Does a W on a transcript look bad?
  • Courses
  • Thread starter kregg34
In summary, dropping a class with a low exam average and a difficult professor may not look bad on a transcript, but it is not recommended to make it a habit. It is important to plan course schedules carefully, and having a few W's in the earlier years is more acceptable. However, it is not advisable to have multiple W's in the later years. Additionally, it is better to take a W than fail a course, but it is important to talk to the professor and see if there is any possibility of curving or addressing the low average. The professor should also take responsibility for the low average and address it properly.
kregg34
I am currently taking 5 classes, all 3rd year physics. Would it look bad on my transcript if I dropped one? The class average on the midterm was 7% and the prof said that the next midterm would be harder, many people got 0% on it. It is a mandatory class (Electromagnetism). Another prof is teaching the class next semester so I was thinking about retaking it then. My GPA is currently quite good (3.8 on 4.3 scale), but I have one other W from 2nd year. Do grad schools care about dropped classes if you have a good GPA?
No. But don't make it a habit.
Likes Dr. Courtney
That's an extremely low average for a midterm. It puts into question the abilities of the students, as well as the professor's skills at teaching. Maybe all of the students should drop the class...
What was the high score on this exam?
He said he wouldn't test certain things, but he tested them anyways. Also it was only 2 questions, if you didnt get the final answer 100% correct, you got 0 points. And one person got 55%, next highest 30%.
What you describe is mathematically impossible. (Given reasonable constraints like linear addition of scores, a top score of 100%, etc.)
Possibly yes, if the professor allows some partial credit, and only two questions on the test. This professor might be allowing for partial credit but is very stingy in issuing any.
kregg34, maybe you omitted some other details of the professor's grading? Some specified way to show the work? Failure to follow specified instructions? Some problem-solving formatting requirements?
Just an opinion, but having only two W's seems not so bad. Plan your semester schedules more carefully, and if necessary, drop a course before the deadline.
The second question had multiple parts.
A W is better than an F. It's worse than an A. It's better if it's for a subject you are clearly exploring and worse if it's a core class for your major.
W's aren't inherently bad, it's the story they tell that's important. If you're withdrawing every term, that's bad (are you lazy, bored, professor shopping, over estimating your abilities to handle reasonable course loads, etc?). If you have to withdraw from all your classes in one term due to work or an emergency (that can be 4~6 W's in some cases!), that's less bad (did their parents die, have to travel for work, etc)
It's also important when you're withdrawing. As a freshman/sophomore it's more reasonable to see a few W's as you "figure things out." In your junior/senior year it's no longer reasonable to see withdraws every term.
This is all just my speculation, and how I'd try to reason things out if I were in the business of looking at transcripts.
But by all means, if you're going to fail the course take the W. Talk to the professor, see if this is somehow normal and he curves at the end of the course. A W will look a whole lot better than an F. When I was younger and dumber I withdrew from a few courses to avoid a B. :frown:
Likes e.bar.goum
I cannot imagine a decent university class in any subject where the midterm scores are abysmal and the teacher does not address the class publicly about such an obvious concern. Also possible that if it were a small class, he might choose to address students individually. To leave it essentially unaddressed? That, to me, would be a warning sign of a bad teacher, independent of whether the students are up to the level of the material; and if so, "Get out now, fast."
Of course, we don't have all the information here, so can't judge whether there may be mitigating factors. @kregg34, did the teacher initiate discussion of midterm results not just as a dry announcement, but as a shared concern requiring proactive response - whether publicly in class, or privately w/ individuals, e.g. w/ you?
The professor should be more worried than you are. The entire class averaging ~30% or less shows a severe failing on his part. Even if it was just that he forgot to set the correct prerequisites for the course, he has essentially caused general confusion and time wastage for a lot of people. With so many people scoring badly, the blame quite obviously does not rest on the individuals themselves.
Anyway that W isn't all bad, since it could be an F...
I've just failed an exam in a subject I'm generally quite capable in (obviously not "full marks" capable - but capable) because 3 out of 5 questions were based on the one area I was cripplingly weak on. Meanwhile, vast swathes of the course were not questioned at all in the exam. Absolutely fuming to be honest. What kind of exam only examines a fraction of the info that was taught? The same goes for a lot of my courses actually. It seems to be a recurring theme on British STEM courses - too much info for one exam to cover. Sort of defeats the point of exams.
Sorry, needed a rant!
Curves are pretty much standard, even in a "decent university class." These scores aren't at all uncommon.
It doesn't mean any such thing. It means the class scored a 30% on what they were tested on. The professor may curve at the end of the course.
OP should voice concerns to professor and see what their options are.
I suppose, but it doesn't seem likely. What's the point in setting an exam with questions that students clearly aren't able to answer yet? Seems a complete and utter waste of time to me.
I agree with @sa1988, at least to some extent. One possibility of the entire class scoring an average of ~30% is that the teacher is ineffective. There are other possible causes, of course.
I can just about guarantee that if an instructor is not tenured, there will be people asking him or her why the class scored so low.
You're only adding to my point when you say the prof "may" curve at the end of the course. May? May not? Are students supposed to guess?
The OP's posts indicates a high degree of confusion on his part as to what is going on. Maybe we're lacking some necessary info, or maybe this is a misperception on the OP's part. But if he's right, there is a problem, because how a course will be graded is part of the expectations that a teacher (a good teacher) communicates to his/her students at the very start of a course. I know this because I've taught in a university setting (NYU) where this was part of the standard.
You're supposed to ask?
I'm going to assume you're serious here, rather than making a joke of some sort.
Should students be kept completely in the dark about grading unless they ask? Answer, no. I don't think so, and neither did the writing department at NYU that I worked for. I was an adjunct, so lowest on the totem pole; but I had to meet the same standards as profs & assistant profs in preparing materials and communicating with students. Every semester I drew up a syllabus; and every semester I communicated, as mandated by the department (which I fully agreed with), both the minimum requirements for getting a passing grade (e.g. percentage of classes attended), and my own standards for how I was going to grade the class. This information was also in my syllabus.
Students shouldn't have to ask how their participation & work will be graded any more than they should have to ask what the syllabus is. Any half-way decent teacher wants students to know what the expectations are, because aside from being fair, it makes it far easier to teach. So everyone gets a copy of the syllabus; everyone gets told how grading will be handled and why. They get told a lot of other helpful things too.
I'm in favor of good teaching practices. Your profile says you're an "Education Advisor", but I haven't gotten a sense so far of what you actually believe regarding teaching - including what you see as good practice for grading. Maybe you can briefly describe what you feel are the appropriate responsibilities for teacher as well as student? I'm also curious, if you're an education advisor, if that means you have taught, or if you look at it only from the student side?
As someone who has looked at transcripts (in an academic context for grad students. YYMV for industry) that's pretty much my attitude. The effect of W's depend on the course, number of W's and their timing.
Likes Student100
I do enjoy pulling peoples leg, but that's not what I'm doing here. If the student has questions or concerns about the course they should speak to the professor and voice them.
The only people in the dark are us. Maybe it was a mistake on the part of the professor they plan to fix. Maybe it was purposely challenging to prevent over confidence by the students. Maybe he plans to curve grades at the end and a 15 is really an A on this midterm. I don't know, and if the OP doesn't know he should ask.
Okay, I'm sure the OP had access to the same basic information, but that's just what a course syllabus is- basic information. Over the course things can change, or some intricacies of grading may not be fully covered; such as, "my exams are insane to challenege students to think beyond the material presented in the courses, intermixed with some things you should know. Passing grades are often in 30 percentiles." I've had courses like this in physics, so they exist. It wasn't actually stated anywhere, unless you asked the professor, but the university was known to curve in general.
This could be the case here, since the OP has access to the class average. To me that's a pretty good indication you're supposed to figure out where you stand from that.
Education advisor has nothing to do with teaching. I'm a student, the only thing I teach are recitation sessions were I end up doing peoples homework for them, more often than not.
There is no good standard practice for grading, and grades themselves are poor metrics of understanding. That said, it's the only real metric we have, flawed as it is. The teacher has a responsibility to communicate the material and adress any reasonable concerns from their students, students have a responsibility to learn whatever lesson the teacher is lecturing on and communicate any concerns or questions.
So ball is in OP course, before withdrawing they should speak to the professor.
Plus as V50 pointed out, OP comments aren't making much sense anyway. They should come back and clarify.
Edit: fixed semi-hilarious autocorrect.
Agree completely on both these points; I've tried to make clear in my comments that there could be other factors we're not hearing about. Indeed, that may be the most likely scenario.
My only caveat - which perhaps sounded as if I were sure it was the case, when I'm not - has been that in instances where a teacher is truly not being communicative about something as important as appropriateness of the enrolled students for the material, etc., then that would be a very bad sign. Part of the reason that scenario concerns me is that as a teacher myself, I once ran a course (last one I taught, ironically) where the enrollment was quite small - only 7 or 8 students - and only 1 student out of the group was a fit for the course description in the catalog & the curriculum as taught. That 1 student did great & benefited from my teaching; but I simply was not able to find a way to teach the other 6 or 7, and it ended up as an unhappy experience for me & for them. Frankly they should not have enrolled given the catalog description; but I was slower to react to the problem than usual for me, because it had never happened to me before that so many would make such a mistake. And also it was only a 6-session mini-course, so there was less time to react. It was a bizarre situation. Looking back, the right thing to do, once I realized the depth of the problem after perhaps the second class, would have been to let the students know, whether individually or as a group, so they could get refunds. In effect, cancel the course due to inappropriate enrollment. The one appropriate student would have lost out, of course.
I taught for something like 6 or 7 years (I'd have to go look up my CV), and every year there was a learning experience of one kind or another.
Student100 said:
Education advisor has nothing to do with teaching. I'm a student, the only thing I teach are articulation sessions were I end up doing peoples homework for them, more often than not.
I didn't mean you needed to have taught to be an education advisor; I can fully see the worth of someone helping out from the student point of view. I was just curious as to which POV you operate from when you're in that role. But I would say that if you ever do get the opportunity to teach, you may find it quite eye-opening.
FAQ: Does a W on a transcript look bad?
1. Does a W on a transcript affect my GPA?
No, a W (withdrawal) typically does not affect your GPA as it is not considered a grade. However, if a W is earned due to failing a course, it may affect your GPA.
2. Will a W on my transcript affect my chances of getting into graduate school?
It depends on the specific graduate school and their admissions criteria. Some schools may view a W as a lack of commitment or academic difficulty, while others may not consider it at all. It is best to research the policies of the graduate schools you are interested in.
3. Can I retake a course after receiving a W?
Yes, you can retake a course after receiving a W. However, the W will remain on your transcript and both attempts will be recorded. It is important to check with your school's policies on course retakes.
4. Can I remove a W from my transcript?
In most cases, a W cannot be removed from your transcript. However, some schools may allow you to petition to have a W removed if there were extenuating circumstances that caused you to withdraw from the course.
5. Will employers see a W on my transcript?
In most cases, employers will not see a W on your transcript. However, some employers may request a copy of your transcript and may see the W. It is important to be prepared to explain the reason for the W if asked by an employer.
