- #36
twofish-quant
- 6,821
- 20
turbo-1 said:6dF turned up a void 3.5 billion light-years across, so there is currently evidence of large-scale structure at least that large, and there may be much larger structures that we can observe, given improvements in instrumentation, including better optics and greater detector sensitivity.
It's fairly unlikely. You can do angular correlations, and if you do that, you'll find that there is a huge dropoff in the power spectrum once you exceed a certain angle. One problem with doing distance correlations is that you don't know whether or not you are seeing a real correlation or some galaxy evolution or observational selection effect.
With voids framed by filaments and walls of galaxy clusters, the distribution of matter in space takes on a foamy appearance.
Which is pretty inconsistent with anything that has been suggested that is wildly different from the big bang. Foams aren't fractals. If the distribution of the galaxies were determined by something like plasma physics, you'd get a cascade at all scales in which you have something that looks nothing like a foam.
A challenge for modern cosmology could arise from the discovery of structures on larger and larger scales, because the formation of structure through gravitational accretion takes time, and the Big Bang theory contains a self-imposed limit on the time available in which structure can form.
Yes, but remember that all this was written in the 1970's. Things have progressed since then.
So people in the 1980's and 1990's were specifically looking for structures that could challenge the big bang. The stuff that they did find required some model tweaking, killed a few scenarios, but ended up not challenging the BB in a major way. Now it is true that you have to assume three "tooth fairies" to get everything to work (inflation, dark matter, and dark energy), but that's a lot better than any alternative theory. Once you assume these three tooth fairies, you get massively detailed predictions about how the galaxies are distributed, abundances of elements, and the characteristics of the cosmic microwave background. The fact that people outside the field aren't aware of this, is more a failing of science journalism than anything else.
The problem is that you just can't wave your hands and say "plasma physics" and get people to take you seriously, because we have enough data that you really have a huge job trying to explain how something really weird explains the data better than any of the theories that you have.
One big problem that you have if you start invoking plasma and magnetic fields is that what tends to happen when you have plasma and magnetic fields is that structures start breaking up. You get what is known as a Kormogarov cascade in which big eddies start breaking up and forming smaller eddies, and you end up with a hell of a time trouble to explain how you get big voids from that. If you take things that we know are due to plasma and magnetic fields (which you can do in the laboratory), you come up with a specific power spectrum that looks totally different from what we see in the galaxies.
