Does a battery exert energy keeping a capacitor charged?
In summary: According to this discussion the efficiency of generating oxyhydrogen using the HHO method should be very high given that after charging plates, the energy used by the battery to keep the capacitor charged over time in a capacitor circuit is essentially insignificant.
Piotr R
I am researching whether or not there is an equation that calculates energy used by a DC battery to keep a capacitor charged over time in a capacitor circuit.
I know a capacitor in a circuit acts as a break when it is fully charged, but does the battery continue using energy to keep the capacitor charged once it is fully charged?
Welcome to the PF.
It depends on the type of capacitor. All real capacitors will have a small "leakage current", which the battery has to supply to keep the cap from self-discharging over time. You can do a search on capacitor leakage current to see what typical values for different types of caps (electrolytic, tantalum, ceramic, etc.).
Welcome to the PF.
The type of capacitor I'm talking about is a parallel plate capacitor C = keA/d where k is the dielectric constant, e is 8.85*10^-12, A is the area of the plates, and d is the distance between the plates.
Assuming no leakage, I want to know in a theoretical sense whether or not a capacitor continues to need the battery to "push" protons onto its plate.
Intuitively, I assume that the battery has to exert energy to keep the protons pushed up against the capacitor plate, because the protons are attracted to the electrons on the opposite plate, and the "path of least resistance" is back through the wires and back through the battery.
I'm looking for an equation that depends on time, emf, capacitance that calculates the energy needed to keep the capacitor fully charged in the form of E(t) = ... where E(t) is the total energy exerted keeping the protons on the plate at time t
No leakage = no current flow.
So a battery hooked up to a capacitor will run out of energy no faster than a battery hooked up to nothing? I guess in this case there's "backwards leakage" from the plate towards the battery
For the ideal situation you are asking about, that's correct. Once the cap is charged up, you can disconnect it from the battery and both will stay at that final voltage.
Just keep in mind that all real-world capacitors and batteries have leakage currents. That's why real battery storage life is not infinite, and why real capacitors don't stay charged up forever.
TBH, I don't know what you mean by that... No current flows.
It would be better to disconnect the battery, once the capacitor was charged. (Ignoring leakage, even through dampness in the air etc)
"backwards leakage" means leakage from one plate towards the other passing through the battery
I'm asking because I am trying to figure out where energy is being used in an HHO generator, which essentially uses parallel plate capacitors in parallel.
According to this discussion the efficiency of generating oxyhydrogen using the HHO method should be very high given that after charging plates, the only energy usage is keeping the plates charged because of leakage
Does anyone know the efficiency of HHO generators btw?
What's an HHO generator? Do you mean a fuel cell? Or just splitting water into O2 and H2 using electricity?
Or do you mean like the MythBusters HHO Generator...
I'm not sure what you mean by fuel cell, but if your talking about converting hydrogen and oxygen until electricity like Honda's hydrogen car's engine does then no.
There's a lot of content on the internet about it I'm not sure which link to give you because I'm not referring to anything in particular. Maybe mythbusters? Although I'm on my phone right now and can't figure out how to get a working link.
I found this on eBay
https://www.google.com/search?q=hho...&ved=0ahUKEwj0qtPivqfTAhXk1IMKHfzBDAIQgjYIjgU
Yes this, haven't watched that video yet, I'm at the cheesecake factory
Thread closed temporarily for Moderation...
Thread reopened. After a detailed PM conversation, it does not appear that the OP is asking about over-unity.
To clear things up, I know 1 mol of water requires 237kJ of energy to dissociate into hydrogen and oxygen plus 49kJ to overcome the change in entropy of the reaction, and I know you get 237+49=286kJ of energy back from combusting the hydrogen and oxygen back into water.
I'm trying to dissect how the HHO generator is working, because I go to New Jersey Institute of Technology, and I have a capstone engineering course I have to take in a year or so, which is sort of like an undergraduate thesis, and I'm trying to figure out what topic I want to pursue.
I have an alternative, but similar proposition to approach electrolyzing water, but before I go and tell my professor it's what I want to work on, I want to have a decent understanding of the topic.
I have a few questions about the HHO generator, which if you want to know more about I recommend watching
One question I have is how efficient these generators are, and to calculate that simply divide energy output by energy input and multiply by 100.
The king of random channel that I linked claims 5 Liters per minute, but even accounting for the fact that there are 55.5 moles per liter of water, don't we need to know the resistance in the system to find the heat dissipation?
CWatters said:
Can i suggest you Google the efficiency of electrolysis. Lots of research has been done on this. For example..
https://en.m.wikipedia.org/wiki/Electrolysis_of_water#Efficiency
yeah, I'm doing that now. i just discovered a mole of hydrogen fills up about 22 Liters of space, which goes against what I initially assumed.
So i just watched this guy test a Punch 5.0 HHO generator, which claimed near 100% efficiency
and I used his voltage, current, and time measurements to calculate the energy input. He produced 1 liter of hydrogen gas, which is 0.044643 moles, because 1 mol H2 = 22.4L
The Input energy = V*i*t= (14.13V)(9.845A)(109s)=15163J
The output energy (from combusting the hydrogen is potentially) = n*H = (0.044643 moles H2) * (237.5 kJ/mol) = 10602.7 J
The efficiency is therefore output/input = 10602.7/15163 *100% = 70%
I wasn't sure whether I should use 237.5 kJ/mol, or 286 kJ/mol for the combustion output energy of hydrogen gas, but in either case, if I was supposed to use 286 kJ then the efficiency of the Punch 5.0 is 84.2%
Did I do this right? thoughts?
The efficiency is therefore input/output = 15163/10602.7 *100% = 70%
Efficiency is Output / Input, so I'm not sure how you got the right answer with your math, but whatever.
Efficiency = 10602 / 15163 = 0.699 = 70%
So it's better to use the electricity directly if possible, instead of storing the energy as Hydrogen. If you have a hydroelectric dam and want to power your car with it, then the efficiency difference between using batteries for storage versus Hydrogen and fuel cells is worth considering...
Yeah, I put input/output, and 15163/10602 but i meant the inverse. Thanks.
And in terms of cars, yeah you make a valid point, but for now I'm just looking for the most efficient way to convert electrical energy into hydrogen gas, because there are other uses for them; rocket propulsion being one
Interesting. What are some other ways to get Hydrogen? Do they all start with water?
BTW, I think you can increase the efficiency of electrolysis some by adjusting the ionic content of the water. Have you already looked at that?
no they don't wall start with water, but water covers 70% of the surface of this planet
there's other ways of getting hydrogen, like through gasification, which is when high temperature steam reacts with methane, or something, but other methods of getting hydrogen haven't been introduced to me in my curriculum, so i wouldn't really know about them
i saw that too, yeah.
that's like a final step sort of thing after i design the system, and the fundamentals are finalized i'd probably do control tests to compare different electrolytes
I thought it produce a 1 liter mixture of hydrogen and oxygen? That would be 0.66L (0.03 mole) Hydrogen and 0.33L Oxygen. It could even be less because the mixture was bubbled through water at 91 degrees so the mix is probably not at STP.
I agree with your figure for the input power.
Revising the figures for the output gives..
(0.03 moles H2) * (237.5 kJ/mol) = 7125J
with the efficiency working out at about
(7125/15163) * 100 = 47%
Likes Piotr R
Hmm I think you're right, I thought the hydrogen was being separated from the oxygen for some reason.
Either way though, don't you need oxygen for the combustion reaction i.e. 2 H2(g) + O2(g) ->2 H2O(g) + 475 kJ ?
I could be wrong, but that's what I thought
Nevermind I think you're right that it's 47% efficient
Where does all that energy go I'm wondering?
And btw i think the hydrogen combustion energy output is 286 kJ/mol, so the efficiency would be
0.03 * 286 = 8580 kJ
-> 8580/15163 * 100 = 56.59%
I think most of the loss goes into heating the water.
In theory you only need something like 1.2-1.4V to split water so running at 12-14V is wasteful..
https://en.wikipedia.org/wiki/Electrolysis_of_water
Electrolysis of water
is the decomposition of water (H2O) into oxygen (O2) and hydrogen gas (H2) due to an electric current being passed through the water. The reaction has a standard potential of −1.23 V, meaning it ideally requires a potential difference of 1.23 volts to split water.
Overpotential[edit]
Real water electrolysers require higher voltages for the reaction to proceed. The part that exceeds 1.23 V[24] is called overpotential or overvoltage, and represents any kind of loss and nonideality in the electrochemical process.
For a well designed cell the largest overpotential is the reaction overpotential for the four-electron oxidation of water to oxygen at the anode; electrocatalysts can facilitate this reaction, and platinum alloys are the state of the art for this oxidation. Developing a cheap, effective electrocatalyst for this reaction would be a great advance, and is a topic of current research; there are many approaches, among them a 30-year-old recipe for molybdenum sulfide,[25] graphene quantum dots,[26] carbon nanotubes,[15] perovskite,[27] and nickel/nickel-oxide.[28][29] The simpler two-electron reaction to produce hydrogen at the cathode can be electrocatalyzed with almost no overpotential by platinum, or in theory a hydrogenase enzyme. If other, less effective, materials are used for the cathode (e.g. graphite), large overpotentials will appear.
Not sure if this has changed but most Hydrogen used to be made from fossil fuel because its cheaper than using electricity. ..
https://en.wikipedia.org/wiki/Hydrogen_production
As of 1999, the majority of hydrogen (∼95%) is produced from fossil fuels by steam reforming or partial oxidation of methane and coal gasification with only a small quantity by other routes such as biomass gasification or electrolysis of water.[/quote]
I know the energy on the plates is U = CV^2/2 where U is the energy, C is the capacitance, and V is the voltage.
In this case I'm assuming that the plate configuration creates a parallel plate capacitor
You're saying that some of this energy is heating the water, right? That makes sense. Along with what berkeman mentioned about leakage, I guess that's two sources right there the system is losing energy.. interesting
  • #31
I don't think there is much to be gained by thinking of the cell as a capacitor. There will be some capacitance but it's not really relevant to the operation of the cell. Once the capacitance is charged (occurs in fractions of a second) no further energy is needed to charge that capacitance.
No I'm not saying that some of the energy used to charge the capacitor is wasted.
The leakage current in a capacitor is normally designed to be as small as possible. That's not the case with an electrolysis cell. You actually want current to flow between the plates of an electrolysis cell.
Likes berkeman
  • #32
I agree with CWatters. The electrolysis cell is not modeled as a capacitor, and there are no significant reverse leakage currents.
It is a load that you drive with a voltage. There is a forward current that flows. That voltage and current do work -- some of that work splits the water into H2 and O2, and some of it does work on the water (by driving ions through the water), which is lost as heat.
  • #33
Maybe not in this case there isn't, but in the case of my undergrad project it is relevant. And to my understanding current does not flow between the capacitor plates in pure water situations, which is why people use electrolyte because
Electrolysis of Water: Pauling, Linus (1970) General Chemistry, Section 15-2. San Francisco.
"If a water-soluble electrolyte is added, the conductivity of the water rises considerably. The electrolyte disassociates into cations and anions; the anions rush towards the anode and neutralize the buildup of positively charged H+ there; similarly, the cations rush towards the cathode and neutralize the buildup of negatively charged OH− there."
But for the most part capacitors produce electric fields; not current.
the reason water is being split is because of the opposite charges on the capacitor plates. one plate's charge is positive, and the other plate's charge is negative, so the negative oxygen atoms are attracted to the positively charged plate, and the positive hydrogen ions are attracted to the negatively charged plate.
it is not beneficial if there is current running between the plates, because in the case there is current: There would be no difference in having a capacitor setup like we've been discussing, and a straight up wire in water.
As mentioned above, electrolyte is added, but not to explicitly allow current to flow between the plates, but instead to neutralize the build up of H+ ions and OH- ions on either plate, so that the process of generating electric field, and likewise creating an anode and a cathode can continue
  • #34
Capacitors don't pass DC currents... :smile:
  • #35
Capacitors don't pass currents at all
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
