Does a rod rotate under gravity?
In summary, the rod does not rotate around a point that is removed from the rod. The torque is due to the difference in direction of the force on each end.
albertrichardf
165
Hello.
Say you have a uniform rod in free-fall. Would it rotate?
Suppose you compute the rotation around the CM. I computed that the lever arm is the same on either side, regardless of the angle at which the rod falls, so there can't be any rotation. So if I just dropped a 30º to the horizontal rod, it would fall and stay at 30º to the horizontal. Is that correct?
Also, suppose I compute the rotation around one end of the rod. The torque is non-zero, but the rod is not rotating around that point. How is that possible? Furthermore, since the rod is falling, the end is falling as well, so my reference point is moving. If the reference point was stationary (the end of the rod is falling, it does not necessarily coincide with the point), does that change anything?
Thank you for answering
For simplicity, assume the rod consists of two point masses at each end, connected by a rigid massless string. Compute the magnitude of the gravitational force on each end. Are they equal?
The gravitational force should be equal at either end. So I guess there would be no net torque either
It isn't.
The gravitational force is given by
$$F=GMm/R^2$$
Where ##R## is the distance from the source of gravity to the CoM of the rod. If the rod of length 2x is inclined at any angle ##\alpha## other than horizontal, the closer end will experience
$$F=GMm/(R-xsin\alpha)^2$$
the farther end will have
$$F=GMm/(R+xsin\alpha)^2$$
This difference is what is called tidal force. It produces torque on the rod and acts to align it vertically (parallel to the direction to the source of gravity). This is used to stabilise satellites (cf: https://en.wikipedia.org/wiki/Gravity-gradient_stabilization) and a part of tidal locking mechanism of natural satellites.
Under an additional assumption that the source of gravity is a point-mass (or equivalently - spherically symmetric), with careful analysis you should notice that the torque is not only due to the difference in magnitude of the force, but also due to the difference in direction of the force on each end, as from either end's perspective the direction to the source of gravity is different.
When the rod's length compared to the distance is non-negligible, then the torque isn't. But I was talking about a rod much smaller than Earth, so that ##F≈mg##. Then based on the your analysis, the force should be equal on both ends and there is no net torque.
Thank you about the tidal effect link.
Yes, under the assumptions that the gravitational field is uniform and that it is initially not rotating.
This type of body centered computation is possible, but you need to carefully account for the reference frame. In this case (assuming Newtonian mechanics) the reference frame is non inertial. There is a fictitious force pointing upwards, exactly equal to gravity. So the torque about the end is zero in that frame, which is consistent with the observed motion.
Alright. But what if I did not choose an end of the rod as a computation point, but I chose a point that was completely removed from the rod altogether? The point would not be accelerating so there could not be a fictitious force.
Likes Dale
If there is no fictitious force then you are talking about an inertial frame. For such a frame there is only the force of gravity, and depending on where you choose your origin gravity can exert a torque. If it does then the angular momentum about the origin will increase as the rod falls.
To see how this works, it is best to actually work the problem. An object does not need to spin about its own axis to have angular momentum about an external point.
The angular momentum of a non-rotating, falling brick as computed about a point some horizontal distance away from the brick is not constant.
If the angular momentum changes, does that necessarily imply that the centre of mass of the rod is rotating around that point?
In the sense that it has a non zero angular momentum and non zero angular velocity, yes. In the sense that its path is curved, no.
That's what I meant. Thank you for answering
You are welcome, you write a lot of good questions.
Likes albertrichardf
Thanks. And you write a lot of good answers
Likes Dale
FAQ: Does a rod rotate under gravity?
1. Does a rod always rotate under gravity?
Yes, a rod will always rotate under gravity if it is not fixed at one end. This is due to the force of gravity acting on the center of mass of the rod, causing it to rotate around that point.
2. How does the length of a rod affect its rotation under gravity?
The longer the rod, the slower it will rotate under gravity. This is because the force of gravity is acting on a longer lever arm, making it more difficult for the rod to rotate. However, a longer rod will also have a larger moment of inertia, making it harder to rotate once it is in motion.
3. Can a rod ever stop rotating under gravity?
Yes, a rod can stop rotating under gravity if the force of gravity is balanced by another force, such as friction or air resistance. Additionally, if the rod is fixed at both ends, it will not rotate under gravity.
4. How does the mass of a rod affect its rotation under gravity?
The mass of a rod does not directly affect its rotation under gravity. However, a heavier rod will have a larger moment of inertia, making it harder to rotate once it is in motion.
5. Is the rotation of a rod under gravity affected by its shape?
Yes, the shape of a rod can affect its rotation under gravity. A rod with a larger cross-sectional area will experience more air resistance, slowing its rotation. Additionally, a rod with a non-uniform shape may have a different distribution of mass, affecting its moment of inertia and therefore its rotation under gravity.
