Does electron excitation for atoms above hydrogen happen at the valenc
In summary, the electron excitation for atoms above hydrogen happens at the valence before the core electrons first.
hongiddong
65
Does electron excitation for atoms above hydrogen happen at the valence before the core electrons first?
I know that for a gamma ray it is due to the excitation within the nucleus, but what about for normal emission spectra.
Do we just shine a bunch of different energy onto the atom and the energies will hit both the valence and the core, or does the valence take the brunt of most of the energy before it hits the core?
I think that the electron's are moving around in the probable Energy regions, and if the different electrons in there different energy locations, ex. helium, receive the discrete energy to jump to it's discrete energy gap that is being radiated with the electron it will jump up because the radiation is hitting all the electrons(valence and the core), assuming a constant radiation of a continuum of different energies.
Chemistry news on Phys.org
That depends on the frequency (energy) of the radiation. Light in the visible or near UV can only excite valence electrons as they are least tightly bound. On the other hand, X-rays preferably lead to core ionization. Maybe you have already heard of Moseley's law which cleared up many open questions in the development of the periodic system.
ooo, hmm. My last question is then, if we were to shine a energy radiation beam at a carbon atom for instance, would this constant energy beam be able to touch both the valence and the core electrons?
No problem with kicking out inner electrons with x-rays (compare with Auger effect and Auger electron spectroscopy), so the answer is yes.
Likes 1 person
Depends a little bit on what you mean with "touch". Generally, any radiation will interact with all electrons what will lead to the radiation being scattered. Whether ionization of core or valence electrons takes place, depends on the energy of the quanta of the incident radiation.
Likes 1 person
Thanks Dr.Dru and Borek!
FAQ: Does electron excitation for atoms above hydrogen happen at the valenc
1. What is electron excitation in atoms?
Electron excitation is a process in which an electron in an atom is given additional energy, causing it to jump to a higher energy level or orbital. This results in the atom becoming unstable and eventually releasing the excess energy through the emission of light or heat.
2. How does electron excitation occur?
Electron excitation can occur through various means, such as collisions with other particles, absorption of photons, or application of external energy. In the case of atoms above hydrogen, electron excitation typically occurs through absorption of photons from external sources.
3. Is electron excitation possible for all atoms?
Yes, electron excitation can occur for all atoms, but the exact energy levels and mechanisms may vary depending on the specific atom and its electron configuration.
4. What is the significance of electron excitation for atoms above hydrogen?
Electron excitation for atoms above hydrogen is important in understanding the energy levels and behavior of these atoms. It is also crucial in various fields such as spectroscopy, where the analysis of light emitted or absorbed during electron excitation can provide valuable information about the composition and structure of atoms.
5. How is electron excitation related to the valence of an atom?
The valence of an atom refers to the number of electrons in its outermost energy level or shell. Electron excitation can occur for electrons in any energy level, but it is particularly relevant to the valence electrons as they are the most likely to interact with external sources of energy and participate in chemical reactions.
