Python Docker containers in Windows "look" like VMs...
  • Thread starter Thread starter fog37
    Windows
Docker on Windows operates through a combination of Hyper-V and WSL 2, which creates a virtual machine-like environment to run Linux containers. While Docker containers are designed to be lightweight and utilize the host OS, the necessity of a VM on Windows blurs the line between containers and virtual machines. The Dockerfile's instruction to pull a parent image, such as Python with Alpine Linux, highlights Docker's reliance on Linux technology. Microsoft's integration of WSL allows for seamless development across Windows and Linux environments, enhancing productivity. Ultimately, the distinction between a "sandbox" and a "full virtual machine" is nuanced, with both technologies executing instructions on the CPU in different ways.
fog37
Hello,
I am trying to better understand how Docker works under the hood in Windows...I get the difference between virtual machines (guest OS on top of a host OS) and containers (which work with the host OS)...The Docker desktop installation process seems to automatically install both Hyper V and WSL 2 (which is different from WSL1...Hyper V a type of lightweight hypervisor to run and manage virtual machines and WSL2 is really a Linux OS virtual machine... If so, then running Docker in Windows seems to be like running a virtual machine and not a container..
IF the Dockerfile first line is FROM python :3, it means that we are instructing the docker engine to go on Docker hub and downloaed a Docker parent image containing the interpreter python as well as the Linux distribution Alpine....I get Docker is truly a linux application. Now we have both the Alpine Linux distribution and WSL2 which seem to be two Linux operating systems...Again, that looks more like a virtual machine than a container: we have Windows (our host OS), Alpine, and WSL2...
Thank you!
Technology news on Phys.org
Docker is a linux technology that runs on windows and macos. On Linux, it takes advantage of some Linux security protections to run code in a sort of sandbox using the same OS. This makes Docker containers very light-weight and reduces system resource usage on a Linux host.
When running on Windows there has to be a VM to run Docker inside. Windows provides the WSL subsystem for that and it is a VM that looks like a linux environment to Docker. It was quite "inspired" by MS to offer this but I guess they saw the writing on the wall with developers bouncing between the two environments. I know they resisted this approach for a long time forcing people to have two machines, or log into a linux machine or use dual boot...
https://en.wikipedia.org/wiki/Windows_Subsystem_for_Linux
One thing that I found cool was that the MS VS code editor works in both environments via a web service that runs inside the WSL environment and does the CRLF conversion seamlessly between them. It allows developers to span the environments much more easily.
It is probably worth pointing out that the distinction between "sandbox' and "full virtual machine" is also a matter of degree. The CPU is still executing the instructions like it always did.
I use Docker to run a specific Home Assistant Linux 'environment' on a general Linux server that handles other networking and processing capabilities for the programs running inside the Docker 'environment'.
Yes, this brings up an interesting scenario. Commodore 64 family of machines are emulated in the VICE application. Its like a VM that executes 6502 code on any machine hosting VICE. That means that the 6502 code is "translated" in equivalent machine code of the host machine to run. They even simulate the Commodore address space for peeks and pokes.
I would consider VICE a full blown VM vs something like WSL that runs linux on Windows where the opcodes of the image are the same as the host ie you wouldn't install an Apple M2 linux image on WSL if it is running on an Intel processor since the opcodes are different.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
