Does an object moving in a geodesic accelerate?
In summary: So coordinate acceleration will change when you use Newtonian gravity or general relativistic theory.
Lunct
133
So in GR, objects orbiting the sun, for example, move in a geodesic - a straight line something curved. Without GR (using Newtonian Gravity), I can easily say because planets orbiting the sun are doing so in a ellipse, they are accelerating. However, would they still be accelerating when you add in GR and they move in a straight line on curved spacetime?
Let's assume for sake of simplicity that these planets are moving at a constant speed, although I believe in reality they are not.
A geodesic is a curve whose acceleration is zero.
so they don't accelerate?
Geodesics really aren't my strong point.
You have to carefully distinguish two different meanings of the term "acceleration".
The first meaning, which is the one GR uses, is "proper acceleration"--what you measure with an accelerometer. Objects moving on geodesics of spacetime, in GR, have zero proper acceleration; that's what @martinbn is saying, in more precise terminology. That is true whether spacetime is flat or curved; and these geodesics are the closest things to "straight lines" that exist in spacetime.
The second meaning, which you seem to be implicitly using, is "coordinate acceleration"--the second derivative of position with respect to time. It is called coordinate acceleration because any time you use it, you are, whether you realize it or not, choosing some particular system of coordinates. (Note that you do not have to choose any coordinates to define or measure proper acceleration; that is an invariant property of a curve, independent of coordinates.) When you say planets orbiting the Sun are accelerating, you are implicitly adopting coordinates in which the Sun is at rest. But you could also adopt, for example, coordinates in which the Earth is at rest, and in these coordinates the Earth is not accelerating (in the coordinate sense), while the Sun is. (Note that these coordinates are not just theoretical; astronomers use them all the time, when they locate objects, including the Sun, by their distance from Earth and their angular position on the sky.) But regardless of your choice of coordinates, the Earth has zero proper acceleration and is moving on a geodesic of spacetime. (So is the Sun, for that matter.)
Likes martinbn, Dale and Lunct
does that mean that coordinate acceleration changes when you use Newton Gravity or GR.
Coordinate acceleration will depend on what coordinates you use. Nothing stops you from using Newtonian gravity with freely falling coordinates. Well, nothing, except the fact that a flat coordinate system will only transform gravity away locally and you'll run off the edge eventually.
Nothing stops you from using GR with non-inertial coordinates.
Coordinate acceleration doesn't depend on what theory you use; it only depends on what coordinates you choose.
Related to Does an object moving in a geodesic accelerate?
1. What is a geodesic and how does it relate to an object's motion?
A geodesic is the shortest path between two points on a curved surface. In the case of an object moving in a geodesic, its motion is following the shortest path possible on the curved surface it is traveling on.
2. Does an object moving in a geodesic always accelerate?
No, an object moving in a geodesic does not always accelerate. If the geodesic is a straight line, the object will maintain a constant speed and not accelerate. However, if the geodesic is curved, the object will experience acceleration due to the change in direction of its motion.
3. How is acceleration related to an object's motion in a geodesic?
Acceleration is a measure of how much an object's motion is changing. In the case of an object moving in a geodesic, the object's direction of motion is constantly changing, causing it to experience acceleration.
4. Can an object moving in a geodesic accelerate without a force acting on it?
Yes, an object can accelerate in a geodesic without a force acting on it. This is because the object's motion in a geodesic is determined by the curvature of the surface it is traveling on, not by any external forces.
5. How does an object's mass affect its acceleration in a geodesic?
An object's mass does not affect its acceleration in a geodesic. In the absence of external forces, all objects will accelerate at the same rate in a geodesic, regardless of their mass. This is known as the principle of equivalence in Einstein's theory of general relativity.
