Does hybridisation only occur with Carbon?
In summary, hybridization occurs when orbitals of two atoms overlap. This can happen with most atoms, but is most frequently seen with carbon because it has a large number of hybridized orbitals.
Roroy
I've been studying how hybridisation works, and in very single example I've come across, there is always Carbon as the atom that undergoes hybridisation. But this can't be right, can it?
I mean, Nitrogen can form triple bonds, Oxygen can form double bonds, etc.
I'd assume then that Nitrogen gets sp hybridised and Oxygen gets sp2 hybridised?
Is this correct?
Chemistry news on Phys.org
Hybridization can occur with most atoms. For instance, the nitrogen in NH3 is sp3 hybridized. The reason we tend to focus on carbon is because hybridization plays such an important role in understanding bonding in organic chemistry.
Likes DrClaude
Is this correct?
Hybridization is not related to the number of bonds, but the spatial geometry of those bonds.
The only place where hybridization occurs is in our minds. You can describe nitrogen compounds with or without hybridized orbitals on N. The results are mostly very similar. It is also possible to describe bonding in ethylene using so called banana bonds made from sp3 hybrids on C.
For oxygen, hybridization becomes quite unfavourable due to the huge energy difference between 2s and 2p orbitals.
Hybridization is a term that surfaces in explaining the transitions that occur at the valence level during molecular bonding giving 'Molecular Compounds'. This event can theoretically be applied to any nonmetal element, but is most frequently applied to Carbon, Nitrogen, Oxygen and the Halogens. However, the principles can be applied to Silicon, Phosphorous, & Sulfur. The concept of hybridization can be found in most freshman level general chemistry textbooks in the chapters on Molecular Geometry under the Valence Bond Theory. Here's a post entered on 9/14/2016 on Hybridization, maybe this will help... https://www.physicsforums.com/threads/why-does-hybridization-occur.885346/#post-5570100 => Dr Pelezo 9/14/2016. Hope this helps.
What stops it from being applied to metals?
Nothing, although I think that despite Paulings resonating VB theory of metals, VB theory is more appropriate for non-metals than for metals, which are better described in terms of MO theory. The reason is that in metals both ionisation energies and electron affinities are small, so that generating ionic contributions in covalent bonds is energetically neutral in metals, but disfavoured in non-metals. MO theory includes these ionic configurations automatically, while you need many resonance structures to include them in VB. In covalent non-metal compounds, the ionic structures are suppressed whence VB gives often a better description.
Actually, nothing ... Be and B, using the Valence Bond Theory, are hybridized to sp and sp2 orbitals to generate linear and trigonal planer geometries respectively to accommodate formation of compounds like BeX2 and BX3 where X = Halide. For Gp IA metals, showing hybridization would mean showing an s-orbital changing into a paramagnetic hybridized orbital which overlaps with a paramagnetic orbital of the non-metallic anionic fragment to generate the diamagnetic bonded pair. Ionization would then be based upon a highly polarized system that undergoes 'heterolytic bond clevage'. Such, in my humble opinion, seems to be over-kill for describing a simple process. There might be circumstances/studies where such would give a better understanding of the process. I guess it would be more accurate to say (in my post) that hybridization is 'most frequently' applied to nonmetallic elements in molecular compounds or polyions; but both the valence structure of the cation metal and anion nonmetal fragments could (and, maybe should) be shown to be hybridized to accommodate the bonding process being described.
Likes Greg Bernhardt
Whatever a paramagnetic orbital may be...
Are you asking what is paramagnetic? If so, in an unbonded hybrid orbital, containing only 1 electron is said to be paramagnetic. When two paramagnetic orbitals overlap, a covalent bond is formed containing paired electrons (the more stable configuration). The pairing of the electrons for the purpose of forming a bond between two elements is referred to as diamagnetic. Diamagnetic stability (paired electrons) is greater than paramagnetic stability and is the most fundamental driving force in the process of chemical bonding.
At best, the electron is paramagnetic, but not the orbital.
An orbital is the character of the electron and the electron the character of the orbital. Such is defined by the electron's quantum state within the element. Such gives rise to the 4 quantum numbers that define the nature of a given electron and associated orbital character. In the ground state configuration the electrons can have 'known' orbital geometries defined by s, p, d, & f configurations. When bonding takes place the quantum states of the valence electrons transform into orbital configurations that accommodate electron pairing. The terms used to describe an orbital containing one electron is paramagnetic (which does mean the electron is paramagnetic), but after bonding;i.e., the pairing of the electrons forms a diamagnetic condition and the sigma bond, assuming symmetry exists about the nuclei undergoing bonding.
Consider BeCl2 ...
Do you have a reference for this terminology?
The following notes are from Ebbing & Gammon; General Chemistry, 9th edn., Houghton Mifflin Co, New York, Copyright 2009; pgs 309 - 311. Also see Glossary in same edition.
FAQ: Does hybridisation only occur with Carbon?
1. Does hybridisation only occur with Carbon?
No, hybridisation can occur with other elements as well, such as nitrogen, oxygen, and sulfur. However, carbon is known for its ability to form a wide variety of compounds through hybridisation, making it a commonly studied element in this context.
2. What is hybridisation?
Hybridisation is a process in which the atomic orbitals of an atom mix to form new hybrid orbitals with different shapes, energies, and bonding properties. This allows for the formation of more stable compounds.
3. How does hybridisation affect the properties of a molecule?
Hybridisation can affect the geometry, bond angles, and bond lengths of a molecule, which in turn can influence its physical and chemical properties. For example, molecules with sp3 hybridisation tend to have a tetrahedral shape, while those with sp2 hybridisation have a trigonal planar shape.
4. Can hybridisation explain the bonding in all molecules?
No, hybridisation is just one model used to explain the bonding in molecules. Other models, such as molecular orbital theory, also play a role in our understanding of chemical bonding.
5. How is hybridisation determined experimentally?
Hybridisation can be determined through various experimental techniques, such as X-ray crystallography, NMR spectroscopy, and electron diffraction. These methods provide information about the arrangement of atoms in a molecule, which can then be used to determine the hybridisation of the central atom.
16K
