Does B=0 at points out of the plane containing and normal to a point current I?
In summary, the magnetic field \( B \) produced by a point current \( I \) is zero at points that are located outside the plane containing the current and normal to it. This occurs because the contributions to the magnetic field from the current at equal distances in opposite directions cancel each other out, resulting in no net magnetic field in those locations.
Trollfaz
141
Consider a point current I flowing at origin in the positive z direction. Biot Savart Law states that B field must move in an anticlockwise circle everywhere with the infinite line that the direction vector of the current, in this case the z axis, at the center. And its strength must be equal at all points as long as ##\triangle r## is equal.
Now using Ampere's law
$$\int_{C}B.dl=\frac{I_{enc}}{\mu_0}$$
Means for a circle of radius r,
##2πrB=\frac{I}{\mu_0}## in xy plane
##2πrB=0## else as no current enclosed by circle.
So does this mean there's no magnetic field outside xy plane
What do you mean by ”point current”? A current existing only at one point? There is no such thing as it would violate conservation of charge implied by Maxwell’s equations.
Likes Vanadium 50
Then for a semi infinite wire starting from z=0 carrying current I in the positive z direction. By Ampere's law, B is 0 if z<0 as a circle encloses no current but clearly it's not.
A semi infinite wire also violates current conservation. You need to stop making up unphysical scenarios. They all suffer from the same basic flaw.
Likes vanhees71
There are many circles you can draw centred on the origin.
Imagine the current at the origin was in a very short dipole.
You can expect a dipole far-field radiation pattern, which is only zero in the directions of ±z .
This is not what the OP has in mind. They are imagining a static one-directional current in the origin only, which is unphysical.
In the case of a dipole there is no loop containing any current outside the dipole so all circulation integrals of the magnetic field are zero. For the OP it should be noted that this does not mean that the field is zero. The circulation integral equalling zero is not in itself a sufficient condition to conclude that the field is zero along the closed curve.
Likes vanhees71
Do you claim to be a better mind reader than me?
The B field at any point in 3D is the sum of the B field generated by every dz of an infinite wire along the z axis. I am considering only the element dz at the origin.
If you read OP’s other threads you would see where they are coming from and the type of questions being asked at the moment.
This is not what OP is talking about. They are talking about applying Ampere’s law to find the total magnetic field with a current at the origin only:
∫CB.dl=Iencμ0
2πrB=Iμ0 in xy plane
2πrB=0 else as no current enclosed by circle.
I guess you mean a current along an infinitely thin wire. Then the correct form of
This is utterly misleading, because using the Biot-Savart law only for a finite (or infinitesimal) piece of wire cannot lead to a solution of the (magnetostatic) Maxwell equations, because these can only be solved is ##\vec{\nabla} \cdot \vec{j}=0## everywhere. So for a filamental current you have to integrate along a closed loop or in the (somewhat artificial) limit along an infinite wire and close the loop at infinity.
Likes Orodruin
FAQ: Does B=0 at points out of the plane containing and normal to a point current I?
What is the significance of B in the context of a current-carrying conductor?
B represents the magnetic field generated by the current I flowing through the conductor. The magnetic field is a vector field that exerts a force on moving charges and magnetic dipoles.
How is the magnetic field B oriented with respect to the plane containing the current I?
According to the right-hand rule, the magnetic field B forms concentric circles around the current-carrying conductor. If you point the thumb of your right hand in the direction of the current I, your fingers curl in the direction of the magnetic field lines.
Does B equal zero at points out of the plane containing and normal to the point current I?
No, B does not equal zero at points out of the plane containing and normal to the point current I. The magnetic field extends in three dimensions and its strength depends on the distance from the current-carrying conductor and the configuration of the current.
How can the magnetic field B be calculated at a point out of the plane of the current I?
The magnetic field B at a point out of the plane of the current I can be calculated using the Biot-Savart Law or Ampère's Law, depending on the symmetry of the problem. For a straight, long conductor, the Biot-Savart Law provides an integral form to calculate the magnetic field at any point in space.
What factors influence the magnitude of the magnetic field B generated by a current I?
The magnitude of the magnetic field B generated by a current I is influenced by the amount of current, the distance from the current-carrying conductor, and the configuration of the conductor (whether it is straight, looped, or coiled). The permeability of the medium surrounding the conductor also affects the magnetic field strength.
