Do we need a screen to view a real image?
In summary, the conversation discusses the concept of real images and their visibility without the use of a screen. The speaker asks if a screen is necessary to view a real image, and explains their confusion about the location of the image when looking at a concave mirror. It is then explained that the image can be seen by looking at it from the right direction and that it is an optical illusion. The conversation also touches on the use of screens in optical instruments and provides an example of a real image without a screen. The conversation concludes by reiterating that all images we see are because of a real image formed on the retina.
hasankamal007
42
So, the question I ask is simple : " Is a screen necessary to view a real image?"
For example, when I view my image at the 'concave mirror' side of a spoon, a real image is visible. Now, according to my book the image location should be between Centre and Focus. So, is the image actually kinda floating in air before spoon. If that is the case, why can't I see this air-suspended image from somewhere else.
Can the images float like this in air? Or is it the air particles that become the screen in this case? Will this floating image be visible in a vacuum also?
Please explain as well.
Thanks a lot in advance.
You have to look at it from the right direction. Place your eye along the axis of the lens, on the image side, further away from the lens than the image location (maybe about 30 cm further away), and look towards the lens.
At first glance, the image looks like it's "inside" the lens, but if you move your head around so as to look at the image from slightly different directions, you should be able to convince yourself that the image is actually between the lens and your eye.
Hold a pencil or pen point between the lens and your eye, and move it back and forth. You should be able to put it in a location where the image appears to be "stuck" to it as you move your head from side to side.
Yes.
No.
Yes.
You don't need a screen to see a real image but (putting things the other way round) to see an image on a screen (project it), it has to be real. All this means is that the rays (in a ray construction) actually emanate from real locations in space. So the rays have to converge at that point - so they can then leave the point and reach your eye.
Plenty of optical instruments have real images formed inside them - like telescopes and microscopes - you then observe this real image with an eyepiece which then forms a virtual image at a convenient distance for viewing.
What you are talking about is an optical illusion. The image only seems to float in mid air. There is nothing at that location. The real image location is on your retina. That's why it is also called a virtual image.
You have it backwards. In this case the image is actually "floating" in mid air--it's no illusion. That's why it's called a real image--the light is really there.
Everything you see is because of a real image formed on your retina. Your eye lens forms that, whether the (outside) image you are looking at is real or virtual.
Related to Do we need a screen to view a real image?
1. Can we view a real image without a screen?
No, a screen is necessary to view a real image. Without a screen, the image would not be able to be displayed for our eyes to see.
2. Why do we need a screen to view a real image?
A screen is needed because it acts as a medium to display the image. Just like how a canvas is needed for a painting to be seen, a screen is needed for a real image to be viewed.
3. Is there a way to view a real image without a screen?
No, currently there is no way to view a real image without a screen. However, there are other methods of displaying images, such as using a projector onto a surface, but a screen is still needed in those cases.
4. Can we view a real image using a different type of screen?
Yes, we can view a real image using different types of screens, such as a computer monitor, a TV screen, or a phone screen. As long as the screen is able to display the image, it can be used to view the real image.
5. Do all screens display real images accurately?
No, not all screens display real images accurately. Factors such as resolution, color accuracy, and brightness can affect how the image appears on the screen. It is important to choose a high-quality and calibrated screen for accurate image viewing.
44K
15K
  • Other Physics Topics
