High School Does a photon's energy change as it refracts?
When a photon is refracted, it slows down, leading to a decrease in wavelength while its frequency remains constant, implying it does not lose energy during this process, as described by E=hf. Inside a transparent medium, photons behave as quasi-particles rather than free photons, affecting their energy dispersion relation. Some energy is lost during reflection and scattering when light interacts with a medium, but the exiting photons typically maintain the same frequency. The energy balance of the light beam accounts for these losses, while individual photons retain their energy upon exiting. Overall, the discussion clarifies the relationship between photon energy, frequency, and behavior during refraction.
maxelcat
TL;DR
Does the energy of a photon change as its velocity changes due to refraction?
I believe that when a photon is refracted it slows. Why is it that the wavelength decreases but that its frequency stays constant?
Does this imply that the photon has not lost any energy in the process of slowing down given that E=hf?
Thanks
Yes, this is the implication. If a photon transfers energy somewhere, then either the photon vanishes completely, or its frequency goes down.
But I answered, because I thought about the same question in the context of electrons in a crystal recently, and the eigenvalue problem one solves to get the Bloch waves. I wondered whether the eigenvalues are related to the energy, or to something else. Initially I was convinced that it must be related to energy, but in the last few days I changed my mind, because the frequency cannot really change, without an interaction and energy transfer.
maxelcat said:
TL;DR Summary: Does the energy of a photon change as its velocity changes due to refraction?
Thanks
If the material is transparent and finite, you can say that the photons entering the material and leaving the material have the same energy. However the photons inside the material are no longer photons but quasi-particles of the light-matter system (you can be sure of that because the wave vector ##\mathbf k## is no longer the same, so your energy dispersion relation is not that of a free photon).
Part of the incident energy is reflected when a wave strikes a transparent medium, so I presume that in quantum terms an occasional photon is reflected at the surface?
Yes. If you look at the whole energy balance, you will lose some energy of the light beam in reflection, diffusive scattering and heat, but if you look at the individual photons that exit the material, these photons have usually the same frequency (same for those that are specular reflected).
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 78 ·
