Does every object have capacitance?
  • Thread starter stingray191
  • Tags
    Capacitance
In summary, every object has the potential to have capacitance, as long as it is either non-conductive or electrically isolated from other objects. This is because capacitance is the ability to hold an electric potential different from the objects near it. While capacitance is typically associated with two conducting objects in close proximity, it can also exist in other situations, such as with non-conductive objects or in an isolated environment. Humidity, materials, and other factors can affect the capacitance of an object. The measure of capacitance is important in understanding and planning for potential problems or uses of electrical potential.
stingray191
Does every object have a capacitance associated with it? For example, is there a capacitance in a single wire or a chair? If so, can you please explain why because I was taught that capacitance is associated with two conducting objects. Thank you.
If an object can be charged then it has capacitance defined by the equation C=Q/V.Here Q is the charge and V the potential.Capacitance is usually associated with two conducting objects in close proximity because the capacitance of isolated objects is extremely small.
My understanding is:
capacitance is the ability to hold an electric potential different than the electic potential of objects near it.
In that case, all objects have the potential to have capacitance, they just need to either; a) be non-conductive or b) be electrically issolated from the other object.
Items that are non-conductive (relatively) still bleed charge, just a lot slower, so the difference is noticable.
Take a CRT screen. The electron beam coming from the back charges the screen (glass) makign a noticable field. It feels a little like fur. If a little fabric softner is sprayed on the CRT, that field dissipates.
The same thing happens with cloths.
Humid air can conduct charges easier than dry air. This is the reason you can shock people with static electicity easier in the winter. Heating air reduces its humidity meaning it takes longer for a static charge to dissipate. The discharge when you zap someone is the equalizing of capacitance.
Another way of saying this is:
Capacitance is the measure of how much electrical potential difference an object can hold in reference to another object.
This applies to all objects.
You see capacitance discussed in conductors more often because that is where capacitance causes the most problems. Conductors will induce a charge in another conductor this induced charge can cause problems if not planned for or can be used if planned for.
The capacitance between two concentric conducting shells of radius b and a, b>a, is
C = 4 pi e0 ab/(b-a)
so the capacitance of a 5-cm radius sphere in a 5 meter radius room (with grounded plumbing, wires, etc in the walls) is about 5.5 picofarads. So everything does have some capacitance to something.
Bob S
FAQ: Does every object have capacitance?
What is capacitance?
Capacitance is the ability of an object to store electrical charge.
Yes, every object has capacitance to some degree. However, the amount of capacitance can vary greatly depending on the material and shape of the object.
How is capacitance measured?
Capacitance is measured in units called farads (F). This unit represents the amount of charge that can be stored per unit of voltage.
What factors affect the capacitance of an object?
The capacitance of an object is affected by its surface area, distance between plates, and the material between the plates. The greater the surface area and the closer the plates are together, the higher the capacitance will be.
Why is capacitance important in electronics?
Capacitance is an important concept in electronics because it allows for the storage and release of electrical energy. This is crucial in many electronic devices, such as capacitors, which are used to store energy and regulate the flow of electricity.
