Does Gravity Deflect Light according to Newtonian Mechanics?
In summary, according to Newtonian mechanics, the trajectory of light is not affected by gravity. However, General Relativity predicts that light is deflected by gravity by a small amount.
Logic314
I have read in several popular physics texts that general relativity predicts that gravity deflects light, but that Newtonian mechanics, in contrast, predicts that the trajectory of light is not affected by gravity. However, I am very skeptical and confused about this result.
We of course have the common famous result of Newtonian mechanics, which states that objects of different masses all accelerate the same way under the same local gravitational field (this is the basis for the experimental fact that a feather and a rock fall at nearly the same acceleration inside a vacuum chamber).
But if this is indeed what Newtonian mechanics predicts (that is, if the acceleration in a local gravitational field really is independent of the mass of the particle, according to Newtonian mechanics), then Newtonian mechanics should predict that light has the same acceleration as a rock does within the same local gravitational field, despite the fact that they have different masses (one being nonzero and the other being 0), and thus, Newtonian mechanics should predict that gravity bends light.
So, I'm very confused about why popular physics textbooks seem to emphasize that Newtonian mechanics predicts that light is unaffected by gravity, even though this seems to contradict the general principle from Newtonian gravity theory (that the way objects accelerate under the influence of gravity does not depend on their masses).
Science news on Phys.org
The primary difference between Newtonian Mechanics and the predictions of General Relativity when it comes to light paths is the curvature of the shape of space. Specifically, light from a star is deflected twice as much by passing close to the sun than would be predicted by extending Newtonian mechanics to assume that light was accelerated by the same amount as material objects. This can be accounted for by noting that in GR the shape of a ruler or any locally rigid object would be slightly curved relative to a practical coordinate system suitable for describing orbits. Relative to local rulers, material objects and light are both accelerated at the same rate, but when the curvature of space is taken into account, there is an additional coordinate acceleration due to the effect of the curvature of space on anything moving rapidly, roughly equal to ##g v^2/c^2##, where ##g## is the Newtonian acceleration, so for light moving tangentially at ##c## relative to the direction of the source the effective acceleration relative to the coordinates is twice the Newtonian acceleration.
That is my opinion also, and your rationale is the same as mine too.
I don’t think there is any official governing board to settle the issue, so I would not recommend arguing about it or pushing it. But you have company.
The caveat here is the the the force causing the acceleration is
$$ F_g = \frac{GMm}{r^2}$$
thus we can argue that since acceleration is F/m, the acceleration of m is
$$ a_g = \frac{GM}{r^2} $$
and Ag is independent of the value of m.
However, if m=0 then
$$ F_g = \frac{GM(0)}{r^2} = 0 $$
and Ag = 0/0.
So the actual rule is, the acceleration of m is independent of the value of m,as long as m does not equal zero.
Of course, there is no rule that light must have a mass of zero in Newtonian physics, so gravity could have an effect if you assume a non-zero mass.
If you do a calculation using Newtonian orbital mechanics for an object following a hyperbolic orbit around the Sun, just skimming the surface at perihelion and with an initial velocity of c, you end up with a deflection angle just 1/2 that predicted by Relativity (using a quick and dirty method*, I got an estimate of 0.875 arcsec, which is just a tad more than 1/2 the 1.7 arcsec predicted by Relativity.)
* I used the perihelion distance instead of b ( the impact parameter) in an equation. The impact parameter is the closest approach the object would have made to the Sun if its trajectory hadn't been altered by gravity. Thus is will be more than the perihelion distance. Substituting perihelion for b will give a larger answer for the deflection, but for an object moving at c, the difference between impact parameter and perihelion will be small. Small enough that it won't badly effect an "order of magnitude" estimate like this.
Logic314 said:
I have read ..
You might have a look at this for a mathematical treatment of particles passing by a large object, such as a star, or even a black hole.
https://mathpages.com/rr/s6-03/6-03.htm
A confusing part is that light speed is a constant in all reference frames.
Measuring the speed of light from the rock or feather, or from the release point, or from the surface of the earth, should yield c in all cases. If light accelerates according to Newtonian mechanics, and if light is to be treated as a particle, we should measure something greater than c as light falls to the surface. Instead, the energy loss or gain of light moving in a gravitational field is attributed to a change in frequency, rather than a change in kinetic energy which the particles with mass experience ( particles with mas can never travel at c ). And we thus keep our cherished light always travels a c.
Related to Does Gravity Deflect Light according to Newtonian Mechanics?
1. Does gravity affect the path of light according to Newtonian mechanics?
According to Newtonian mechanics, gravity does not affect the path of light. Light is considered to be a massless particle and therefore does not experience the force of gravity. This theory is also supported by the fact that light travels in a straight line in a vacuum, unaffected by gravitational pull.
2. How does Newtonian mechanics explain the bending of light in the presence of massive objects?
In Newtonian mechanics, the bending of light is explained by the concept of gravitational lensing. This occurs when a massive object, such as a star or a galaxy, bends the path of light passing by it due to its gravitational pull. This phenomenon was first predicted by Newton and is still used to explain the bending of light in the presence of massive objects.
3. Is the bending of light due to gravity the same as the bending of light in a medium?
No, the bending of light due to gravity and the bending of light in a medium are two different phenomena. The bending of light in a medium is caused by the change in the speed of light as it enters a different medium, while the bending of light due to gravity is caused by the distortion of space-time by massive objects.
4. Can light be affected by the gravitational force of multiple objects?
Yes, light can be affected by the gravitational force of multiple objects. In this case, the light will follow the path of least resistance, which is determined by the combined gravitational pull of all the objects. This can result in complex bending patterns of light, such as in the case of gravitational lensing.
5. Does Einstein's theory of general relativity provide a different explanation for the bending of light compared to Newtonian mechanics?
Yes, according to Einstein's theory of general relativity, the bending of light is explained by the curvature of space-time caused by the presence of massive objects. This theory provides a more accurate explanation for the bending of light compared to Newtonian mechanics, especially in extreme cases such as black holes.
  • Astronomy and Astrophysics
  • Classical Physics
