Does a pump face less back pressure if a vertical pipe is wider?
  • Thread starter Thread starter Ray F
    Pump
A pump will face less back pressure when pumping water through a wider vertical pipe, such as a 20 mm diameter compared to a 10 mm diameter, assuming the flow rate remains constant. The hydrostatic pressure, which depends solely on the height, is the same for both pipe sizes. However, the resistance to flow, influenced by wall friction, is reduced in larger diameter pipes, leading to lower back pressure. This principle is often applied in systems like central heating, where larger pipes are used to minimize pressure loss. Therefore, using a wider pipe can enhance pump efficiency by reducing back pressure.
Ray F
How did you find PF?: google search
I've worked at sea for a number of years and now I'm particularly interested in learning more about fluid dynamics in order to find practical solutions to environmental problems. I would be very grateful for any advice people on this forum can give me.
At the moment I want to pump water up to the roof of a house. My question is this: will a pump that pumps water 10 meters up a vertical pipe of 10 mm Inside Diameter face less back pressure pumping the same water 10 meters up a pipe of 20 mm Inside Diameter? Or is the back pressure the same? Thank you for your help.
At the same flow rate in each case?
It depends upon the flow velocity and perhaps the surface roughness of the pipe. Here is a good simple treatment https://en.wikipedia.org/wiki/Friction_loss
The middle part is excellent, in my opinion. Please ask questions as necessary
Welcome to PF.
To pump water upwards, you must overcome both the hydrostatic pressure, and the resistance to flow in the pipe.
Hydrostatic pressure is a function of height only, not of diameter.
The added back pressure, due to the resistance to flow, is due to wall friction of the water flowing in the pipe. It will be less for a bigger diameter pipe, but that back pressure will be dependent on the flow rate and the pipe details.
Likes Juanda, Rive, russ_watters and 1 other person
The bigger pipe will put less back pressure on the pump for the same flow.
As demonstrated by the fact that central heating (water) central heating often uses large bore pipes (according to a number of rules of thumb) according to the flow of water they need to take. I quote central heating because the system pressure is usually only a bar. Cold water supplies are straight off the mains and tend to use 15mm pipe throughout. Copper is too expensive for plumbing to be over generous with large bore pipes.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
17K
10K
