Do we see multiple images in mirror?
In summary, when looking in a mirror, you see your image but the light that reaches your eyes also reflects off your body back to the mirror again and back to your eyes. The amount of absorption of light from clothing far out weighs any reflection, so you don't see a reflective image. If you are in a room with a mirror and the walls are painted white, you may still see a single image on the mirror.
leonstavros
78
When we look at a mirror we see our image but the light that reaches our eyes also reflects off our bodies back to the mirror again and back to our eyes. Do we see multiple images of our self but somehow ignore all but the primary reflection?
Science news on Phys.org
I would say theoretical yes, but NO for 2 reasons:
1 . the amount of absorption of light from clothing far out weighs any reflection - clothing is just not shiny.
2. If a ray of light from the mirror does hit your eye and is reflected, the angle of incidence = angle of reflection so only a very tiny amount of light would be at an angle sufficient so that the ray would be reflected back to the mirror and then back to your pupil - ie the reflected image would be something in between the size of your pupil and your iris, and again very faint, if not, completely unnoticable. due to absortion again.
Clothing reflects light (which is why you can see it in the first place, assuming the clothing isn't acting as a black body), but you don't see a reflective image because the clothing scatters the light it reflects, destroying any potential image with an extreme blurring effect. If the clothing approximated a mirror, then you could see an image reflected off that clothing, either directly or if viewing an image from a mirror.
The extra light scattered off your clothing from your image in the mirror simply adds a tiny bit to the brightness of the image. It doesn't create a new image.
If you were to hang a mirror on your chest, and keep it parallel to the other mirror, then you would see an infinite regression of multiple images in the image of that mirror. I see something like this in a restaurant where I often eat, that has mirrors on walls facing each other, with my seat in between.
What if you're in a room with a mirror and the walls painted white and you're also clothed in white? would you still see a single image on the mirror? I would guess yes although there would be a whole bunch of reflections in the room.
Yes, if all the other walls are white, they would reflect the light, but only diffusely, so that they would not create additional images. The image of the wall in the mirror just looks bright, but you don't see an additional image in the wall.
I know I'm beating this thing to death but I keep thinking of scenarios such as sitting in the middle of the white room with the mirror in front of me thinking about all those variable phase reflections of the original image creating variable interference patterns as they add or subtract on my retina. What do you think?
No, you only get an interference pattern through a superposition of two or more coherent beams that are offset in some way. You don't get an interference pattern from a superposition of incoherent beams. All the random phase differences on average end up canceling out in non-coherent superpostions so that you get a sum of scalar sum of powers instead of a vector sum of fields. If you shine the beams from two different, isolated lasers at the same spot on the wall, you will not get an interference pattern. You have to lock the lasers together, or use one beam from one laser and split it into two beams that than interfere with each other (such as a Michelson interferometer).
The front of your eye is specularly reflective, so you may be able to see and image of yourself in your eyes in the mirror if you look really close, but it will just be a secondary image. There won't be interference fringes or anything.
FAQ: Do we see multiple images in mirror?
1. Why do we see multiple images in a mirror?
We see multiple images in a mirror because light reflects off of the surface of the mirror at different angles, creating multiple reflections of the same object.
2. How many images can we see in a mirror?
The number of images we see in a mirror depends on the number of reflecting surfaces. For a flat mirror, we will see one reflected image. However, for a concave or convex mirror, we can see multiple images depending on the curvature of the mirror.
3. Why do objects appear reversed in a mirror?
Objects appear reversed in a mirror because the light rays reflecting off of the object are flipped in the horizontal direction when they hit the mirror's surface. This creates a reversed image of the object in the mirror.
4. Can we see infinite images in a mirror?
No, we cannot see infinite images in a mirror. The number of images we see is limited by the number of reflecting surfaces and the angle at which the light reflects off of them. Eventually, the images will become too small and dim to be seen by the human eye.
5. Do all mirrors produce multiple images?
No, not all mirrors produce multiple images. Flat, smooth surfaces that reflect light at the same angle will only produce one image. However, mirrors with curved or irregular surfaces can produce multiple images due to the varying angles of reflection.
