Does an electron's position collapse when measuring g factor?
In summary: It would seem as if they have no connection.In summary, the two experiments discussed in the provided links from the 1980s involved trapping electrons in a penning trap and measuring the ratio of the magnetic moment and angular momentum of the electron. It is unclear if the electron's positional wave function was collapsed during these experiments, as the position was largely unconstrained. The experiments also looked at the electron's zero-point state, where its position is uncertain. The magnetic moment was measured by using the strength of the electron's interaction with a magnetic field, and this information was used to calculate the size of the electron, although this connection is not clear. These experiments do not provide evidence for or against wave function
joegibs
47
https://link.springer.com/chapter/10.1007/978-3-540-39664-2_1
http://iopscience.iop.org/article/10.1088/0031-8949/1988/T22/016/pdf
In these two experiments done back in the 80's, electrons were trapped inside a penning trap for long periods of time. They were measuring the ratio of the magnetic moment and the angular momentum of the electron (the "g factor"). My question is, when measuring the magnetic moment and angular momentum, did they collapse the electron's positional wave function when doing it? Or was the positional wave function of the electron still uncertain/spread out?
It sounds as though they were doing cyclotron resonance and measuring resonant absorption of radiation. in that case, the position of the electron would be unimportant and hence largely unconstrained.
Also:
The classical notion of an atomic particle at rest in free space is discussed, and shown to be approximable by zero-point confinement of the particle in a laboratory trap.
If the electron was approximately at rest it implies the trap is large and again the position would be uncertain. In the zero-point state, the position is certainly not localised.
Likes joegibs
Also:If the electron was approximately at rest it implies the trap is large and again the position would be uncertain. In the zero-point state, the position is certainly not localised.
Is that the case in both of these experiments?
As far as I can see, the main topic in both the links you give is the same work, out of Seattle.
Oh ok. How does one measure the magnetic moment of the electron tho? And what is the magnetic moment?
In one way or another by measuring the strength of its interaction with a magnetic field. What is it you really want to know?
What do you mean?
You started by asking whether the electron was localised, and now you're asking about measuring magnetic moments. Is there a connection?
No just curious
Okay. An electron can take one of two states in a magnetic field; the energy difference between these states is proportional to the magnetic moment and the field. In one type of experiment, you get the electron in the lower state to absorb electromagnetic energy and flip to the upper state,. The frequency of the radiation absorbed is proportional to the energy difference of the two states, from which you can calculate the magnetic moment.
Oh ok. But how do they use the information about the magnetic moment to calculate the size of the electron in these two experiments? It would seem as if they have no connection.
This depends on which interpretation of QM you adopt. If you adopt a collapse interpretation like Copenhagen, then yes. If you adopt a no collapse interpretation like the MWI, then no.
If you are asking whether these experiments providea actual evidence that wave function collapse happens, independent of QM interpretation, the answer is no. The results of these experiments can be explained using standard QM (indeed, I believe the papers you linked to do that), which is compatible with both collapse and no collapse interpretations.
I think that's to do with quantum electrodynamics--relativistic quantum theory--which I don't claim to understand, but it seems there are subtle effects on the energies involved if the electron has a finite size. (This is not the same as talking about uncertainties in its position--different experiments measure different things; in some the electron is spread out like a wave in others it behaves more like a particle.)
In these experiments, were they just determining the size of internal structure (if there is one)? In that case, the wave function would've never collapse regardless of which interpretation you take. Since all interpretations hold that the internal structure is zero
Peter Donis is better equipped to answer this than I am, but I'll offer my thoughts. As I understand it, "collapse of the wavefunction" doesn't refer to the wavefunction somehow shrinking in physical space so that a particle becomes located at point. It means that the quantum mechanical description of the particle has become less ambiguous (as simple as possible, roughly speaking). Before the "collapse" occurs a particle or other system is in an indefinite state, called a superposition, made up of all possible states. In the case of an electron spin, for any given direction it can be pointing in the same direction or the opposite. The collapse means that the system has entered a single one of the possible states. This description requires that the states have distinct quantum numbe; in many cases identifying the final "collapsed" state and its quantum number still leaves other quantities imprecise: the Seattle authors talk about an electron in its zero-point state. This is an energy state with quantum number zero; it means the energy is precise, but other quantities such as position are still described by distributions. Position in space is not quantised (in conventional quantum mechanics), so there are no pure states corresponding to a particular location of a particle.
The question of the size or internal structure of the electron is a prediction of theories, but the aim of experimental science is to test theories.
Likes Mentz114
More or less, yes. A more technical (and precise) statement would be that collapse means the wave function changes from a superposition of eigenstates of the observable being measured, to one of those eigenstates. If position is being measured, the collapse would be to a position eigenstate. But if some other observable is being measured, the collapse (on a collapse interpretation) would be to an eigenstate of that observable; and the resulting spread in position of the particle's state would depend on the eigenstate that it ended up in (more precisely, on its position representation).
(Strictly speaking, position eigenstates--Dirac delta functions--are not valid states, because they are not normalizable. So an even more precise statement would be that the observable actually being measured when we say we are measuring "position" is not the position operator as it is usually given in idealized QM, but an operator whose eigenstates are something like Gaussians with a narrow spread in position--how narrow depends on the accuracy of the measuring device.)
A superposition does not have to contain "all possible states". Which states it contains will depend on how the particle was prepared prior to measurement.
I don't think any of the models being used to analyze these experiments attribute any internal structure to the electron; they all use the standard QM assumption that the electron (like all other fundamental particles) is a point particle. Heuristically, I would say that the measurements being made were to try and determine the spatial "spread" of the electron's wave function--the size of the region of space in which the amplitude, in the position representation, was significantly different from zero.
Related to Does an electron's position collapse when measuring g factor?
1. What is an electron's position collapse?
An electron's position collapse refers to the phenomenon observed in quantum mechanics where the position of an electron becomes definite at the moment it is observed or measured.
2. What is the g factor of an electron?
The g factor, also known as the electron spin g-factor, is a dimensionless quantity that describes the strength of an electron's magnetic moment in a magnetic field. It is a fundamental property of electrons and is used to explain various physical phenomena.
3. What does measuring the g factor of an electron involve?
Measuring the g factor of an electron involves applying a magnetic field and observing the energy levels of the electron. This can be done through various techniques, such as electron spin resonance or nuclear magnetic resonance.
4. Does the electron's position always collapse during g factor measurement?
Yes, the electron's position always collapses during g factor measurement. This is because the act of measuring the g factor involves observing the electron's position, which causes the collapse of its wavefunction.
5. What are the implications of an electron's position collapse in g factor measurement?
The collapse of an electron's position during g factor measurement has significant implications in quantum mechanics. It demonstrates the probabilistic nature of the behavior of particles at the atomic and subatomic level and challenges our classical understanding of cause and effect.
  • Quantum Physics
  • Quantum Interpretations and Foundations
