Does a set of matrices form a ring? Or what is the algebraic structure?
In summary,There are two ways that a set of matrices can be everything: as a set of linear representations in a vector space, or as the set of all invertible matrices.
askmathquestions
65
Square matrices are closed under addition and their own form of multiplication, but in general do not commute.
What algebraic structure then describes this, along with polynomials of matrices and allows us to amend with other operations, such as differentiation or integration defined on these objects? Would the appropriate algebraic structure be a ring or a field?
Yes, the set of all ## n \times n ## Matrices over a ring R are a ring, not a field, since your general matrix is not invertible under multiplication. notice this, matrices being square, is needed to define multiplication. The invertible matrices form a group under multiplication, not a field, because they're not even closed under addition.
Likes dextercioby and topsquark
Really? They're not closed over addition? I can't think of an example where I don't have an additive inverse.
not the existence of an additive inverse, but closure under addition. Try Id + -Id ; Id the identity. Is it invertible, this sum of invertible matrices?
Likes topsquark
Just for nitpicking: they form a field in case ##R## is one and ##n=1.## 🤘
It is not pure nitpicking. The center of the full matrix ring over a field is the diagonal matrices with the same entry (Zassenhaus, IIRC). Hence, the field plays indeed a role beside the trivial case.
This means:
A set of matrices can be all of them:
  • additive group
  • multiplicative group
  • vector space
  • ring
  • module
  • algebra
  • division algebra
  • field
Whatever you like. A set of matrices can be everything. You need to be way more specific in your questions.
The usual process is the other way around. E.g. given a group ##G##, then find and classify all group homomorphisms ##G\longrightarrow GL(V)## for a vector space ##V.## The same question arises in all categories, not only groups. E.g. for a Lie algebra ##\mathfrak{g}## we are interested in all Lie algebra homomorphisms ##\mathfrak{g}\longrightarrow \mathfrak{gl}(V).##
The linear representations (matrices) are normally better understood than the original structure. They can therefore be used to gain information about that structure.
Likes topsquark
Okay, thank you for clarifying.
Likes WWGD
The other way around compared to what?
Likes topsquark
... to the mess in post #1.
Likes topsquark
WWGD said:
I don't understand how @topsquark comes into play here, but I think that @askmathquestions isn't really interested in learning a certain subject.
We always have to make guesses to make his questions answerable. E.g. you made the assumption that ...
... meant ...
WWGD said:
Yes, the set of all ## n \times n ## Matrices over a ring R are a ring, not a field ...
... in order to be able to give an answer.
  • Haha
  • Sad
Likes PeroK and topsquark
As it happens I could use a good source for that. :)
I know at least the basics but it's always good to have a good source to refer to.
-Dan
Likes WWGD and fresh_42
-Dan
Sorry :) , I mistook you for askmathquestions
Likes topsquark
I'm almost always interested in learning new subjects, why are you being elitist?
I'm not a born-rich mathematician who's had unlimited time and money their whole life, I don't have the background to know how to perfectly phrase every single detail of every possible conceivable single question, sorry for not being rich like you apparently. Even if you're not rich, you've certainly internalized the pervasive elitism that has persisted in mathematics for hundreds of years.
I only think that you must help us to help you. Your questions are all way too vague to answer. Hence we need a dialogue with you to specify your questions. There is unfortunately no shortcut to linear algebra. One has to start at the beginning.
Square matrices are closed under addition...
Wrong. Additive groups are closed under addition. Vector spaces consist of additive groups. Certain sets of matrices, square or not, are closed under addition. A matrix alone cannot be closed, a set of them can be.
... and their own form of multiplication, ...
Wrong. Some sets do, and others don't. It depends on the set. Cp. post #5 above.
Right. Multiplication of arbitrary square matrices is not commutative. A set of diagonal matrices is commutative. Diagonal matrices (over a field) commute.
What algebraic structure then describes this, ...
What is "this"? Lie algebras describe to some extent the degree of commutativity if it was that what you have asked. Every associative algebra ##\mathcal{A}## turns into a Lie algebra via the multiplication
[X,Y]:=XY-YX\text{ for all } X,Y\in \mathcal{A}
The result ##[X,Y]## is thus one way to describe the failure of commutativity. If we have multiplicative groups instead of associative algebras, then their central series would be appropriate to investigate.
... along with polynomials of matrices and allows us ...
What do polynomials of matrices allow? And again, which set of matrices? Which set of polynomials?
... to amend with other operations,...
Which other operations? There cannot be even an attempt to answer that. This is an invitation for an endless, and meaningless discussion.
... such as differentiation or integration ...
That would be multivariate calculus. A rather broad topic. Do you ask for a book?
... defined on these objects? Would the appropriate algebraic structure be a ring or a field?
You cannot talk about structures if it isn't even clear what the set of such a structure is.
A concatenation of mathematical terms does not make a valid question.
Likes topsquark
Wrong. Some sets do, and others don't. It depends on the set. Cp. post #5 above.Right. Multiplication of arbitrary square matrices is not commutative. A set of diagonal matrices is commutative. Diagonal matrices (over a field) commute.
Post #2 by WWGD answered the bulk of my inquiry in only a few sentences. Perhaps in all the time you've been buried under nothing but math, you've lost the basic social skills to communicate with laymen, also not uncommon in the world of math.
  • Skeptical
  • Sad
Likes topsquark, berkeman and PeroK
After moderator discussion, the thread has been reopened.
Likes topsquark
I am not. I try to understand. I basically asked in post #5 about details, you did not answer, I asked you privately per PM without an answer, so I tried a provocative statement:
This is clearly a personal opinion. It is my impression. Correct me if I'm wrong. It was by no means offensive. I didn't even say that you weren't willing to learn. I said I don't see a certain subject you are interested in. This was meant as a hidden question about which subject. Again, a provocation? Yes, but not an insult.
No, he did not. He made an assumption, namely that you would have meant all possible matrices over a ring, and then answered to that assumption. Without such guesses, he wouldn't have been able to give a qualified answer which he did, under his assumption. Without such a condition, we would be in the situation of post #5. You might have felt that he gave you an answer, but I doubt - again my personal opinion - that you understood what he wrote.
I still try to figure out how we could help you best - and, this is the strict requirement in all of our technical forums, without just talking on a fb level. Your questions are basically all substandard and I could - and probably would better - hide behind our rules and close the threads instead; anonymous and forcing you into a private dialogue. Instead, I tried to provoke you, after asking for explanations in vain. I apologize if that insulted you. It wasn't meant that way. It was an attempt to bring you to the table. You asked a lot about vectors and related topics. Now, we can neither replace a college course nor what is written already on Wikipedia, so we need to know how we can help. And, sorry to say this, but this begins with your substandard questions. All which I have seen required additional guesses before they could be answered. So we either have to give up our standards, or you be more specific in what and why you ask.
Likes topsquark
You are asking a math question in a math forum. It would be reasonable to expect "nothing but math".
Communication is a two way street, you don't have to reply to the people trying to help if you aren't happy with how they provide guidance. You are getting expert advice here for free, they are trying to help as best they can; it's the only reason they would respond. If you are too critical you may get what they owe you... nothing.
Likes PeterDonis and topsquark
Consider that you are asking a question about rings. Isn't it fair to assume that you have at least some knowledge of what a ring is? So why are you surprised that someone is responding to you with language based on ring theory? You should expect that! If you don't know the theory then you need to say that up front.
-Dan
Likes malawi_glenn
This is clearly a personal opinion. It is my impression. Correct me if I'm wrong. It was by no means offensive. I didn't even say that you weren't willing to learn. I said I don't see a certain subject you are interested in. This was meant as a hidden question about which subject. Again, a provocation? Yes, but not an insult.No, he did not. He made an assumption, namely that you would have meant all possible matrices over a ring, and then answered to that assumption. Without such guesses, he wouldn't have been able to give a qualified answer which he did, under his assumption. Without such a condition, we would be in the situation of post #5. You might have felt that he gave you an answer, but I doubt - again my personal opinion - that you understood what he wrote.
Instead of trying to "provoke" people which is clearly rude, you have a few options:
1 is, don't comment on a question you don't like, go do something else with your life
2 is be patient and understanding, work with the poster.
-Dan
I think that's irrelevant to trying to manipulating someone with provocations, though I agree it would be helpful to say that.
To provoke an answer wasn't my first choice. It was my last. You did not respond to direct questions.
Well, I have a third option: I will strictly apply our rules.
You're saying that as if you "had" or "needed" to do anything, even though I doubt anyone tried to force you to do anything.
This is a math forum. It is here to answer math questions. Can we all get back to the reason this page exists? Why are y'all arguing with people you don't know. Maybe we should shift all of this to an Argument Forum?
Seriously, what's the point? What will you actually win?
Do you still have questions about Rings, Fields, Invertible Matrices, Commutation, etc? If not, I'll suggest that we all agree that you are right, others are wrong. Then we can shut this drama down and get back to the physical sciences. Those that are still upset can move the fight to Twitter.
Likes topsquark and malawi_glenn
FAQ: Does a set of matrices form a ring? Or what is the algebraic structure?
What is a ring in algebraic structure?
A ring is a mathematical structure that consists of a set of elements and two binary operations, addition and multiplication. These operations follow certain rules, such as closure, associativity, and distributivity, and the set must contain a special element called the identity for each operation.
How do you determine if a set of matrices forms a ring?
In order for a set of matrices to form a ring, it must satisfy the following properties:
  • The set must be closed under matrix addition and multiplication.
  • Matrix addition must be associative and commutative.
  • Matrix multiplication must be associative and distributive over addition.
  • The set must contain a zero matrix that serves as the additive identity.
  • Each matrix must have a multiplicative inverse, except for the zero matrix.
Can a set of matrices form a ring if it does not contain a multiplicative identity?
No, a set of matrices cannot form a ring if it does not contain a multiplicative identity. The multiplicative identity is a necessary element for the ring structure, and without it, the set will not satisfy all the properties of a ring.
What is the difference between a ring and a field?
A field is a more specific type of ring that also has the property of multiplicative inverses for all non-zero elements. This means that every element in a field has a unique multiplicative inverse, while in a ring, only the non-zero elements have multiplicative inverses.
Can a set of matrices form a ring if it contains non-square matrices?
Yes, a set of matrices can form a ring even if it contains non-square matrices. The properties of a ring do not depend on the size or shape of the matrices, but rather on their operations and elements. As long as the set satisfies all the properties of a ring, it can be considered a ring regardless of the shape of the matrices.
