Erik Ayer
- 75
- 4
- TL;DR Summary
- When a photon is downconverted, does its path collapse?
I saw a paper on an experiment where a pump beam first went through a double-slit, then was downconverted with BBO. Recently a friend with a PhD in quantum physics said the downconversion will cause the pump's wavefunction to collapse and the implication for this experiment is that the pump photon would then have only gone through one slit or the other rather that a superposition of both, and hence there would be no interference. That depends on how close the BBO was to the slit and whether the light had overlapped and interfered by then.
If the wavefunction does collapse at downconversion, the this experiment would be kind of stupid. With the BBO immediately following the double slit, there would be no interference. If the BBO was placed where the light from the slits overlapped, there would be interference but it would be the pump beam's interference rather than the downconverted light.
More generally, if a pump beam with some finite cross section is downconverted, when that happens does it happen at a specific position within that cross section? Initially every photon is in a superposition across the entire beam (and the double-slit experiment works and stuff), but I'm wondering whether the two photons from downconversion then come from a specific point within the intersection of the beam and the BBO rather than be in superposition of having downconverted across the whole cross section.
