Does a "heat pump" not spew HFCs like an "air conditioner"?
In summary: ASHARE-Research-Report-Air-Conditioning-Heating-and-Cooling-Efficiency-2013According to the ASHARE study, ground source is twice as... efficient? as air source:The ASHARE study found that ground source heat pumps were twice as efficient as air source heat pumps when it came to cooling.
swampwiz
571
83
https://slate.com/technology/2022/0...hin-heat-pump-solar-panels-electric-cars.html
In this era of heat waves, air conditioning can be a lifesaver. The problem is that popular A/C tech—primarily used within the U.S.—emits hydrofluorocarbons, which are even more effective than carbon dioxide at trapping hot gases in the atmosphere and heating the overall planet. To help solve this problem, President Joe Biden signed an executive order last month to spur the production of heat pumps, which use electricity to shift hot air in and outside of a given indoor space as needed (and without spewing HFCs), through the Defense Production Act.
First, this text makes no sense as it seems to say that the problem with A/C can be solved by "shift[ing] hot air in". But then it also seems to say that a "heat pump" - which I have always thought had the *popular* definition of basically being an air conditioner with the controlled & ambient sides reversed (technically both are heat pumps - i.e., does a cycle that is counter-clockwise in T-s space) - somehow doesn't spew HFCs like an "air conditioner" does.
EDIT: OK, the author had dropped the term "geothermal", as this device is referred to as a "geothermal heat pump":
https://en.wikipedia.org/wiki/Ground_source_heat_pump
There needs to be some better terminology in HVAC as this is not a "heat pump", but rather a "ground source heat conduction device".
The whole thing is ridiculously uninformed. The statement reads as if the writer knows nothing factual regarding heating and cooling except for firmly believing in the magic of the thermostat.
For air conditioning we use a sealed system that doesn't "spew" anything, they leak if you neglect them to the point that they break. We absorb heat from the inside air circulating in the home, transfer it to refrigerant circulating in the sealed system, and reject the absorbed heat outside. A heat pump is identical, but capable of being reversed.
Likes russ_watters, Vanadium 50, berkeman and 1 other person
I was under the impression that residential geothermal systems used the stable underground temperature to both heat and cool but was disappointed to find out they are basically the same as air source heat pumps but just are a bit more efficient using the ground as the heat exchange media instead of the air (as I understand it). They still rely on compressors. Seems like a big expense over an air source system for a little increase in efficiency. Maybe in some areas the air is too cold in winter but in Texas I can't see the advantage of a ground source heat pump over air source.
"I can't see how" is not valid engineering.
They do use stable underground temperatures. There are efficiencies to having cold (warm) thermal sink (source) for cooling (heating) using a thermal pump. The question is whether they are big enough gains to warrant the added environmental expense of below ground heat exchangers when amortized over system lifetime. You run the numbers and choose wisely.
This sort of is like rocket science
I answered that question for myself after a 2 hour presentation I recently went through and was rather disappointed. I could buy three air source systems for one geothermal system. I did not think that was worth the extra efficiency. You might have a different answer but there are other complicating factors than just the technical details too.
Likes hutchphd
But is it really a small increase in efficiency? I thought it was a big increase.
What, exactly, did you find?
Efficiency is a function of temperature difference. In AC mode instead of running 90F air across the coil you use 60F water. In heating it's 60F water instead of 20F air.
Air source heat pumps also have minimum operating temperatures and some won't even run below 20-30F. And even if they do, it's at lower capacity. So they need supplemental heat.
Edit: according to this ASHARE study, ground source is twice as efficient:
https://blog.geocomfort.com/case-study-geothermal-vs-air-to-air-heat-pumps
Likes anorlunda
3x expensive. For this vendor giving the presentation you have to schedule the digging it ~9 months in advance. Wells need to be spaced apart ~20 ft and in small lots you might have to put wells under driveways and other places incurring extra costs. If you have some land, it's all easier. I would send you the presentation of our meeting but it's not up on the web yet.
Yes, I underestimated the efficiency difference but the cost difference was ~50 dollars a month in energy costs which is not that much considering it would take 50 years of savings to break even with the up front system cost if paid for in cash assuming the air-air system was ~15k vs. the ground system ~45k.
I think the first line of defense for reducing energy usage and cost is upgrading the efficiency of the house itself in terms of insulation, windows and other such things and whatever system one has make sure it is in proper working order. A modern more efficient conventional AC unit with an efficient sealed house and a good digital thermostat at reasonable settings will save a lot of energy.
Due to the inaccurate and inflammatory thread title, this thread is closed.
Likes cjl, Bystander, russ_watters and 1 other person
FAQ: Does a "heat pump" not spew HFCs like an "air conditioner"?
What is the difference between a heat pump and an air conditioner?
A heat pump and an air conditioner both work to cool a space, but they use different methods. An air conditioner removes heat from the air inside a building and expels it outside. A heat pump, on the other hand, can both cool and heat a space by transferring heat from one location to another.
Do heat pumps use HFCs?
Yes, heat pumps do use HFCs (hydrofluorocarbons) as a refrigerant, just like air conditioners. However, newer models are designed to use more environmentally friendly refrigerants such as R-410A, which has a lower impact on the ozone layer.
How do HFCs contribute to climate change?
HFCs are a type of greenhouse gas that contribute to climate change by trapping heat in the Earth's atmosphere. They have a high global warming potential, meaning they have a much stronger effect on climate change compared to other greenhouse gases like carbon dioxide.
Are there any alternatives to HFCs in heat pumps?
Yes, there are alternatives to HFCs in heat pumps, such as hydrocarbons and carbon dioxide. These refrigerants have a lower global warming potential and are considered more environmentally friendly. However, they may have some safety concerns and require specialized equipment for installation.
Can heat pumps be retrofitted to use alternative refrigerants?
It is possible to retrofit a heat pump to use alternative refrigerants, but it may not be a simple process. It would require replacing the existing refrigerant and making sure all components are compatible with the new refrigerant. It is best to consult a professional before attempting to retrofit a heat pump.
13K
9K
47K
