Does high electronegativity mean low electropositivity?
In summary, electronegativity and electropositivity are opposite terms that reflect opposite properties. Generally, being high in one means being low in the other. However, while there are quantitative definitions for electronegativity, there is not a clear definition for electropositivity. A reaction between HCl and NaCl to create Cl2 and NaH is unlikely to occur, but if it does, it would depend on the ratio of reactants. It is important to consider multiple factors, such as bond type and stability of products, when predicting if a reaction will occur. There is not a comprehensive list of known reactions between compounds, as there are countless possibilities and it is difficult to accurately predict without taking into account many details.
ProjectFringe
96
I understand that electronegativity and electropositivity are opposite terms, but does being high in one mean you are low in the other?
I saw that HCl will react with NaCl to create Cl2 and NaH. I believe that Cl has the greatest electronegativiy (willingness to attract an electron). So wouldn't it stay bonded to H and Na, which are less electronegative (assuming that means H and Na are more electropositive)?
So why does Cl bond to the other Cl? Does it have to do with the type of bond or some other factor in this reaction, and if so, is there an order of operations to consider when determining whether a reaction will occur (e.g. 1. bond type, 2. electronegativity, 3. etc.)?
Chemistry news on Phys.org
By definition they reflect opposite properties so yes, that's what I would expect. But while I have seen quantitative definition of the electronegativity (actually several definitions, wikipedia lists at least some them), I don't think I have ever seen a definition of electropositivity. Probably one can be easily proposed by extending the ideas already used with the electronegativity, but my bet is electropositivity is such an obscure term it is not worth it.
Will it? I haven't seen such a reaction.
Likes ProjectFringe
Looks to me like an automatically created database of everything, having nothing to do with the reality.
Likes ProjectFringe
:cry:I guess studying using the internet doesn't work, which is why talking to a real person is really helpful.
Anyways, thanks for all your help!:biggrin:
Likes BillTre
So, just to be clear. Is there no reaction between HCl and NaCl? How can I know if a reaction will occur?
Is there any disassociation or maybe transfer of Cl- ions between HCl and NaCl?If the answer is no reaction, then can we assume Cl2 + NaH will result in HCl and NaCl? How can we know if this reaction will occur?
No reaction for all practical purposes.
This is more or less what chemists learn - how to predict what will/can happen. No shortcuts, you need to accumulate a lot of knowledge (and even then you will be occasionally surprised by the reality, there are always many convoluted, interleaved and antagonistic effects affecting the final outcome).
When you dissolve both they dissociate, Cl- from both sources are identical and there is no way which came from which compound.
See above - it is not trivial and may depend on conditions. HCl and NaCl seem to be the most likely outcome, as these are very stable compounds (and stability of products is always one of the main driving forces responsible for the reaction outcome).
Likes ProjectFringe
Got it! Thanks again :bow:
Is there anywhere you can go to see a list of 'known' reactions between compounds? Like the website I found before, but with real reactions...
Depending on ratio of reactants, though.
If Cl2 is in excess then, yes, NaCl+HCl, because neither of them reacts with Cl2.
If, however, NaH is in excess then NaH does not react with NaCl, but readily reacts with HCl:
NaH+HCl=NaCl+H2
total
2NaH+Cl2=2NaCl+H2
Likes ProjectFringe
Good point.
And a good example of why it is often difficult to precisely predict what will really happen without taking into account thousands of details.
Likes ProjectFringe
That would be a very long list and it would never be complete. But typical reactions are usually listed in sources for the individual compounds (e.g. chemistry textbooks or Wikipedia). For example the French Wikipedia entry for NaH includes the above mentioned reaction with HCl.
Likes ProjectFringe
FAQ: Does high electronegativity mean low electropositivity?
What is electronegativity?
Electronegativity is a measure of an atom's ability to attract electrons towards itself in a chemical bond.
How is electronegativity related to electropositivity?
Electropositivity is the opposite of electronegativity, and it refers to an atom's ability to donate electrons in a chemical bond. Therefore, high electronegativity means low electropositivity, and vice versa.
What is the significance of high electronegativity?
High electronegativity can indicate a stronger pull on electrons, making the atom more likely to form covalent bonds and less likely to donate electrons. It can also affect the polarity of a molecule and its reactivity in chemical reactions.
How is electronegativity measured?
Electronegativity is measured on the Pauling scale, which assigns a numerical value to each element based on its chemical properties and bonding behaviors.
Can an atom have both high electronegativity and high electropositivity?
No, an atom cannot have both high electronegativity and high electropositivity. These two properties are inversely related and cannot both be high at the same time.
