Does a signal called "EN" stand for something special in this circuit?
  • Thread starter Thread starter zenterix
    Electric circuit
zenterix
Write a boolean expression that describes the function of the circuit below.
My question is what does "EN" stand for in the circuit?
If it is simply a signal like A, B, and C then the function represented by this circuit is ##\bar{(AB+C)EN}##.
Perhaps "enable".
Likes hutchphd, BvU and berkeman
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
