Do you know a formula for the integral of a product of 4 spherical harmonics?
In summary, the conversation discusses the problem of computing integrals of products of three spherical harmonics in the context of atomic physics. The conversation mentions various methods, including using Cartesian coordinates and Clebsch-Gordan coefficients. It is recommended to use the Cartesian approach for its simplicity and the ability to check intermediate values. The conversation also mentions the possibility of using software or online tools to calculate the integrals.
andresordonez
68
Hi, this may seem like something I should ask in the math forums but, as I came into this problem in atomic physics I'm confident that this is a question more appropriate here than in the math forums.
So far I've been only able to find the common integral of a product of three spherical harmonics.
Any kind of help (formulas, bibliography, etc. ) is welcome!
I don't know of a good reference, but I can outline a method that will work. First of all, you want to start with the spherical harmonics written in terms of Cartesian coordinates
[tex]Y^I = C^I_{i_1\cdots i_k} x^{i_1}\cdots x^{i_k}. [/tex]
The [tex]x^i[/tex] are one of the coordinates [tex]x,y,z[/tex], while the [tex]C^I_{i_1\cdots i_k}[/tex] are symmetric traceless tensors of [tex]SO(3)[/tex]. [tex]k[/tex] counts the degree, so it's the [tex]\ell[/tex] quantum number of the harmonic. The index [tex]I[/tex] ranges over the [tex]2k+1[/tex] different symmetric traceless tensors, or alternatively over the same number of harmonics of degree [tex]k[/tex]. So [tex]I[/tex] is analogous to the [tex]m[/tex] quantum number of the harmonic.
To compute integrals of harmonics, we need the formula
[tex]\int_{S^2} x^{i_k} \cdots x^{i_{2m}} = 4\pi \frac{2^m}{(2m+1)!} \left( \delta^{i_1 i_2} \cdots \delta^{i_{2m-1} i_{2m}} + \text{perms} \right). ~~~(*)[/tex]
I didn't compute this very carefully, but considered a few cases and guessed the coefficient. It's been years since I've had to use this for anything and can't remember if there's a trick to do it cleanly.
Now to compute integrals of products of harmonics, we just multiply (*) by factors of [tex]C^I_{i_1\cdots i_k}[/tex] and compute the number of ways that the [tex]C\text{s}[/tex] can be contracted. For 2 of them,
[tex]\int_{S^2} Y^{I_1} Y^{I_2} = 4\pi \frac{2^k}{(2k+1)!} k! \delta^{I_1I_2},[/tex]
while for 3 factors
[tex]\int_{S^2} Y^{I_1} Y^{I_2} Y^{I_3}= 4\pi \frac{2^{\Sigma/2}}{(\Sigma+1)!} \frac{k_1!}{\alpha_1!}\frac{k_2!}{\alpha_2!}\frac{k_3!}{\alpha_3!} \langle C^{I_1}C^{I_2}C^{I_3}\rangle,[/tex]
where
[tex] \Sigma = k_1 + k_2 + k_3,[/tex]
[tex] \alpha_i = \frac{\Sigma}{2} - k_i,[/tex]
and
[tex] \langle C^{I_1}C^{I_2}C^{I_3}\rangle = C^{I_1}_{i_1\cdots i_{\alpha_2+\alpha_3}} {C^{I_2i_1\cdots i_{\alpha_3}}}_{j_1\cdots j_{\alpha_1}} C^{I_3i_{\alpha_3+1}\cdots i_{\alpha_2+\alpha_3}j_1\cdots j_{\alpha_1}}.[/tex]
I've never tried to work out the product of 4, but it seems straightforward if you can reproduce these formulas. I've also never tried to convert any of these formulas to ones with [tex]Y_{\ell m}[/tex]s, but I explained part of the translation, so that's certainly possible to do.
The only contribution to the integral comes from that combinations of the Y's with L=0.
So you could alternatively use the Clebsch Gordan formula repeatedly to find all the ways to couple the l's to L=0.
I recommend the Cartesian approach fzero described mainly because you can actually check the intermediate values and the Cartesian formulas. I think it's the only way which is straight-forward. If you need formulas for expanding solid harmonics in terms of Cartesians, these are given in Molecular Electronic Structure theory of Helgaker, Joergensen and Olsen.
Clebsch-Gordan coefficients become incredibly messy if many angular momenta are involved, and additionally you have the problems of phase conventions, order of components, real vs complex spherical harmonics, etc. Unless you are willing to re-calcualte the formulas yourself for your concrete Ylm definition, your chances of obtaining correct results by simply taking any textbook or published formulas are rather slim (even if the published formulas do not contain errors... unfortunatelly not something you can count on). When I need CB coefficients, I actually calculate them from the Cartesian expansions as described by fzero, because this appears to be the least painful way.
Maybe Mathematica, Maple, Octave or even the internet can do the calculation for you.
I just tried:
Integrate[SphericalHarmonicY[1,1,x,y]*SphericalHarmonicY[2,1,x,y]*SphericalHarmonicY[2,-2,x,y]*SphericalHarmonicY[1,0,x,y],{ x,-Pi/2,Pi/2},{y,-Pi,Pi}]
in
http://www.wolframalpha.com.
Here is the result:
I just tried:
in
Here is the result:
Oh, right... this is of course the best approach if the maximum angular momentum of the spherical harmonics is known beforehand and not too large: run it through mathematica and tabulate everything.
FAQ: Do you know a formula for the integral of a product of 4 spherical harmonics?
1. What are spherical harmonics?
Spherical harmonics are mathematical functions that are used to describe the angular variation of physical quantities on a sphere. They are often used in problems involving spherical symmetry, such as in quantum mechanics and electromagnetism.
2. What is the formula for the integral of a product of 4 spherical harmonics?
The formula for the integral of a product of 4 spherical harmonics is a complex equation that involves the use of Legendre polynomials and associated Legendre functions. It is often used in problems involving the interaction of multiple particles on a spherical surface.
3. What are the applications of the integral of a product of 4 spherical harmonics?
The integral of a product of 4 spherical harmonics has various applications in physics and engineering. It is commonly used in quantum mechanics to calculate the interaction between multiple particles, and in electromagnetism to solve problems involving spherical symmetry.
4. Is the formula for the integral of a product of 4 spherical harmonics difficult to understand?
The formula for the integral of a product of 4 spherical harmonics can be quite complex and difficult to understand, especially for those without a strong background in mathematics. It involves the use of advanced mathematical concepts such as complex analysis and special functions.
5. Are there any alternative methods for calculating the integral of a product of 4 spherical harmonics?
Yes, there are alternative methods for calculating the integral of a product of 4 spherical harmonics, such as using numerical integration techniques or approximations. However, these methods may not always yield accurate results and may not be applicable in all situations.
10K
