Does climate change affect air density at altitude (scale height)?
The discussion centers on the impact of global temperature increases on atmospheric conditions, particularly regarding the tree line and habitability. A specific focus is on how a slight increase in temperature could affect the scale height of the atmosphere, potentially raising it from 8 km to 8.16 km. The conversation also touches on the implications of rising ocean volumes, which could further influence atmospheric height, while noting that warmer sea levels lead to lower air density. The dissolution of gases in oceans at varying temperatures and pH levels is highlighted as a complicating factor. A journal article is referenced that explores these dynamics in relation to aviation, providing equations for calculating pressure and density at different altitudes. The discussion includes a breakdown of these equations, emphasizing the relationships between standard pressure, altimeter settings, airport elevation, and temperature, ultimately aiming to clarify how these factors interact in climate computations.
Mike S.
TL;DR Summary
Assume a "worst" case scenario of 6 C global warming. Will the air pressure at high altitudes increase significantly due to a change in scale height of the atmosphere and other factors?
Increases in global temperature change affect the tree line and presumably comfortable habitability via temperature, and average air pressure associated with weather patterns. That's not what I mean. I'm thinking a 1/50 increase in kelvin temperature might increase the scale height of Earth's atmosphere by a comparable factor - from, say, 8 km to 8.16 km. Increases in the volume of the oceans should also push up the atmosphere from below. However, the density of air molecules starts off less because it's hotter at sea level. Then there's the wild card of how much of each gas dissolves into the oceans at different temperatures and pH levels. Has anyone worked through all the angles to determine the net effect on the average of all air density at any given altitude above the geoid?
Thanks! The equations given in that source are simple but the semantics are unfamiliar to me, so I'll break them down as I go along.
The simplified approximation is:
PA = (P0 - PAltSet) * 1000 + HAirport
DA = PA + 120 (T - Ts)
P0 is "standard pressure" in inHg, which I would *assume* is 29.92 inHg
PAltSet is an "altimeter setting" in inHg ( a pressure reading from a fixed station at the ground read over the radio to the plane, or in this case, just measured at the airport we're talking about, but apparently representing the hypothetical pressure at sea level given current weather conditions)
HAirport is the elevation of the airport in feet
T = Temperature in C, at the airport in this case
Ts = "standard temperature" in C, and Ts = T0 - 0.002 * HAirport. I might *imagine* T0 is 0 or 25, wait no, 15 C?
Reverse engineering their example from Denver, where H = 4226 ft and DA = "roughly" 6350 ft when T = 25 C and PAltSet = 30.01 inHg, I get PA = 4136 ft, Ts = 6.548, and the 120(T-Ts) is 2214, so that adds up. To rephrase these in equations where I'm not guessing random temperature and pressure adding feet and inches of mercury...
PA = (29.92 inHg - PAltSet) * (1000 ft/inHg) + HAirport
DA = PA + (120 ft/C)* (T + 0.002 C/ft * HAirport - 15 C)
DA = PA + (120 ft/C) * T + 0.24 * HAirport - 1800 ft
Combined,
DA = (29.92 inHg - PAltSet) * (1000 ft/inHg) + (120 ft/C) * T + 1.24 * HAirport - 1800 ft
With the units in place, it looks like the ft/inHg and ft/C may both be at issue in climate computations, but at least I've gotten this far. :)
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
We have little shade but plenty of wind on my property. The upshot of this is that I have to be judicious in how/where I put up shade-creating barriers in various places around my property to maximise shade without unduly large windage. My property is an irregular polygon and not aligned with the cardinal axes, so it is not easy to tell where the shade will be at a given time. For example, I have put up an umbrella next to our pool, but it can only shade the southish-side of the pool, and...
Recently, there were stories of hikers and trekkers caught in blizzards and snow storms in the region around Mt Everest. None were on the mountain, but rather is valleys around the mountain. My curiosity lead me to some interesting stories about what happened recently, and generally about the weather and its impact of those visiting the region and those attempting to summit. What the Heck Is Going On with the Mount Everest Blizzard Rescue...
