Does determinism exclude retrocausality?
In summary, deterministic systems entail that effects follow causes, but this does not imply that there is no choice involved.
entropy1
1,230
71
Suppose the system under examination is fully deterministic. Does that imply that effects follow causes and not precede them?
For instance, if in this system Alice would respond to event X with A, but, if instead of X event Y would have happened, with B, does that mean she has no choice between A and B in that case?
Bohmian mechanics is fully deterministic, and posits retrocausality, so I'd say determinism does not imply that.
This isn't an example of retro causality.
Alice wants vanilla, and she'd respond to X: vanilla ice cream being presented to her right with the action A: reaching to her right. But if instead Y happens (the vanilla is placed to her left), then she'd respond with B: reaching to her left. Straight cause and effect there, nothing retro.
Retrocausality would be her reaching for the ice cream before she knows where it is going to be placed.
Edit: I have changed my notation to make it consistent with @entropy1
For any discussion of causality it is absolutely essential to be clear about what definition you are using for causality. Otherwise you have people arguing who think they are arguing about substance when they are actually just arguing because they are using different definitions. Here are some suggested definitions, for clarity: https://en.wikipedia.org/wiki/Causality
Necessary causes: If x is a necessary cause of y, then the presence of y necessarily implies the prior occurrence of x. The presence of x, however, does not imply that y will occur.
Sufficient causes: If x is a sufficient cause of y, then the presence of x necessarily implies the subsequent occurrence of y. However, another cause z may alternatively cause y. Thus the presence of y does not imply the prior occurrence of x.
So, given the laws of classical physics, and in particular the time reversibility, if we have an initial condition ##\cancel{A} \ Y## then we can apply the laws of physics to calculate a final condition ##B## at any later time. However, we can also start from the final condition ##B## and use the laws of physics to calculate backwards to the initial condition ##\cancel{A} \ Y##. So ##\cancel{A} \ Y## implies ##B## and ##B## implies ##\cancel{A} \ Y##.
Thus we see that ##\cancel{A} \ Y## is both a necessary and a sufficient cause of ##B##. However, by the definitions above ##B## fails to be a necessary cause of ##\cancel{A} \ Y## because ##B## did not occur prior to ##\cancel{A} \ Y##. Similarly, ##B## fails to be a sufficient cause of ##\cancel{A} \ Y## because ##\cancel{A} \ Y## did not occur subsequent to ##B##.
Likes jim mcnamara and entropy1
Could one argue that in the deterministic setting, if at present B would happen instead of A, the consequence would be that consecutively something different would happen (in general/in the universe) than if A would have happened?
And if B would happen instead of A, something different preceded this event than if A would have happened?
Dale said:
Thus we see that A is both a necessary and a sufficient cause of B.
OK now I am completely confused. How are these statements compatible?
I think @hutchphd is right. This is not logically possible. You can have both A and B or neither A nor B. But you cannot have A instead of B.
Edit: I am confused here. You can have both A and X or neither A nor X, but you could instead have B and Y.
Not sure. A is a measurement of spin up, B is down. You can't have both or neither, so it's A instead of B, or B instead of A. This is an uncaused difference. Nothing different 'preceded event B than if A would have happened'.
OK, that's a QM interpretational assertion. There are deterministic interpretations that say B is determined and A is out, due to some preceding state, possibly a hidden one. Something like MWI says both A and B, or neither, so we're more in line with Dale's statement. WF collapse interpretations (like RQM for instance) are not necessarily deterministic, so there is B or A, even if there is no 'dice rolling' in some of them.
Am I totally inconsistent with this line of thinking?
Likes entropy1
Where did that come from? That isn’t what we are talking about. B is caused by A so A and B are not what you described. Not to mention that we are talking about completely deterministic systems.
Edit: I am also confused here. B is caused by Y, not A.
I'm talking about followup discussion on entropy1's post 4, which is A or B, due to some prior state or not, not the scenario of one being the cause of the other.
It did get confusing when the same terms were used to describe A causing B.
But you are apparently talking about the other scenario in post 6, which is A being necessary and sufficient for B, in which case yes, both A,B or neither. I don't think that's what @entropy1 was talking about.
Likes entropy1
That was still explicitly deterministic, so I still have no idea why you brought in your example. It seems off topic for a thread about deterministic systems.
Dale said:
B is caused by A
If I wrote that, that would be a mistake...
Thanks for clearing that up. Post #4 is a somewhat separate question from post #1. In fact, I was working toward a more physical matter myself.
Ok, so in your notation what is the cause and what is the effect? Please be clear, there has been substantial confusion.
In post #1 A and B are events that are caused by resp. causes X and Y. In post #4 I extended this with that A and B cause unspecified effects (consequence) and are caused by unspecified causes (precedence). I left it unspecified deliberately at this point.
Ah, ok, my post above was incorrect then. I have gone back and added edits to correct my usage and make it consistent with your notation.
Definitely. If B instead of A at present then previously Y instead of X.
Yes, I'm suggesting exactly that: if B would have happened at present, there would be a different preceding cause than if A would have happened (in general, but in a deterministic setting when it is either A or B, think of a quantum measurement, like Halc mentioned). But I'm not sure if this is true.
entropy1 said:
Yes, I'm suggesting exactly that: if B would have happened at present, there would be a different preceding cause than if A would have happened (in general, but in a deterministic setting). But I'm not sure if this is true.
Yes, this is true by your above notation and the above definitions. Since X and Y are necessary and sufficient causes of A and B respectively: we therefore know that B at present implies prior occurrence of Y, whereas A at present implies prior occurrence of X. This is by the definition of necessary cause.
I have to study this; this is brain exercise for me. ?:) (necessary cause vs. sufficient cause)
If X is only a sufficient cause for A, X is not mandatory to have happened. X' or X'' could be causes too. Then, X' could be a cause for both B and A. This means that if B happened the preceding cause could be X', and if A happened it could be too. So there would be a single cause, not different ones, and no need for different histories for A and B. Does that make sense?
But then, if there is some rule that A and B can't happen both, and can't happen neither, the choice between A and B would be random, right?
If X would be sufficient cause for A, and X happens, does that mean that A happens?
It does make sense for a sufficient cause. However, in classical physics all causes are necessary and sufficient causes.
Yes. If X is a sufficient cause for A and X happens then subsequently A happens.
A different view on the matter is the following:
Provided the system (universe) is deterministic, if I respond differently (to some event), the event (cause) was different (because if the cause was the same, the response would be the same, right?).
For example: if I respond with A, the cause was X, but if I respond with B, there would have to have been a different cause Y.
These causes (X and Y) would have to be necessary causes.
In this example A and B are mutually exclusive (one of them happens at t0).
If X and Y would on the other hand be sufficient causes, then some different cause Z could cause A as well as B. If A and B are mutually exclusive, does that mean that the respons to Z (A or B) is random?
Is that correct?
And also, is it so that if X is necessary cause of A, that occurence of A implies occurence of X, and that if X is sufficient cause of A, that occurence of X implies occurence of A?
Determinism or non-determinism is only well defined, if we have a definition of "states".
The use of notation like "A" and "B" to denote phenomena is somewhat ambiguous. I think most contributors to this thread are using notation like "A" to denote a set of different possible phenomena.
For example, "A" could denote "It rains at my house on Monday morning". There are many different phenomena that are described by "It rains at my house on Monday morning". The can differ in details like where the rain drops land and what the closing value of the Dow Jones Industrial Average is on that day.
A different use of notation like "A" is to denote a unique event, as opposed to a set of events.
Either interpretation of notation leads to a host of problems!
Likes entropy1
This is why, in a deterministic setting, all causes must be both necessary and sufficient.
Likes entropy1
entropy1 said:
Is it true that if X is necessary cause of A, that occurence of A implies occurence of X, and that if X is sufficient cause of A, that occurence of X implies occurence of A?
And since I chose this title for the thread, does in the first case (X is necessary a condition for A, occurence of A implies occurence of X) mean that A could be a cause for X (retrocausally)?
If the universe is deterministic there is no "if" about how you respond. You respond deterministically. So, for your idea to be coherent, we have to imagine that your are using the term "some event" to denote a set of phenomena and that the history of universe contains several examples where phenomena of that type occurred. Likewise, what you call your "response" must also described by at least two mutually exclusive sets of phenomena ##R_1, R_2##. Otherwise the history of the universe contains no examples where you responded "differently".
However, if "some event" ##S## can be followed by two different sets of events ##R_1, R_2## then some of the events ##S,R_1,R_2## are not "states" of the universe. (In a deterministic process, a given "state" is always leads to a unique later "state". That is the definition of "state" and "deterministic".)
You are attempting to discuss cause-and-effect properties for sets of events that are not states. This might be possible, but I think it's tricky!
@Stephen Tashi
If we have state of the universe X at t=0, then you say, that, under determinism, there is only a single possible state of the universe at t=1, say A, right?
So I am suggesting that if at t=1, if we don't find the state of the universe to be A, but, say, B, that X wasn't the state of the universe at t=0, but some other state Y.
You would have to change the definition of cause if you wanted that to work, as I said in my first post when I posted the definition.
You mean the requirement that cause precedes the effect temporally? (do you mean post #3?)
That would be a formal difference then?
Yes - that's the definition of "determinism" and "states".
Yes it makes sense as deduction. How we relate a deduction to the concept of causality or retro-causality isn't clear. The deduction isn't sufficiently abbreviated by "If not A then not X". The deduction includes the time information, so it's "If not A at time t=`1 then not X at time t=0".
@Stephen Tashi
Ok. So if I was to smuggle in a free-will deamon that could choose between either A or B happening at t=1, could we have retrocausality?
Yes. With the current definition you cannot have retrocausality because of that requirement. I do not know how people who propose retrocausal theories modify the definition.
How is retrocausality defined? In these discussions it is absolutely essential to be clear about your definitions.
  • #31
entropy1 said:
Ok. So if I was to smuggle in a free-will deamon that could choose between A and B happening, could we have retrocausality?
In mathematical logic, the statement "If P then Q" is considered True when P is False. If you introduce a demon to make Determinism False then all statements of the form "If Determinism is True then ..." are True.
Rather than introduce a demon, I think you should return to the idea of defining causality for events that are not states.
  • #32
My assumption is that determinism holds universally except for the free-will deamons. Then retrocausality (in the universe) could hold, right? But determinism also holds, for given a state at t=1, the state at t=0 already happened. I am simplifying enormously here, I am aware, but it is only a thought experiment.
  • #33
It's unclear what that means.
Likes entropy1
  • #34
You are right. For me, I think it means that if the universe is deterministic, there are still several ways in how it could be that. I mean, different histories are conceivable.
The free-will deamon picks a history by choosing a state of the present (A or B).
  • #35
Again, how do you define retrocausality? Until you define exactly what you mean by that word your question literally has no meaning.
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
