Does integration give area between graph and x axis?
In summary, when calculating the area between a curve and the x-axis, it is important to consider the implicit assumption that the curve is above the x-axis. The definite integral from a to b calculates the area of a region bounded by the vertical lines x=a and x=b, the horizontal line y=0, and the graph of the function. Any areas below the x-axis are counted as subtractions from the total area, and the entire area will be negative if the entire graph is below the x-axis.
CAH
48
Does integrating find the area between the curve and x-axis (regarless of it being a smile/frown or any other graph)?
I've heard people say its the area UNDER a curve...
but then how would you even get a definit answer surely it may be infinite if there's no restrictions?
Thanks
Mathematics news on Phys.org
When people call it the area "under a curve", there is still the implicit assumption that it is above the x axis.
For a definite integral from a to b, you would be calculating the area of a region bounded as follows:
On the left by the vertical line defined by x=a
On the right by the vertical line defined by x=b
On the bottom by the horizontal line defined by y=0
On the top by the graph of the function.
Note that if the curve is below the x-axis then this area is counted with a minus sign
If it's below the x-axis is it calculating the area above the curve, between the curve and the x-axis above it
As jk22 pointed out, the areas of any regions where the graph is below the x-axis count as subtractions from the total area, not as additions. If the entire graph is below the x-axis then the entire area will be counted as negative.
But yes, other than this concern about the sign of the result, it is calculating the area above the graph and below the x axis.
FAQ: Does integration give area between graph and x axis?
1. What is integration?
Integration is a mathematical concept that involves finding the area under a curve or between two curves on a graph. It is also known as the reverse process of differentiation.
2. How does integration give the area between a graph and the x-axis?
Integration calculates the total area under a curve by dividing the curve into small, infinitely thin rectangles and summing up their areas. This process gives an accurate estimation of the area between a graph and the x-axis.
3. Is integration always accurate in finding the area between a graph and the x-axis?
Integration is a precise method for calculating the area between a graph and the x-axis, as long as the function is continuous and well-behaved. However, there may be some limitations in certain cases, such as when the function has sharp corners or discontinuities.
4. Can integration be used for any type of graph?
Yes, integration can be used for any type of graph as long as the function is continuous and well-behaved. It is a fundamental tool in calculus and is applicable in various fields such as physics, engineering, and economics.
5. How is integration related to the concept of area?
Integration is directly related to the concept of area as it is used to calculate the area under a curve or between two curves on a graph. It is a powerful mathematical tool that allows us to find the area of irregular shapes and functions that cannot be easily measured by traditional methods.
