach the bananas.
What are the main challenges of the problem?
The main challenges of the problem include determining the correct sequence of actions to reach the bananas, ensuring that the tools are used effectively, and avoiding any obstacles or traps that may hinder the monkey's progress.
What is the significance of "The Monkey and Bananas Problem" in science?
"The Monkey and Bananas Problem" is significant in science as it demonstrates the concept of problem-solving and decision-making using logical reasoning. It is also used to study animal behavior and cognitive abilities in primates.
13K
