Do theoretical physicists use significant figures?
In summary, colleagues and I often consider a lot of different factors when choosing which kind of uncertainty estimate to include in published papers. They prefer to choose a method that is widely known for well communicated simplicity, yet one that is close to and representative of the likely possibilities including lesser known, but often more appropriate techniques, as well as their consensus "gut feeling" about what the uncertainties really are.
Mikaelochi
40
I know the phrase ''theoretical physicist'' may be a general term, do they or ''mathematical physicists'' use significant figures? I know it's kind of a silly question, but it stems from what I learned in chemistry class. Our chemistry teacher talked about the importance of such things and I understood pretty well. But I plan to work in high energy theory in the future. So would I be using this concept frequently in my calculations or is it a useful thing to know but won't really use it? Thanks.
First, yes they do. They would look like idiots if they said "I predict the range of this parameter is between 1000001 and 4999999.
Second, the attitude of not wanting to learn something unless there is an immediate and obvious use is not one that successful physicists share. "When are we going to use this?" is very middle school.
Likes Evo, Dr. Courtney, gleem and 4 others
No, I just wanted to know when it was used. For example, Riemannian geometry has its usefulness in general relativity, which is seems quite interesting may I add. But I never heard of significant figures being at the forefront. Perhaps it's just the notation. Like would they typically use the plus or minus symbol to represent uncertainty or use the sig figs rules. Basically what's the conventional way that theoretical physicists represent uncertainty? That's what I'm trying to ask, if I didn't make it clear.
Instead of using these sig figs rules, is there a simpler way to represent the uncertainty? Maybe I could say this calculation has a 0.1% uncertainty or something like that.
By the way, it's not that I don't want to learn it, it's just that if I'm going to give an answer, the point is that it's accurate as possible. I would prefer to have good justification for rounding rather than base it off some assumption.
Indeed, in real scientific work, the "sig fig" rules are not used. The lowest level of uncertainty analysis ("error analysis") that is commonly used is described here:
https://en.wikipedia.org/wiki/Propagation_of_uncertainty
You can decide for yourself whether this is "simpler" than the "sig fig" rules. :-p
Even this approach is often not sufficient, because it makes assumptions about the probability distributions involved which are not always met in practice, especially with small data samples.
Likes CalcNerd
As someone in theoretical physics (not high energy but we use some of the same techniques), I can tell you than in my recent projects everything was done analytically. So it depends on the area. But some people may do simulations or compare work to experiments, so it depends on what you are trying to do.
Likes Mikaelochi
Often when you see a range for an estimated value, it is because there is some statistical analysis giving the answer. The results often come from a tremendous number of random events that are used to narrow down the estimate as more data comes in. So the range of values comes from probability and statistics. Speaking of that in terms of "significant figures" is somewhat misleading. You should look at statistics and confidence intervals if you are not already familiar with it.
Likes Mikaelochi
I was never a fan of significant figures, preferring to include an estimate of the uncertainty either as a percent (relative) or absolute, along with the assumptions or methods used to generate that estimate.
Colleagues and I often consider a lot of different factors when choosing which kind of uncertainty estimate to include in published papers. We prefer to choose a method that is widely known for well communicated simplicity, yet one that is close to and representative of the likely possibilities including lesser known, but often more appropriate techniques, as well as our consensus "gut feeling" about what the uncertainties really are.
In most fields, uncertainty analysis is as much an art as a science, since there are so many ways to estimate uncertainties based on different views of the data and assumptions. I am of a mind to believe if one computes an uncertainty five different ways, that the true uncertainty is likely bounded by the different approaches, but I'm never confident ascribing a confidence level to that. In spite of the popularity of p-values, I think they are silly to take too seriously, just one possible metric among many.
Likes Mikaelochi
Thank you very much for the responses. Very helpful!
Related to Do theoretical physicists use significant figures?
1. Do theoretical physicists use significant figures?
Yes, theoretical physicists use significant figures in their calculations and analyses. Significant figures are an important tool in expressing the precision and accuracy of a measurement or calculation.
2. Why do theoretical physicists use significant figures?
The use of significant figures allows theoretical physicists to communicate the level of uncertainty in their measurements and calculations. This is important in accurately representing the limitations of their work and ensuring the validity of their conclusions.
3. How do theoretical physicists determine the number of significant figures to use?
The number of significant figures used by theoretical physicists is based on the precision of the measurement or the accuracy of the calculation. Generally, the number of significant figures is equal to the number of digits that are known with certainty, plus one estimated digit.
4. Can theoretical physicists round off significant figures?
Yes, theoretical physicists can round off significant figures in their calculations. However, it is important to follow the rules of significant figures when rounding off, such as rounding to the nearest known digit and maintaining the number of significant figures.
5. Are significant figures important in all fields of physics?
Yes, significant figures are important in all fields of physics, including theoretical physics. They are used to communicate the precision and accuracy of measurements and calculations, which is essential in understanding and verifying scientific research and discoveries.
  • STEM Academic Advising
