Does dark matter contribute to my body mass?
In summary, dark matter is present throughout the universe and tends to clump with regular matter due to gravity. However, the amount of dark matter in our solar system is very small and would not have a significant impact on an individual's weight. This is because dark matter does not interact with regular matter, so it simply passes through our bodies and does not contribute to our inertia or weight on a scale. The only way it could affect weight measurements is if there was a large amount of dark matter collected in the Earth, which would increase its gravitational mass and slightly increase weight on a scale.
rootone
3,395
946
No I'm not a particularly big person with a weight issue.
Somebody asked me this question and I don't know the answer, but somebody here will.
OK, it's now accepted that dark matter is everywhere in the Universe, it tends to clump with regular matter because all matter is subject to gravity, but there is a lot more of it than the normal matter.
So, some proportion of my body mass will be due to dark matter.
If the dark matter wasn't there, would I weigh less according my bathroom scales?
Space news on Phys.org
Dark matter does not really clump except on cosmological scales. Any dark matter passing through your body just keeps right on going as though you weren't there. Also, there is so little dark matter in our solar system that the amount in the volume of your body would be unmeasurable with current technology.
Likes rootone
To give you an idea of how little dark matter there is in the solar system in total, it is about the same as that of a small asteroid. This may seem strange considering there is more dark matter in the universe than "normal: matter, but this has to do with distribution.
Planets are dense. The solar system taken as a whole is much less dense even though the total mass of the solar system is more than any given planet. The solar system as a whole is denser than a given volume of our local stellar neighborhood, even thought the combined mass of all the stars in the local neighborhood is more than that of the solar system. The density of the galactic disk is greater than that of the dark matter halo, but since the DM halo fills a much, much larger volume, the total mass of the dark matter halo is greater than that of the galactic disk.
It is the electromagnetic interaction of normal matter along with gravity that causes it to clump up like it does, and it is the lack of this electromagnetic interaction that keeps DM from clumping as densely.
Likes JMz and rootone
Indeed, in that whole hierarchy, normal matter apparently has greater density than DM at every level, until the last one, the (outer) halo.
Even if there was a tonne of dark matter around, it wouldn't affect a measurement of your mass. It is just floating straight through you. If I push you, I will not feel the dark matter contributing to your inertia since it will just stay where it is while you move, since it is essentially not coupled to you at all. Likewise, it will not push down on the scales, since it goes straight through your body and straight through the scales. There is also no bouyant force or any such thing generated by it, since you are not displacing any dark matter. The only way it will change the measurement is by there being loads of dark matter collected in the Earth, which makes the effective gravitational mass of the Earth bigger. Then gravity on Earth will be a little bigger and you will register a larger weight on the scales as a result. Of course we would also have calibrated our scales to take this into account, so the marking on your scales would just have "10 kg" written in a slightly different position.
Likes JMz
Related to Does dark matter contribute to my body mass?
1. What is dark matter?
Dark matter is a type of matter that is believed to make up about 85% of the matter in the universe. It does not interact with light, making it invisible, but it does have a gravitational effect on visible matter.
2. How does dark matter contribute to my body mass?
Dark matter does not contribute to your body mass directly. It is believed to make up a significant portion of the mass of the galaxy and our solar system, which in turn affects the gravitational pull on all objects, including our bodies.
3. Can dark matter be detected in the human body?
No, dark matter cannot be detected in the human body. Currently, the only way to detect dark matter is through its gravitational effects on visible matter.
4. Is dark matter harmful to humans?
No, dark matter is not harmful to humans. It does not interact with normal matter in any way other than through gravity, so it does not pose any threat to our health.
5. How does the presence of dark matter affect our understanding of the universe?
The presence of dark matter is essential to our current understanding of the universe. It helps explain the observed gravitational effects on galaxies and the structure of the universe. Without dark matter, many observations and theories would not make sense.
  • Cosmology
  • Cosmology
