Does f(x) = kx^2 - (6k-5)x + 8k + 7 pass through (a,b) and (c,d)?
  • Thread starter gerimis
  • Tags
    Function
In summary, Homework Statement f(x) = kx^2 - (6k-5)x + 8k + 7 always passes through (a,b) and (c,d). So, b + d = …if f(x) passes through (a,b) then you know:b=k*a2 - (6k-5)a + 8k + 7do you see how this helps?if f(x) passes through (a,b) then you know:b=k*a2 - (6k-5)a + 8k + 7do you see how this helps?Ya, but I am still not understand
gerimis
Graphic Function f(x) = kx^2 - (6k-5)x + 8k + 7 always pass through (a,b) and (c,d). So, b + d = …
Ya, but I am still not understand, because the answer is Real Number.
do what i did to b with d and add them both together, you will end up with a real number in terms of a,c, and k
I got:
b + d = k(a² + c²) - {(6k - 5)*(a + c)} + 16k + 14
And i don't know what I've to do with that. :D
that is a solution
I don't understand :(
Because the answer options:
A. 19
B. 24
C. 29
D. 34
E. 39
Do you know anything about k that would restrict it beyond "an element of the reals?"
My sense is that there is some information missing. gerimis, are you sure you've provided all the information here?
No, i don't...
I have tried to use Discriminant D>0, but i don't still get the 'k'.
You can't possibly get an answer that doesn't depend on some of the variables. This is because, say we gave even more information such as the points are (-1,b) and (1,d) so we don't have a and b anymore and the quadratic is y=kx2 then we will still have the value of b+d being dependant on the value of k in the quadratic. We have b+d=2k so if k=1, then the quadratic y=x2 passes through (-1,1) and (1,1) so b+d=1+1=2. If k=2, b+d=4 etc.
The problem is saying that for any value of k, the function defined by f(x) = kx^2 - (6k-5)x + 8k + 7 passes through the points (a, b) and (c, d). This means that f(a) and f(c) do not depend on the value of k.
Now, rewriting f(x) as k(x^2 - 6x + 8) - 5x + 7, what must be true of a and c, for f(a) and f(c) not to depend on the value of k?
Yes they do...
Mentallic said:
Yes they do...
There are two specific numbers a and c for which they do not. Look at the equation f(x) = k(x^2 - 6x + 8) - 5x + 7 again.
Oh yes I just skimmed over your second paragraph. That specific quote however is incorrect because you cannot make that false conclusion. As you said, there are specific values of a and c such that b+d is independent of k. Maybe this is what was required of the OP?
I agree that the phrasing "for any value of k", implies that the values of a, b, c, and d must not depend on k. If that is true then we must have,
taking k= 0, [itex]b+ d= 5a- 5c+ 14[/itex]
taking k= 1, [itex]b+ d= a^2+ c^2- a- c+ 30[/itex]
taking k= -1, [itex]b+ d= -a^2- c^2+ 21a+ 21c- 2[/itex]
taking k= 2, [itex]b+ d= 2a^2+ 2c^2- 27a- 27c+ 46[/itex]
That gives 4 equations to solve for a, b, c, and d. Since the question only asks for b+ d you may not have to solve completely.
For example, adding the second and third equation gives [itex]2(b+ d)= 19a+ 19c+ 28[/itex] while adding twice the third equation to the fourth gives 2(a+ b)= 14a- 14c+ 42. Those, together with b+ d= 5a- 5c+ 14 may allow you to solve for b+ d directly.
FAQ: Does f(x) = kx^2 - (6k-5)x + 8k + 7 pass through (a,b) and (c,d)?
What is a function in science?
A function in science is a mathematical relationship between two or more variables that describes how one variable changes as the other variable(s) change. It is often represented by an equation or graph.
What is the purpose of a function in scientific research?
Functions are used in scientific research to model and understand complex systems and phenomena. They allow scientists to make predictions and test hypotheses about how different variables affect one another.
How do you identify a function in a scientific study?
A function can be identified in a scientific study by looking for a mathematical relationship between two or more variables. This can be represented by an equation or graph, and the variables should have a cause-and-effect relationship.
What are the different types of functions in science?
There are several types of functions used in science, including linear, quadratic, exponential, logarithmic, and trigonometric functions. Each type has a specific shape and behavior that can be used to describe different phenomena.
How do scientists use functions to make predictions?
Scientists use functions to make predictions by inputting known values for one variable and using the function to calculate the corresponding values for the other variable. These predicted values can then be compared to actual data to test the accuracy of the function.
