Does atmospheric pressure affect the saturated vapor pressure ?
In summary, the Clausius-Clapeyron equation is derived assuming only gaseous water above the liquid, neglecting the effects of other atmospheric gases. However, in common settings, atmospheric gases exert a higher pressure on the liquid surface, potentially affecting the saturation vapor pressure. This pressure correction may be small due to the low atmospheric pressure, but the non-ideal nature of gases and the presence of dust particles may also play a role. Additionally, for solid-liquid equilibrium, the "p" in the C-C equation refers to total liquid pressure, while for liquid-gas equilibrium, it refers to partial pressure of the vapor.
Jano L.
75
When the Clausius-Clapeyron equation for saturation vapor pressure over liquid water is derived via the Carnot cycle, it is usually assumed that there is only gaseous water above the liquid. The other atmospheric gases are neglected.
However, in common settings (lake, glass of water...), the atmospheric gases exert much higher pressure on the liquid surface than the water vapor. Does this large pressure affect the saturation vapor pressure somehow? I guess that the correction is small, perhaps since the additional atmospheric pressure is too low to change the volume of liquid water significantly...
For ideal gases, I think there should be no change.
Gases are not ideal, of course - they need some volume (reducing the volume available for water a bit), they have some interaction (I guess this gives a bit more water, but I don't know). In real air, you also have dust particles and so on.
Yes, that is similar to what I was thinking.
On the other hand, when applied to solid-liquid equilibrium, the "p" in the C-C equation refers to total liquid pressure. It is a bit strange that for liquid-gas equilibrium, the "p" in the C-C equation refers to partial pressure of the vapor, not to the total liquid pressure.
Related to Does atmospheric pressure affect the saturated vapor pressure ?
1. How does atmospheric pressure affect the saturated vapor pressure?
Atmospheric pressure and saturated vapor pressure have an inverse relationship. This means that as atmospheric pressure increases, the saturated vapor pressure decreases, and vice versa. This is due to the fact that at higher pressures, molecules are more tightly packed together, making it more difficult for them to escape into the gas phase.
2. What is the significance of saturated vapor pressure?
Saturated vapor pressure is the pressure at which a liquid and its vapor are in equilibrium. This is important because it determines the rate of evaporation and condensation of a substance. It also affects the boiling point of a liquid as the higher the saturated vapor pressure, the lower the boiling point.
3. How is atmospheric pressure related to weather?
Atmospheric pressure plays a crucial role in weather patterns. Changes in atmospheric pressure can indicate the movement of air masses, which can lead to changes in temperature, humidity, and precipitation. Low atmospheric pressure is often associated with stormy weather, while high atmospheric pressure typically brings clear skies and fair weather.
4. Can atmospheric pressure affect the boiling point of water?
Yes, atmospheric pressure can affect the boiling point of water. At sea level, water boils at 100 degrees Celsius. However, at higher elevations where atmospheric pressure is lower, the boiling point of water decreases. This is because the lower atmospheric pressure allows water molecules to escape into the gas phase more easily, resulting in a lower boiling point.
5. How does atmospheric pressure impact living organisms?
Atmospheric pressure is an important factor for living organisms. Changes in atmospheric pressure can affect the amount of oxygen available for breathing, as well as the functioning of the respiratory and circulatory systems. Extreme changes in atmospheric pressure can also lead to altitude sickness in humans and can affect the behavior of animals.
9K
16K
