Does Euclidean geometry require initial fine-tuning?
In summary, the flatness problem, also known as the oldness problem, is a cosmological fine-tuning problem within the Big Bang model of the universe. This problem was solved by introducing the theory of inflation, which flattens out any initial curvature and makes our universe appear spatially flat. However, the exact flatness required for euclidean geometry still raises the issue of fine-tuning regarding initial energy densities. Whether the universe has euclidean geometry or not cannot be experimentally established, making it a matter of personal opinion and dependent on prior probabilities. Some scientists argue that euclidean geometry is unlikely due to the fine-tuning problem, but this is not a universally accepted viewpoint. The assumption of euclidean geometry does not necessarily support the idea
timmdeeg
282
TL;DR Summary
The question
doesn't Ω=1 require k=0 at the big bang (before inflation started)?"
was answered affirmatively [url=https://www.physicsforums.com/threads/lambda-cdm-model-and-spatial-flatness.979086/#post-6249196]here[/url]. However I should have asked "does" instead of "doesn't?
So to clarify this issue, does Ω=1 require k=0 at the big bang?
If yes would this mean that we have a fine-tuning problem regarding the initial density of the universe here (comparable to the *old* Flatness-Problem)?
https://en.wikipedia.org/wiki/Flatness_problemThe flatness problem (also known as the oldness problem) is a cosmological fine-tuning problem within the Big Bang model of the universe.
The fine-tuning problem of the last century was solved by introducing the theory of inflation which flattens out any initial curvature so that our actual universe looks almost spatially flat. The inflation doesn't create euclidean flatness though.
Would the claim that our universe has euclidean geometry raise the old fine-tuning problem regarding the initial energy densities again?
Space news on Phys.org
Exact flatness requires that ##\Omega_k = 0##. However, inflation would drive it unobservably close to zero even if it was not to start with.
Ok, thanks for confirming that.
Would you agree that this requires initial fine tuning?
Yes. I think from our observation we can't distinguish (now and probably also in future) between ##\Omega_k## is "close to zero" (but not zero, due to inflation) and ##\Omega_k = 0## (due to initial fine-tuning).
If this is correct so far, what would we assume to be more likely, the former or the latter?
Why is this not an acceptable answer?
This answer concerns one aspect of my question, which involves 2 initial possible states of the universe:
A The initial spatial curvature is non-zero, implying ##\Omega_k\neq 0## (due to inflation "unobservably close to zero though") and thus excluding euclidean geometry.
B The initial spatial curvature is zero, implying ##\Omega_k = 0## (raising the fine-tuning problem though) und thus euclidean geometry.
A and B are not distinguishable by observation. But I think it is legitimate to ask which possibility seems more likely?
Also please correct wrong reasoning.
It is not legitimate. The answer is utterly dependent on your prior.
Likes timmdeeg
Oh, then I was mistaken, thanks for clarifying.
Remembering the flatness problem my personal view is that ##\Omega_k = 0## is very unlikely.
May I ask what’s the personal view of others around here?
Science does not progress by vote, nor by personal views. However, my personal view is worrying about whether a number is x or immeasurably close to x is effort best expended elsewhere.
Likes Orodruin and weirdoguy
I fully agree, but this doesn't preclude that scientists don't hesitate to talk about personal views, e.g. about the interpretations of Quantum Mechanics.
Another question in this context, hopefully more on scientific grounds and less on personal views:
Can we ever ascertain from our observation whether or not our universe has euclidean geometry?
That some scientists like to discuss something does not make it scientific.
Edit: Also, many scientists do prefer to leave personal opinion out of the discussion as much as possible.
No. On two levels. First of all, being Euclidean is not something that can be experimentally established beyond experimental accuracy. Second, you are talking about an approximation that is only valid on very large scales and in a very particular set of coordinates. It is clear that this approximation is not applicable on small scales and the Universe clearly is not flat on small scales so the question in itself becomes rather moot.
Edit: Also, many scientists do prefer to leave personal opinion out of the discussion as much as possible.No. On two levels. First of all, being Euclidean is not something that can be experimentally established beyond experimental accuracy. Second, you are talking about an approximation that is only valid on very large scales and in a very particular set of coordinates. It is clear that this approximation is not applicable on small scales and the Universe clearly is not flat on small scales so the question in itself becomes rather moot.
Yes, I'm talking about the universe in the context of the Friedmann Equations. Our observable universe could have overdensity or underdensity (as some people are presently discussing regarding the Hubble tension). So I don't think it makes any sense to consider a value for ##\Omega_k## locally.
Wikipedia writes If the initial density of the universe could take any value, it would seem extremely surprising to find it so 'finely tuned' to the critical value ##\rho_c##..
From this and the fact that Euclidean geometry of the universe can't "be experimentally established" it seems that it is not personal view to argue that Euclidean geometry is rather unlikely. Not sure if you agree.
If correct this assumption would not support any reasoning that the universe is infinite (but rather the opposite).
As @Orodruin has already pointed out, "unlikely" requires a prior. Different priors will lead to different answers.
For example: suppose there is some constraint that requires zero spatial curvature. Then Euclidean geometry is imposed by this constraint. We don't currently know of any such constraint, but we don't currently have a complete understanding of all the factors involved either. So if I assign enough prior probability to there being such a constraint, Euclidean geometry is no longer "unlikely".
This is not correct, because it is perfectly possible to have an inflation model in which the curvature starts out negative and gets flattened out by inflation. A universe with negative curvature would be spatially infinite. So the question of whether there is spatial curvature or not is separate from the question of whether the universe is spatially infinite or not.
Likes timmdeeg
Perhaps I misunderstand the meaning of "prior probability" (my native language is german). Why can't I understand the Wikipedia quote in #11 such that the prior probability for Euclidean geometry is "unlikely"?
Doesn't at least result a week constraint from this quote?
Yes, I've overlooked this aspect, thanks.
You can, but that just means the author of that quote has a particular opinion on the prior probability for Euclidean geometry. It does not mean it's the only possible opinion or that that particular opinion has any special weight. Assignment of prior probabilities--i.e., the probabilities you assign to various alternatives prior to looking at any data at all--is always subjective. You can't use one person's subjective judgment as an argument against another person who has a different subjective judgment.
timmdeeg said:
Yes, I'm talking about the universe in the context of the Friedmann Equations. Our observable universe could have overdensity or underdensity (as some people are presently discussing regarding the Hubble tension). So I don't think it makes any sense to consider a value for ΩkΩk\Omega_k locally.
You are missing the point. If you are interested in a single value for ##\Omega_k##, then even small local deviations from flatness on your Euclidean space is going to spoil everything for you. It simply is no longer a good idea to apply the approximation and talk about a value of ##\Omega_k## with that kind of precision given what we already know about the Universe's non-flatness.
Perhaps I'm wrong. As I understood it "that quote" describes the origin of the flatness problem und hence was the general view among cosmologists at that time.
Is the universe flat everywhere? (Picking up pen and dropping it). Clearly not.
Therefore the only way to tell if it is globally universally flat is some sort of average. Can I find an average that is zero? Always.
The statement Ωk is close to zero. even immeasurably close to zero is a scientific one. The statement that it is exactly zero is a statement about your choice of averaging procedure.
Orodruin said:
You are missing the point. If you are interested in a single value for ΩkΩk, then even small local deviations from flatness on your Euclidean space is going to spoil everything for you. It simply is no longer a good idea to apply the approximation and talk about a value of ΩkΩk with that kind of precision given what we already know about the Universe's non-flatness.
Sorry, I don't understand the message.
The inflation predicts ##\Omega_k## extremely close to zero regardless any initial curvature. In an arbitrary observable universe people will confirm this prediction by measurement. Nowhere they will confirm ##\Omega_k = 0## because of lack of measurement accuracy. So the initial state of the universe (curved or flat remains unknown)
As to "a single value for ##\Omega_k## " (a value valid for the universe as a whole) assuming the Cosmological Principle the inflation predicts ##\Omega_k## extremely close to zero regardless any initial curvature. If the initial state is ##\Omega_k = 0## then on small enough scales slight deviations from this seem possible (*) but not on very large scales and not regarding the universe as a whole.
I might still be missing something and hope the above allows you to identify what.
(*) Whereby I'm not sure if local values of ##\Omega_k## make sense at all. But strictly a local overdensity would require ##\Omega_k = 1##.
Not quite. The origin of the flatness problem is described a little later in that same article:
"The current density of the universe is observed to be very close to this critical value. Since the total density departs rapidly from the critical value over cosmic time,[1] the early universe must have had a density even closer to the critical density"
The key statement is in bold above; it is only true for models that include ordinary matter and radiation but nothing else, and which do not start out exactly flat spatially. It is not true for inflationary models; it is also not true for models that are dominated by a positive cosmological constant (as our current universe is). And it is also not true for a model that starts out exactly spatially flat.
So anyone of those three possibilities--inflation, a positive cosmological constant, or exact spatial flatness, for example imposed by some constraint as I mentioned in a previous post--would solve the flatness problem. In the absence of evidence that rules out one or more of the three possibilities, which one you prefer is a matter of your choice of prior probabilities--i.e., which one you subjectively consider to be the least unlikely given your other subjective beliefs.
Likes timmdeeg
Thanks for this excellent explanation. I haven't seen these interrelations.
Related to Does Euclidean geometry require initial fine-tuning?
1. What is Euclidean geometry?
Euclidean geometry is a branch of mathematics that deals with the study of geometric shapes and their properties in a flat, two-dimensional space. It was developed by the ancient Greek mathematician Euclid and is based on five postulates or axioms.
2. Does Euclidean geometry require initial fine-tuning?
No, Euclidean geometry does not require initial fine-tuning. The five postulates or axioms on which it is based are considered to be self-evident and do not require any additional assumptions or adjustments.
3. What is the significance of Euclidean geometry?
Euclidean geometry is significant because it provides the foundation for many other branches of mathematics and has practical applications in fields such as architecture, engineering, and navigation. It also played a crucial role in the development of modern physics and the concept of space.
4. Are there any limitations to Euclidean geometry?
Yes, there are limitations to Euclidean geometry. It is only applicable to flat, two-dimensional spaces and cannot accurately describe the properties of curved or non-Euclidean spaces. It also relies on certain assumptions that may not hold true in all situations.
5. How does Euclidean geometry relate to other branches of mathematics?
Euclidean geometry is closely related to other branches of mathematics, such as algebra and calculus. It provides a geometric interpretation of algebraic equations and can be used to solve problems in calculus, such as finding the area under a curve. It also forms the basis for more advanced branches of geometry, such as differential geometry and topology.
  • Cosmology
