Does decreasing pressure of fluid in a fixed volume lower temperature?
In summary, the conversation is discussing the relationship between fluid velocity and temperature in a horizontal pipe. Based on Bernoulli's equation, it can be concluded that if the fluid velocity increases, then the pressure must decrease in order to satisfy the equation. This decrease in pressure will likely result in a decrease in temperature, assuming the fluid behaves similarly to a gas. However, the answer may depend on the equation of state and flow properties of the fluid. Overall, the question is flawed since it does not provide enough information to accurately determine the relationship between velocity and temperature.
grayb
Sorry if the formulation is imprecise, I'm a biology major trying to study some physics. The question is:
569. When comparing two points of fluid flowing through the same horizontal pipe, if the fluid velocity is greater, then
A. the temperature is less
B. the temperature is greater
C. the temperature is unchanged
D. the pressure is greater
So far, my reasoning is:
From Bernoulli's equation, you have
(1/2)(\rho)v^2 + \rho*g*h + P = constant
where \rho = density, v = velocity, g = acceleration due to gravity, h = height and P = pressure.
If the first term increases, one or both of the other two terms must decrease in order to satisfy the relationship. How can this happen?
(1) \rho*g*h decreases. This means either \rho, g, or h decreases. Since the fluid is incompressible (assumption I'm making), \rho is constant and cannot decrease. g is a constant and cannot decrease. So it's possible that the height decreased. But that's not one of the answer choices.
(Note: If the fluid were not incompressible, a possible answer would be that \rho, the density, decreases. Since volume is constant, this would mean the mass of the fluid decreased. This is not an answer choice.)
(2) P decreases. Notice that the question says "same horizontal pipe", which means the volume doesn't change to compensate. So the pressure in a fixed volume is being decreased, which means it can be reasonably be assumed (too lazy to go through the math of the relationship between pressure/volume and temperature for fluids, I'm assuming it's similar to gases) that the temperature decreases. That's why I would say it's A.
I make an assumption in Step (2) that decreasing the pressure will decrease the temperature. But I'm not sure what the justification is. I only know of the ideal gas law, and I'm not sure if the behavior is the same for incompressible fluids. Maybe incompressibility means fluid is similar to ideal gas behavior, or maybe it holds in general and the incompressibility assumption can be removed? Or maybe it's dependent on the fluid?
Thanks for any clarification!
Science news on Phys.org
The bottom line is it's a bad question. The answer depends on what the fluid is (or more mathematically, the equation of state), so it will be have differently I it is a gas or liquid. Further, it would depend on the flow properties of the fluid as well since gases behave differently at different pressures and velocities.
The ideal gas law is the equation of state for an ideal gas and it only really applies to compressible gas flows.
My reasoning is completely different from yours.
The answer cannot be D because A, B, and C cover all possible situations regarding temperature, therefore 1 of them must be true.
We are told nothing about the nature of the fluid or the reason it is flowing at different rates through the pipe, Only that it flows at different rates. Given that the authors of the question felt this was the only information necessary I believe the answer they are after is B. Increased velocity of the fluid results in increased friction between the fluid and the pipe resulting in higher temperature.
mrspeedybob,
That isn't necessarily the case even then, though. Fluids are not like solids. Viscous dissipation of kinetic energy into thermal energy has a very weak effect on the temperature of the fluid except at high speeds compared to the effects of conduction and convection from the wall. In other words, without any information on the heat transfer boundary condition at the wall, it is impossible to make the conclusion you made.
I can provide the following response to your question:
Your reasoning is correct in assuming that decreasing the pressure in a fixed volume will result in a decrease in temperature, based on the ideal gas law. However, this relationship may not hold for incompressible fluids. In fact, for incompressible fluids, the temperature does not change with changes in pressure. This is because the density of an incompressible fluid remains constant, regardless of changes in pressure. Therefore, in this case, the correct answer would be C.
The behavior of fluids, whether they are compressible or incompressible, can vary depending on the specific properties and characteristics of the fluid. So, it is important to consider the type of fluid when making assumptions about its behavior. In this case, the incompressibility of the fluid changes the relationship between pressure and temperature, so the ideal gas law cannot be applied.
I hope this helps clarify any confusion and highlights the importance of considering the specific properties of a fluid when studying its behavior.
Related to Does decreasing pressure of fluid in a fixed volume lower temperature?
1. What is the relationship between pressure and temperature in a fixed volume of fluid?
In a fixed volume of fluid, there is an inverse relationship between pressure and temperature. This means that as pressure decreases, temperature will also decrease, and vice versa.
2. How does decreasing pressure affect the behavior of molecules in a fluid?
When pressure is decreased in a fixed volume of fluid, the molecules in the fluid have more space to move around and collide with each other. This results in a decrease in the average kinetic energy of the molecules, leading to a decrease in temperature.
3. Why does decreasing pressure lead to a decrease in temperature in a fixed volume of fluid?
According to the ideal gas law, PV=nRT, the temperature of a gas (or fluid) is directly proportional to its pressure. This means that as pressure decreases, the temperature must also decrease in order for the equation to remain balanced.
4. Can decreasing pressure in a fixed volume of fluid cause a phase change?
Yes, decreasing pressure in a fixed volume of fluid can cause a phase change. This is because, in a fixed volume, decreasing pressure will cause the temperature to decrease. If the temperature reaches the critical point, the fluid will undergo a phase change from liquid to gas.
5. How does the type of fluid affect the relationship between pressure and temperature in a fixed volume?
The type of fluid can affect the relationship between pressure and temperature in a fixed volume. For example, in a gas, decreasing pressure will cause a decrease in temperature, as explained by the ideal gas law. However, in a liquid, decreasing pressure may not always result in a decrease in temperature, as other factors such as intermolecular forces can also play a role in determining the behavior of the fluid.
  • Thermodynamics
