Does consciousness cause Wave-Function collapse?
In summary, there is no consensus on the solution to the measurement problem of Quantum Mechanics. The idea that consciousness causes the collapse of the wave function is not widely accepted and there are other explanations. The wave function collapse occurs regardless of the presence of a conscious observer. In Copenhagen, Bohmian Mechanics, and Many-Worlds interpretations, consciousness may have a role in the collapse, but this is debatable. MWI is not based on observer selection, but rather on the concept of multiple worlds. Science is about discovering truth through experiments, and although the idea of consciousness causing collapse may seem silly, it cannot be ruled out until proven otherwise.
HiggsBoson1
I was wondering if consciousness really causes the wave-function to collapse, and if this is the reason why our behavior is not erratic. Thanks!
There is, as far as I am aware, no consensus of the solution to the measurement problem of Quantum Mechanics. So consciousness may cause collapse of the wave function, or it may not.
Likes davidbenari
Consciousness causing the wave-function to collapse isn't a very popular idea these days and there are alternative explanations, though as far as I know there isn't any evidence that it is involved or if it isn't.
The wave function collapse happens regardless of whether a human or any conscious being is present, all that is needed is something does an observation.
Imagine a scenario where a QM experiment is done, and the result is recorded by machines and stored as a data file.
Let 100 years pass then distribute copies of the file to a million people.
They will all see the same thing
Is there any interpretation in which consciousness is not somehow involved in wave function collapse?
Edit: I guess collapse is real in GRW and CSL. But couldn't it be said that consciousness is involved in wave function collapse in Copenhagen, Bohmian Mechanics and Many-Worlds?
That doesn't disprove consciousness causing collapse.
I'm not really sure. I agree with your comments about GRW etc.
But it does prove that the outcome isn't dependent on a human being there when the experiment took place,
and also what I consider to be the most ridiculous variation on that theme-
which is that different (human) observers being present at the time the experiment was done might produce different results.
It's pop-sci stuff, I know that, but still many seem to believe that's the idea.
CI is deliberately agnostic.
BM has no observer role.
MWI has observer selection. Don't try this at home, but see quantum suicide.
MWI has nothing to do with 'observer selection'. Given the mixed state ∑pi |bi><bi| after decoherence, which is observer independent, each |b><bi| is interpreted as a world and everything just keeps on evolving.
Thanks
Bill
But there is no perfect decoherence, so there is no after decoherence. In Wallace's accounts he tends to refer to some sort of coarse-graining. So this seems to assume that there is an observer who is doing the coarse-graining? Or to put it another way, each observer within MWI can use Copenhagen, including collapse. So to derive that, do we need an observer?
This isn't a particularly quantum argument, since BM and MWI are essentially classical in ontology. For example, to derive Newtonian mechanics as a good approximation to GR, do we need an observer in order to define a "good approximation"?
rootone said:
But it does prove that the outcome isn't dependent on a human being there when the experiment took place, and also what I consider to be the most ridiculous variation on that theme- which is that different (human) observers being present at the time the experiment was done might produce different results. It's pop-sci stuff, I know that, but still many seem to believe that's the idea.
This conciousness causes collapse stuff is, IMHO, silly in the extreme. It faces severe problems. But they can be overcome - a coherent (but very very weird) view of the world can be formed.
Here we face what science is about. Science is about TRUTH. But truth discovered by correspondence with experiment. Experiment is always the final arbiter. It just may be that one day we can prove that conciousness causes collapse. It can't be ruled out.
Its like solipsism - nearly everyone rejects it as being silly - which it is - I certainly laughed my head of when I heard about it and thought how could anyone be gullible enough to believe such obvious rot. But science, correctly, has a different standard - rot it may be - but if experiment shows it is true rot we must accept it. Isaac Asimov expressed it this way. Religious cults, like for example Scientology, say 2+2 = 5 and make no mistake about it, science says almost certainly 2+2 = 4, but we need constantly to check it.
You will find once you integrate this into your world view many things become a lot clearer including the shenanigans of politicians - but that is for you to discover.
Thanks
Bill
Of course there isn't. But it makes no difference because in all situations in practice it is below detectability very very quickly. You can't ever detect those other worlds. It is generally thought detectability in this case is inherent ie is not technologically dependant ie is way below any level of current or future technology's ability to detect - but one never knows does one - that is the very essence of science.
Now if you want to attack MW I think the quantum eraser experiment may prove difficult to handle - what happens to those worlds when decoherence is unscrambled? I don't know the answer to that one in that interpretation - I will leave it up to those expert in it.
Thanks
Bill
I wasn't trying to attack MWI. I'm mainly trying to understand Zurek's statement in http://arxiv.org/abs/1412.5206: "Quantum Darwinism shows why only such redundantly recorded pointer states are accessible to observers|it can account for perception of `quantum jumps'. However, full account of collapse involves `consciousness', and may have go beyond just mathematics or physics. "
Although he mentions collapse, I think he is operating within his "existential interpretation", which as far as I can tell is a version of MWI, and he is trying to explain why although there is no collapse in the full interpretation, individual observers experience or use collapse.
Thanks
Bill
Which of those worlds you find yourself in is subject to an observation selection effect under the MWI.
Thanks
Bill
Quantum erasers present no problem for the MWI since, as you already pointed out, the split into different worlds occurs at decoherence.
Nope - its subject to the Born rule which MW adherents think can be derived from decision theory. I have gone though it from Wallice's book and believe there is a tacit assumption of basis independence which is the assumption of Gleason.
Just as background for others an observation selection effect is a concept from statistics that say you want to survey spending habits and you drop of a questionnaire to households in English. You have prior selected only those that can read and write in English. In MW there is noting analogous to that - the world the outcome occurs in is determined by the Born rule - you being there or not has nothing to do with it.
Thanks
Bill
Thanks
Bill
The Born rule of course applies, to outcome prediction. However testing predictions is subject to observation selection bias. Ignoring it leads to invalid conclusions.
Thanks
Bill
The example of 2+2=4 vs 2+2=5 is not a very good example, because such can be resolved by reference to the definition of what those employed terms mean. There's no need to perform any check on 2+2=4 (or 2+2=5) because one is so by definition, and the other is not. In other words, the definition rules out, in advance, any counter-proposition (and any need to perform any check). Certainly we can arrange 2 pairs of apples on a table, and count them up, but do we really need to do that? For it wouldn't be any different if we'd used oranges, or pears. We otherwise risk suggesting there might be a difference were different fruit used in such a check. But we already know there wouldn't be, because 2+2=4 does not depend on any fruit in the first place. Mathematics can be elaborated without any need to check anything outside mathematical errors.
Rather, what we mean by checking something in science is a lot more involved than simply checking for simple mathematical errors (or not so simple in many cases) but checking to what extent a particular mathematical expression models an observation. If it's a mathematical model (as most are) it will already be internally consistent (because otherwise it wouldn't be a mathematical model) but it may not be externally consistent. For example, Newton's mathematical model of gravity is internally consistent (without any mathematical error), but that doesn't guarantee (as we subsequently discovered) that it was entirely consistent with observations of gravity. The model turned out to be an approximation (even if an extremely good one).
Certainly we need to check models against internal inconsistencies, but the more important task (and not so easily done by thought alone) is checking what models claim in relation to observations. Some models, of course, don't make any claim in relation to any observations so they only need to be checked for consistency.
On a point of order, I have no interest in Scientology (or any other religion), but do Scientologists really say that 2+2 = 5? Or is that more of a metaphorical claim?C
What did the string theorist say to her husband when he caught her with another man?
"Wait", she said, "I can explain everything".
It doesn't matter whether consciousness causes the wave function to collapse or not in order to answer the second question. By continuously observing an object, the object's behaviour can be frozen or erratic. Obviously in everyday life, things are not frozen and things are not hugely erratic. So the answer is that by picking the right observable in the formalism of continuous observation, quantum mechanics is, at least heuristically, to reproduce the classical world we see. This emergence of classical dynamics as a good approximation has been worked out in a few cases, eg. http://arxiv.org/abs/quant-ph/0211036, http://arxiv.org/abs/1104.0820.
Regarding consciousness causing wave function collapse - this assumes, apart from anything else, that wave functions undergo collapse. When "wave function collapse" was first proposed it wasn't proposed as some sort of scientific theory, but as a kind of interpretational crutch that one could lean on, until one better understood the underlying logic. I don't recall who, but in the early conferences someone voiced an objection to the concept of collapse - the response to which was that if they were understanding the theory in the first place they wouldn't need such a crutch (and therefore wouldn't be complaining about such).
Nevertheless, ever since, this crutch has been recast as some sort of "problem" in search of a solution, one of which is the idea of consciousness causing such. But in any case let's assume "collapse" does occur (or the term "collapse" otherwise refers to that which does occur) well it should be obvious that it doesn't require consciousness insofar as a photographic plate can register such collapses without having any consciousness. Unless, of course, we assign consciousness to a photographic plate (and why not I guess).
More relevant is the question as to what such a theory (for want of a better description) might tells us. And in short it doesn't tell us much of anything at all. Even if consciousness did cause collapse (and photographic plates were examples of consciousness) in what way could we exploit such a theory? The answer to that question will tell us if we're moving closer towards understanding the physics or moving further away instead - into some other disciplinary bracket. As far as I can tell, it moves us into theories of consciousness rather than theories of physics.
A more difficult question is how to understand the model without such a crutch. I'm not sure I do. I still need the crutch from time to time. But I'm happy enough using it - it works for me.
One thing I know is that the issue of individual particle detections doesn't play a very big role in most situations. A wave function can be used to describe the "truth" behind an observation but it can also be used to describe an observation without requiring a collapse of the wave function. For example, it can be used to describe the distribution (or density) of particle detections in an experiment. While it can't describe any particular detection (in terms of it's exact position in space on the photographic plate) it turns out this is not a severe short coming. The aggregate pattern is not a function of individual detections but a function of the function so to speak. The impertinence of each particle, in assuming a position it couldn't possibly assume, is tempered by their sheer undying conformity to the square of the wave function (or wave functions plural as Bohr would prefer). This more than makes up for any madness any detection on it's own might inspire.
C
C
It is the lack of any evidence for any mechanism for wavefunction collapse that leads to the MWI. If such a mechanism did exist then there would be no need for the MWI.
The CI was unable to find a definition of an observer, conscious or otherwise, to collapse the wavefunction. The simplest solution, to me at least, is that no such collapse actually takes place.
Since the QM formalism doesn't have wave-function collapse that can't be its reason. Its simply one way to resolve the measurement problem which with our modern understanding of decoherence has morphed somewhat - now its why do we get any outcomes at all. That's utterly trivial in MW.
Thanks
Bill
I don't understand what is necessary to test a theory has to do with the theory itself.
Thanks
Bill
Well, if you believe in collapse (I don't, as is well known in this forum), and if you believe that consciousness causes the collapse, I conclude that a Silicon chip, a cloud chamber, Geiger counters, etc. have consciousness. I've never thought that the experimentalists are clever enough to build conscious beings, but maybe I'm wrong ;-)).
BTW: April Fool's Day is over, but maybe the question was even meant seriously?
Likes bhobba
I have a letter accepted for publication in Physics Today pointing out that Zurek's argument, commonly referred to as 'Quantum Darwinism', is circular. MWI based only on 'decoherence' does not gain a classical splitting basis unless it is put in by hand at the beginning. (See http://arxiv.org/abs/1412.7950 and http://arxiv.org/abs/1406.4126 )
Thus the classical world of experience is not successfully explained in MWI. Publication of my letter, as well as another reply from someone else to Zurek's article, is currently being held up pending a reply from Zurek. At this time, I do not know when (or if) that will happen, since he has not replied to any of his critics in the literature (that I know of) to date.
Also, it's certainly not necessary to appeal to 'consciousness' for wave function collapse. (I discuss this in my new book, as well as in my 2012 CUP book.)
... Is it "any interaction" that causes the wave to collapse or just particular to observer in a crude way?
Thanks
Bill
It's not so much of a test of a theory as noting that the theory leads to results that that depend upon the state of the observer. It wouldn't be of any interest were it not for the fact that it his highly unusual.
There is only one other discipline where such an observer effect is so notable, that I am aware of, and that is the field of psychoanalysis. It's no coincidence that it also uses the term, entanglement.
Seriously, it's not even clear that there is something like a collapse in nature. I'm a follower of the minimal statistical interpretation, and there's no collapse necessary, which avoids a lot of problems with Einstein causality etc. For me "Collapse" is just a word for adjusting the state after the interaction of the system under consideration with a preparation apparatus in the sense of an ideal von Neumann "filter measurement". However, such preparation procedures can be understood from quantum dynamics alone. In very simple cases, like the spin filter measurement with a Stern-Gerlach apparatus you can even semianalytically calculate it by solving the Schrödinger equation. See, e.g.,
PHYSICAL REVIEW A 71, 052106 (2005)
Quantum mechanical description of Stern-Gerlach experiments
G. Potel, F. Barranco, S. Cruz-Barrios and J. Gómez-Camacho
Not all interactions cause decoherence and it has nothing to do with an observer.
Thanks
Bill
Great question. I address this in specific terms in my new book. The interaction that leads to collapse is one in which there is a response from an absorber. There are other interactions (virtual particle exchanges) that do not lead to collapse. Nowhere in this account does one need to talk about an 'observer,' although observers can participate in collapsing interactions by being composed of absorbers themselves. It's just that collapse is not limited to an 'observer'.
Likes julcab12
  • #31
I do not understand, in my post , you guys gave the certainty that consciousness has nothing to do with it, in this post you put me in doubt about consciousness `playing a role on the collapse of the wave ..
  • #32
Come again. There is nothing in MW that requires an observer.
MW is nothing like psychoanalysis. Its an objective deterministic theory.
Thanks
Bill
  • #33
Thanks
Bill
Ok. Can you please elaborate on "Not all interactions and nothing to do with an observer" Thanks in advance.
  • #34
vanhees71, then why "minimal statistical interpretation" isn't accepted by the scientific community? It would end a lot of problems about it, youtube is full of people thinking that we create reality as we look/intent
  • #35
vanhees71 said:
Seriously, it's not even clear that there is something like a collapse in nature. I'm a follower of the minimal statistical interpretation, and there's no collapse necessary, which avoids a lot of problems with Einstein causality etc. For me "Collapse" is just a word for adjusting the state after the interaction of the system under consideration with a preparation apparatus in the sense of an ideal von Neumann "filter measurement"...
My concern about Ballentine's 'ensemble' approach is that it doesn't explain why certain objects (e.g. electrons) must be described only as a (quantum) ensemble while others (e.g. baseballs) may be described as a single (classical) system. That is, it still seems to suffer from a micro/macro or quantum/classical 'cut' that is not defined. In contrast, PTI can explain this transition between the two theories.
  • Quantum Physics
