Does a blueshift change the energy of a photon?
In summary, the energy of a photon depends on its wavelength and when it is blueshifted it has more energy. When a spaceship with a solar panel on the front travels towards the sun at relativistic speeds, the incoming photon undergoes a blueshift from the observer on the spacecraft. There are two options for the solar panel's reading: either it reads two different numbers depending on the observer, or it reads the same because the energy of the photon is not actually based on wavelength. Energy is a frame dependent value in both relativistic and classical mechanics. Momentum is also frame dependent but is conserved during collisions. Invariant quantities, such as the speed of light, are the same in all frames. Different frames may disagree on the values of
Nicholas Harris
The energy of a photon depends on its wavelength, so theoretically when it is blueshifted it should have more energy right?
Then what if a spaceship with a solar panel on the front is traveling towards the sun at relativistic speeds. An incoming photon undergoes a blueshift from the observer on the spacecraft . So does the solar panel read the same energy as if the light wasn't blueshifted? I see two options here: 1. Either the solar panel reads two different numbers depending on the observer. (almost like 2 realities exist) 2. Or it reads the same because the energy of the photon is not actually based on wavelength
To keep it simple let's imagine we're only talking about one photon, because time dilation might affect the power level the solar panel was reading.
There isn't an awful lot of difference between time dilation and blue shift (edit: that's an exaggeration, but they are intimately related). But yes, a ship traveling towards the sun will see more energy from a pulse of light than one moving away. Energy is a frame dependent value, both in relativistic and classical mechanics.
The collision is just like any other. In the frame where the rocket is at rest, all of the energy comes from the light and is absorbed by the rocket. In a frame where the rocket is moving, the kinetic energy of the rocket can either decrease or increase, so it can be either a source or sink for energy.
Incidentally, photons do not keep things simple. Best to get into the habit of thinking in terms of pulses of light (perhaps two identical ones absorbed by different ships, or whatever) until you actually mean to start quantum field theory.
Likes Dale
It needs to be stressed that energy is not an observer independent quantity. Hence, a light signal in itself does not have a fixed energy. In order to say a light signal has a certain energy you must specify according to which observer (which is often done implicitly). Energy in general is an observer dependent quantity. This is true also in classical mechanics.
Likes Dale
Yes.
No, all frames agree on the outcome of any measurement. The result of the measurement depends on the motion of the measurement device, but all frames agree on the number.
No, the energy is based on the frequency. The frequency is a relative quantity, and so is the energy. Energy is conserved, but not invariant.
Dopper effect is another way for explanation.
So energy of photons are different in different frame, but momentum must constant, by law of conservation of momentum. E=pc, how could that possible?
Momentum will be different in different frames too. Momentum will be conserved during the collision, yes, but different frames do not agree on the value. For example, if you drop a 1kg bag of sugar and it hits the ground at 1m/s then in the rest frame of the Earth the total momentum is 1Ns. In the rest frame of the bag of sugar it's the Earth that is moving at 1m/s, giving a total momentum of 6×1024Ns. Both frames agree that the total momentum is unchanged before and after the collision, however.
Edit: the point is that there's a difference between an invariant quantity, which is one that is the same in all frames (e.g. the speed of light), and a conserved quantity, which is one that does not change with time (e.g. total momentum of a closed system).
Likes Pencilvester, Imager and Orodruin
And could you expand a bit on this by saying how that happens mathematically. Would it be the inner product being invariant?
You are confusing “conserved” with “invariant”. They are two completely different qualities. “Conserved” means that the value does not change over time. “Invariant” means that different frames agree on the value.
Energy and momentum are conserved, but they are not invariant.
Mass is both conserved and invariant.
Proper acceleration is invariant but not conserved.
Velocity is neither conserved nor invariant.
Anything you can directly measure must be a Lorentz scalar, of which the inner product is an example, yes. But not the only one - for example a clock measures interval along its worldline.
If you could measure something that wasn't a scalar then frames could disagree about the results which would lead to paradoxes.
Likes kent davidge and Dale
Yes, the inner product of two vectors gives a scalar, and all scalars are invariant. All measurements produce scalars.
Likes kent davidge
Why do you and Ibix say that measurements only produce scalars? I can measure energy, for example, which is not a scalar. It is frame dependent of course, but I can still measure it.
But the reason that an energy measurement is invariant is that it is a scalar. It is an inner product of e.g. a particle 4 momentum and an instrument 4 velocity. As a result, all observers agree on the outcome of this specific measurement
Now that contradicts Orodruin's and Ibix's first posts where they say energy is not invariant.
No, it does not. In speaking of measurements being scalar invariants, one notes that the result of a measurement depends on the 4 velocity of the instrument. Two instruments in relative motion will get different results, but each result is invariant and computable as an inner product in any frame.
It does not. A device set up to measure energy measures energy measures the energy in a particular frame (often implicitly assumed to be the rest frame of the device). This is a measurement and all observers must agree on what this measurement is. The Lorentz invariant way of writing the quantity that is measured is to take the inner product of the 4-momentum of what is being measured and the 4-velocity of the observer relative to whom you are measuring the energy.
OK, I understand. If you think of a measurement producing a reading on a display, for example, any observer in any state of motion could read it, so they all must agree on what the display says. The energy measured in frame A (inner product of momentum being measured with 4-velocity of frame A) will be different from the energy measured in frame B (inner product of momentum being measured with 4-velocity of frame B), but everyone must agree on the results of these measurements.
Likes Dale
Do we give awards for light bulbs going on over people's heads? If so, you just earned at least three of them!
Likes Dale
To amplify a bit on others' responses to this: suppose there are two observers, A and B, who are in relative motion. Each one carries an energy measuring device and each one uses their own device to measure the energy of the same particle.
"Energy measurements are scalars and are therefore invariant" means: A and B will both agree on the reading on A's device, and A and B will both agree on the reading on B's device, even though A and B are using different frames to calculate what that reading will be.
"Energy is not invariant" means: A's device and B's device will show different readings, because they are in relative motion.
Likes Imager, Dale and Pencilvester
It seems that you already got it, but one more take might help. If observer A, in relative motion to observer B, measures the energy of something, then both A and B will agree on the number that A’s measuring device produces. However, B will disagree that the number produced is, in fact, a correct measurement of the energy. In B’s frame the energy is a different number and A’s device systematically fails to measure it correctly. (And vice versa, of course)
Likes SiennaTheGr8
Hmmm I think I got it. Let's say A reads a different value as that of B, still A will agree on the reading of B, because he knows that upon a coordinate transformation from his coordinates to the B coordinates he will get the same reading as B?
Yes, that is a valid coordinate-based way to look at it.
It is also possible to look at it in a coordinate independent manner.
##E_{measured}=g_{\mu\nu}p^{\mu}u^{\nu}##
Where p is the measured object’s four momentum and u is the measuring device’s four velocity. This is a manifestly invariant quantity.
Likes vanhees71 and kent davidge
No. (Sorry if I seem to be contradicting @Dale, I think it's because he and I are intepreting what you say differently.)
"A coordinate transformation to the B coordinates" does not change A's state of motion. A can use coordinates in which B is at rest, input his own (A's) motion in those coordinates, and still calculate the same answer for his own reading. (So can B, of course.) He can also perfectly well use coordinates in which he (A) is at rest, input B's motion in those coordinates, and calculate the correct answer for B's reading. That's why both readings are invariants: they come out the same no matter what coordinates you use to calculate them.
If A changes his state of motion to be the same as B's, then he will get the same reading as B. But he can do that without changing the coordinates he uses. It's very important not to confuse the choice of coordinates with an actual change in state of motion.
Likes kent davidge
Related to Does a blueshift change the energy of a photon?
1. What is a blueshift and how does it affect the energy of a photon?
A blueshift is a phenomenon in which the wavelength of light is shortened, causing the light to appear more blue. This shift in wavelength does not change the energy of a photon, but it does indicate that the source of the light is moving closer to the observer. This can happen due to the Doppler effect, where the motion of the source or the observer causes a change in the perceived wavelength of the light.
2. Can a blueshift change the energy of a photon?
No, a blueshift does not change the energy of a photon. The energy of a photon is determined by its frequency, which remains constant regardless of the wavelength or perceived color of the light. The energy of a photon can only be changed by interacting with other particles or through processes such as absorption or emission.
3. How is a blueshift different from a redshift?
A blueshift and a redshift are opposite effects, where a blueshift shortens the wavelength of light and a redshift lengthens it. They are caused by the same phenomenon, the Doppler effect, but their direction depends on the relative motion of the source and the observer. A blueshift indicates that the source is moving closer, while a redshift indicates that the source is moving away.
4. Can a blueshift be observed in other forms of energy besides light?
Yes, the blueshift phenomenon can also be observed in other forms of energy, such as sound waves or electromagnetic radiation. In sound waves, a blueshift would result in a higher pitch, while in electromagnetic radiation, it would result in a higher frequency and energy. However, the blueshift effect is most commonly associated with visible light and is often used in astronomy to study the motion of celestial objects.
5. How is the blueshift effect used in scientific research?
The blueshift effect is used in various scientific fields, including astronomy, cosmology, and particle physics. In astronomy, it is used to study the motion and distance of celestial objects, as well as the expansion of the universe. In cosmology, it is used to study the origins and evolution of the universe. In particle physics, it is used to study the energy and momentum of subatomic particles. Additionally, the blueshift effect is used in medical imaging, such as Doppler ultrasound, to measure blood flow and detect abnormalities in the body.
