Does gravity just emerge out of all the quantum fields?
In summary, Federico Lelli, Stacy S. McGaugh, and James M. Schombert found that Verlinde's emergent gravity does not reproduce the observed data, and that it might be impossible to find the graviton particle, because gravity is so weak.
bbbl67
212
Most research into quantum-gravity is looking for a specific particle, the graviton, to represent the gravitational force at a quantum level. But they also acknowledge that it might be impossible to find the graviton particle, because gravity is so weak. Now, is it possible that we're looking at this all wrong, and it's not impossible to find the graviton because it's so weak, but because it doesn't exist at all?
Quantum Field Theory tells us that all of spacetime is made up of at least 17 different energy fields (represented by the 17 particles of the Standard Model), more if you split up all of the properties of these particles. So it is possible that gravity is just how spacetime reacts to the presence of all of those different types of energy in the same place, but does not itself constitute a real field? In other words, is gravity just the amalgamated field of all of these other fields?
Basically no.
Verlinde sought to reproduce the successes of other modified gravity theories in a variant of his entropy based gravity theories called "emergent gravity" which arises from quantum entanglement.
Unfortunately, "emergent gravity" doesn't reproduce the observed data.
Verlinde (2016) has recently proposed that spacetime and gravity may emerge from an underlying microscopic theory. In a de Sitter spacetime, such emergent gravity (EG) contains an additional gravitational force due to dark energy, which may explain the mass discrepancies observed in galactic systems without the need of dark matter. For a point mass, EG is equivalent to Modified Newtonian Dynamics (MOND). We show that this equivalence does not hold for finite-size galaxies: there are significant differences between EG and MOND in the inner regions of galaxies. We confront theoretical predictions with the empirical Radial Acceleration Relation (RAR). We find that (i) EG is consistent with the observed RAR only if we substantially decrease the fiducial stellar mass-to-light ratios; the resulting values are in tension with other astronomical estimates; (ii) EG predicts that the residuals around the RAR should correlate with radius; such residual correlation is not observed.
Federico Lelli, Stacy S. McGaugh, and James M. Schombert "Testing Verlinde's Emergent Gravity with the Radial Acceleration Relation"(February 14, 2017).
Another study looking at a different set of data with different investigators reaches basically the same conclusion.
It was recently proposed that the effects usually attributed to particle dark matter on galaxy scales are due to the displacement of dark energy by baryonic matter, a paradigm known as emergent gravity. This formalism leads to predictions similar to Modified Newtonian Dynamics (MOND) in spherical symmetry, but not quite identical. In particular, it leads to a well defined transition between the Newtonian and the modified gravitational regimes, a transition depending on both the Newtonian acceleration and its first derivative with respect to radius. Under the hypothesis of the applicability of this transition to aspherical systems, we investigate whether it can reproduce observed galaxy rotation curves. We conclude that the formula leads to marginally acceptable fits with strikingly low best-fit distances, low stellar mass-to-light ratios, and a low Hubble constant. In particular, some unobserved wiggles are produced in rotation curves because of the dependence of the transition on the derivative of the Newtonian acceleration, leading, even in the most favorable case, to systematically less good fits than MOND. Then, applying the predicted transition from emergent gravity in a regime where it should be fully applicable, i.e. in spherical symmetry and outside of the bulk of matter, we show that the predictions for the secular advances of Solar System planets' perihelia are discrepant with the data by seven orders of magnitude, ruling out the present emergent gravity formalism with high confidence.
Aurelien Hees, Benoit Famaey, and Gianfraco Bertone, Emergent gravity in galaxies and in the Solar System (February 14, 2017).
See also here.
Also, keep in mind that the strong force and weak force operate at only very short ranges, and that particles, as their names suggest, are extremely localized. This leaves electromagnetism and perhaps the Higgs field as the only long range fields in the SM and neither is consistent with observed gravity.
Likes bbbl67 and PeroK
I didn't read Verlinde's work in any detail, just what was written in the popular press. Did his work refer to a graviton?
By the definition of what "field" is, the metric tensor is a field: it assigns a value to every point of spacetime.
No. He argued that quantum entanglement of particles at great distances from each other was a cause of gravity. Feel free to read his linked paper.
Likes bbbl67
FAQ: Does gravity just emerge out of all the quantum fields?
What is the relationship between gravity and quantum fields?
Gravity and quantum fields are both fundamental forces in the universe, but they operate on different scales. Gravity is responsible for the macroscopic behavior of objects, while quantum fields govern the behavior of subatomic particles.
How does gravity emerge from quantum fields?
The current theory of gravity, known as general relativity, describes gravity as the curvature of spacetime caused by the presence of mass and energy. Quantum fields, on the other hand, describe the behavior of particles and their interactions. It is still an ongoing research topic to understand how these two concepts can be reconciled to explain the emergence of gravity from quantum fields.
Is gravity a quantum force?
While gravity is not yet fully understood in the context of quantum mechanics, there is evidence to suggest that it may indeed be a quantum force. For example, the existence of gravitons, the hypothetical particles responsible for carrying the force of gravity, is predicted by certain theories that attempt to unify gravity with quantum mechanics.
Can gravity be explained by the Standard Model of particle physics?
No, the Standard Model of particle physics does not currently include a theory of gravity. While the Standard Model has been incredibly successful in explaining the behavior of particles and their interactions, gravity remains a separate entity that has not yet been fully integrated into this framework.
Are there any experiments or observations that support the idea of gravity emerging from quantum fields?
There have been attempts to detect the effects of gravitons and other quantum aspects of gravity, but so far there is no conclusive evidence to support the idea of gravity emerging from quantum fields. This is an active area of research in theoretical physics and may require more advanced technology and experiments to fully understand.
