Gamerex
- 25
Say light was a stream of water. What would the black hole be? A bend in the river or a waterfall?
Gamerex said:Say light was a stream of water. What would the black hole be? A bend in the river or a waterfall?
Shapiro delay shows that any gravity field actually slows down the speed of light.Gamerex said:Does a black hole cause light to move faster?
I'd say it wouldn't behave like a plug hole at all. Not if the Shapiro delay is true. Seems to me the slowing of light would make each photon appear to be repulsed by the black hole rather than sucked into it.Gamerex said:Say light was a stream of water. What would the black hole be? A bend in the river or a waterfall?
This document might help you understand more about that:Gamerex said:Say light was a stream of water. What would the black hole be? A bend in the river or a waterfall?
Gamerex said:So it's a no. Or a yes. Unfortunatly, I know almost nothing about space-time(Nor the terminology), and like theory more than other things. I guess it's a no.
Not really, it just increases the distance over which the light has to travel. (Well... perhaps you could think about it as slowing light, but that interpretation doesn't really make sense to me)YellowTaxi said:Shapiro delay shows that any gravity field actually slows down the speed of light.
http://en.wikipedia.org/wiki/Shapiro_effect
Still no.robokar said:what if the black hole was directly infront of it
As others have already indicated above, there's more than one way to measure speed in general relativity. Any observer, anywhere in the Universe, making a local measurement of light passing right by, using local rulers and local clocks, measures light to travel at c in vacuum. But if you try to measure light some distance away from you, you may well get a different answer. So if you are hovering outside a black hole, you can calculate the speed of light inside the event horizon to be greater than c, but if you fell into the hole and made a local measurement you would get c.Schrodinger's Dog said:Stephen Hawking said light will travel faster than c in a black hole but I think he's lost the plot a bit these days, light will travel at c in the vacuum end of story. Gravitational lensing may make it look like it is going faster or slower but speed=d/t will never be more than c.
DrGreg said:As others have already indicated above, there's more than one way to measure speed in general relativity. Any observer, anywhere in the Universe, making a local measurement of light passing right by, using local rulers and local clocks, measures light to travel at c in vacuum. But if you try to measure light some distance away from you, you may well get a different answer. So if you are hovering outside a black hole, you can calculate the speed of light inside the event horizon to be greater than c, but if you fell into the hole and made a local measurement you would get c.
It's a bit like the problem cartographers have mapping the world on a flat piece of paper. Small areas (say, less than 50 miles / 100 km across) can be mapped pretty accurately. But if you try to draw a map representing thousands of miles, although part of the map may be accurate, another part will inevitably be on the wrong scale or have the wrong angles.
Hawking hasn't lost the plot.
A black hole is a region in space with a gravitational pull so strong that nothing, including light, can escape it.
No, a black hole does not cause light to move faster. In fact, the strong gravitational pull of a black hole causes light to slow down as it approaches the event horizon.
The speed of light is constant in a vacuum, but the gravitational pull of a black hole can bend the fabric of space-time, causing light to appear to slow down or speed up as it passes near the black hole's event horizon.
No, nothing can escape a black hole, including light. Once light crosses the event horizon of a black hole, it can never escape.
The speed of light is constant in a vacuum, even inside a black hole. However, because of the extreme gravitational pull, the path of light inside a black hole may appear distorted or curved.
