Does entanglement always conserve something?
In summary, the discussion explores whether quantum entanglement conserves certain physical quantities, such as information or energy, during interactions between particles. It highlights the complexities of entangled states and the principles of quantum mechanics, suggesting that while entanglement can lead to non-local correlations, the overall conservation laws still hold true within the framework of quantum theory. The article emphasizes the need for further understanding of how entanglement interacts with conservation principles in various quantum systems.
Swamp Thing
Insights Author
970
670
IIUC, entanglement sometimes plays a role in conserving come quantity like momentum or spin: the quantities measured for two particles must be correlated in order to get a certain total value.
But is this always the case? For example, what, if anything, is conserved in the Hong-Ou-Mandel experiment? Or, what conservation would be violated if one photon was detected at each output (or two electrons at the same output) ?
Energy and momentum are conserved in the system of photon and detector.
Specifically in the HOM setup, if two photons enter and end up in different detectors (instead of the same detector), how would energy be violated?
Also, electrons and photons behave in opposite ways in the HOM situation (bunching / antibunching) , so they can't both be conserving momentum / energy ...?
Now you proceed to two photons case. In the system of photons and detectors there are no violations of energy and momentum. Do you have any motivation on pursuiting the violations ?
I think you have it backwards. Momentum (for example) is always conserved, including in entangled systems.
I guess what I'm getting at is, sometimes conservation laws put constraints on the system that make certain correlations (entanglement) necessary. But sometimes such correlations can arise / exist without the need to comply with any such requirements?
Right, but conservation doesn't cause entanglement. As for detecting entanglement, how would you do this without looking at a conserved quantity?
Just curious. Would you say that there is a conservation law between the two entangled photons that are produced from entanglement swapping?
Not an answer to your question, but an interesting fact: those entangled photons need not be of identical wavelength. In fact, you can even use photons to entangle (via swapping) spins of 2 distant electrons. In principle, there is no requirement that the particle types even be the same.
Experimental loophole-free violation of a Bell inequality using entangled electron spins separated by 1.3 km
