Does dark matter interact with Baryons?
In summary, the paper discusses the standard view that most dark matter models have weak interactions with standard model particles, although the strength may vary depending on the model. It is not possible to completely rule out interactions between dark matter and baryons, but it is possible to place limits on their strength. Currently, no interactions have been detected and there is still uncertainty surrounding the topic. The conversation also acknowledges the excellence of the paper.
wolram
Dearly Missed
4,446
558
This paper says they do. but I have been lead to believe that DM only interacts with gravity
https://arxiv.org/abs/1811.08843
What is the standard view?
Astronomy news on Phys.org
In most DM models there are some weak interactions with standard model particles. For your typical WIMP scenario those interactions are of more or less the same strength as the weak interactions but this generally depends on the dark matter model. You can never prove a negative so you can never exclude dark matter having some interactions with baryons. What you can do is place bounda on the strength of those interactions.
No interactions have been detected.
Nobody knows.
Excellent paper, wolram. Thanks.
Related to Does dark matter interact with Baryons?
1. What is dark matter and baryons?
Dark matter is a type of matter that makes up about 85% of the total mass of the universe. It does not emit or absorb light, making it invisible to telescopes. Baryons, on the other hand, are the ordinary matter that makes up stars, planets, and all visible matter in the universe.
2. How does dark matter interact with baryons?
Dark matter and baryons do not interact through electromagnetic forces, meaning they do not emit or absorb light. However, they can interact through gravity, which is the force that keeps objects in the universe bound together. Dark matter and baryons can also interact through the weak nuclear force, but this interaction is very rare.
3. What evidence suggests that dark matter interacts with baryons?
Scientists have observed that the rotation curves of galaxies do not match the expected rotation based on the visible matter present. This suggests that there must be some unseen matter, such as dark matter, interacting with the visible matter through gravity. Additionally, the gravitational lensing effect, where light from distant galaxies is bent by the gravity of dark matter, also provides evidence for the interaction between dark matter and baryons.
4. Can dark matter and baryons form a bound system?
Yes, dark matter and baryons can form a bound system, such as a galaxy. The gravitational force between dark matter particles and baryons allows them to clump together and form structures in the universe. However, the exact nature of this interaction is still not fully understood and is an active area of research in astrophysics.
5. Can dark matter interact with baryons in ways other than gravity?
While gravity is the main force that allows dark matter and baryons to interact, there have been some theories proposing other types of interactions, such as dark matter decay or annihilation. However, there is currently no conclusive evidence to support these theories, and further research and observations are needed to understand the true nature of dark matter and its interactions with baryons.
