Does a bullet enter water easier?
In summary, a bullet shaped container with 350 psi air pressure filling behind it and 300 psi water in front will force the bullet out of the tube into the water. The shape and density of the bullet may affect the outcome, but ultimately the superior force will cause it to move in that direction.
genergy
If I have a bullet shaped container in a narrow tube and the back flat side has 350 psi air pressure filling behind the bullet and the front side (the conical side) is facing down in 300 psi water will the bullet be forced out of the tube into the water?
If the bullet has a density of .99 (slightly buoyant) would that matter?
Would it matter if the shape was not a bullet but rather had 2 sides equally flat?
If water or any liquid applies equal pressure in all directions but a superior force is directed in only one direction wouldn't that cause the bullet to move in the direction of the superior force?
Yes, the bullet would be forced out of the tube into the water. The shape of the bullet would not significantly affect the outcome. The density of the bullet would make a difference, as a more buoyant bullet may not be pushed out of the tube as effectively. Yes, if the water or any liquid applies equal pressure in all directions but a superior force is directed in only one direction, this would cause the bullet to move in the direction of the superior force.
FAQ: Does a bullet enter water easier?
Does a bullet travel faster in water or air?
A bullet travels faster in air because water has a higher density and therefore creates more resistance.
Can a bullet still penetrate water?
Yes, a bullet can still penetrate water but it will lose speed and momentum as it travels through the water.
How far can a bullet travel in water?
The distance a bullet can travel in water depends on factors such as the type of bullet, its velocity, and the depth of the water. However, on average, a bullet can travel up to 3 feet in water.
Does the shape of a bullet affect its ability to enter water?
Yes, the shape of a bullet does affect its ability to enter water. A pointed and streamlined bullet will have less resistance and therefore be able to travel further in water compared to a flat or rounded bullet.
Can a bullet kill underwater?
It is possible for a bullet to kill underwater, but it is less likely due to the resistance of water. The bullet may not have enough speed and momentum to cause significant damage to a target. Additionally, the impact of the bullet may also be affected by the density of the water and the angle at which it enters the water.
