Ahsan Khan
- 270
- 5
Hello all,
First of all I want to mention what believe or result of concepts, do I hold about rotational motion especially about the angular velocity. I assume that unlike velocity angular velocity has to worked out from some point. I will begin with particle for this I assume that the question of finding the angular velocity of a particle is meaningless unless it is told from what point angular velocity has to be worked since what I think is that a given rotatating particle can have different angular velocities when calculated from different points. Correct me if i am wrong here.I am holding also the similar view for rigid body that when a rigid body is rotating about some axis then the angular velocity of all points on body will be the same when the angular velocity is observed from the point of axis of rotation. But the about some points exist on other than axis of rotation the different points of the rigid body will have in general different angular velocities.
Are these my views consistent with the reality?
Regards
Regards
