kay
- 60
- 2
And what are the conditions for resonance to take place?
kay said:And what are the conditions for resonance to take place?
And what about CH3NO2?Quantum Defect said:Resonance ususally refers to the ability to draw more than one Lewis structure for a given connectivity of a molecule. It involves the sharing of multiple bonds in different ways within the framework. In the case of H3C-NH2, you have filled valence of C and N and all of the H-es, all with single bonds. The only way to draw any kind of resonance structure for this molecule would be to include some double-bonding from the lone pair of the Nitrogen to the Carbon, but this would give you pentavalent C, which is a no-no in Lewis Structures.
kay said:And what about CH3NO2?
Quantum Defect said:For H3C-NO2, there is resonance in the -NO2 group, but you can't make C pentavalent. On the N, there is a formal charge of +1 and a formal charge of -1 on one of the oxygens.
For the picture that you show: H2CCHNO2, there are more resonance structures possible, but one of these will not be particularly important.
e.g. H2C-CH=NO2 [Each N-O bond is a single bond]
This Lewis Structure has +1 formal charges on the end Carbon, and the Nitrogen, and -1 formal charge on each of the oxygens. Separation of many, many charges like this is something that is difficult to do -- i.e. you would need to do work to separate the many charges, so chemists would say that this is a high-energy isomer, and does not contribute much to the true picture of what the real molecule looks like. For example, the charge density on the end carbon is probably pretty close to what you would expect for a neutral carbon, and the terminal C-C bond is probably closer to what you would expect for a double bond, than a single bond as drawn above.
kay said:So I can always assume that whenever a resonance structure has a pentavalent carbon, it doesn't exist?
Yes, CH3NH2 (methylamine) can have resonance structures due to the presence of a lone pair of electrons on the nitrogen atom.
The presence of a lone pair of electrons on the nitrogen atom in CH3NH2 allows for the delocalization of electrons, leading to the formation of resonance structures.
Yes, the resonance structures of CH3NH2 can be drawn by moving the lone pair of electrons from the nitrogen atom to the adjacent carbon atom, resulting in a double bond between the carbon and nitrogen atoms.
Resonance in CH3NH2 helps to stabilize the molecule by distributing the negative charge of the lone pair of electrons among different atoms, making it more stable than a single Lewis structure would suggest.
Yes, CH3NH2 has a hybrid structure that is a combination of all its possible resonance structures. This hybrid structure is a more accurate representation of the molecule's electronic structure.
