Does Kutta Joukowski Theorem applies to Coanda effect (UAV)?
  • A
  • Thread starter godilocks9999
  • Tags
    Theorem Uav
In summary, the conversation discussed the use of Coanda effect in a UAV and the applicability of the Kutta-Joukowski theorem to this design. The expert noted that the Kutta-Joukowski theorem does not apply to the Coanda UAV due to its different mechanism for lift generation. They also mentioned that the application of lift coefficient is not straightforward for this design and explained the potential challenges in calculating lift using dynamic pressure. The expert also clarified that the Kutta condition does not necessarily have to be met at the trailing edge for the Kutta-Joukowski theorem to be applicable.
godilocks9999
Hi everyone,
I am currently working on a Coanda UAV and I am aware that there's no mathematical model to express the lifting effects of Coanda. It is more of a physical description of airflow movement. Correct me if I am wrong!
Thus, I am using the generic expression of lift to describe the lift forces generated by the UAV. (dynamic pressure*area*coefficient).
However, I am also curious if the Kutta Joukowski theorem can be applied to the Coanda UAV. From what I know KJT is for rotating cylinders and airfoils where Kutta condition must be met at the trailing edge. Coanda UAV doesn't seem to fulfill the requirement for KJT at all. Thus, I am currently presuming that (L=rho*velocity*circulation factor) cannot be applied to Coanda UAV.
Here's a view of my axis-symmetric model of the Coanda UAV. Air will flow from the wireframe immediately above the fuselage skin, on to the top surface of the fuselage and be directed downwards due to Coanda effect.
While I am not 100% familiar with this particular variety of UAV, it does not appear to me that the Kutta-Joukowski theorem would apply. For one, the fundamental mechanism for lift generation is different here. The Kutta-Joukowski theorem applies to two-dimensional shapes (and 3D shapes that can be approximated as such) that operate by essentially setting up a net circulation superposed on the inviscid flow surrounding the object, such as an airfoil.
Really, this looks to me more like the craft uses the Coandă effect to basically bend the exhaust around the body and direct it downward, and it is this downward exhaust that provides "lift". Then you would end up placing some kind of series of vanes around the body to redirect this thrust in a more subtle way to allow forward and backward movement. Essentially, it looks like a fancy method of thrust vectoring that ultimately boils down to something akin to the LiftFan on the F-35, only it uses the Coandă effect to bend the initially non-vertical jet around the body. It isn't even clear to me what advantage this would provide versus a downward-facing fan aside from maybe some more complex thrust-vectoring options.
Application of lift coefficient here would not be straightforward, either. Lift coefficients generally are measured/calculated on shapes that are similar to those that would work just as well in the Kutta-Joukowski paradigm. You may still be able to find a coefficient correlating dynamic pressure (I assume generated by your fan?) to the lift produced, but ultimately I wouldn't be willing to assume that such a coefficient would have the same level of applicability, i.e. I wouldn't guarantee that lift is even proportional to dynamic pressure in the first place. Instead it will likely be some fraction of the downward thrust that would be generated by the fan alone, and you would lose some of that lift due to the angle (relative to vertical) at which the jet leaves the surface at the edge and viscous dissipation along the length of the surface due to both the boundary layer at the wall and the shear layer formed with the free-stream. I'd be surprised if the proportionality with dynamic pressure held in this case.
Really appreciate for the thorough opinion on my queries! With regards to Kutta-Joukowski theorem, it must fulfil the Kutta condition where the flow beneath and atop an airfoil surface meets at the trailing edge?
Not really. The Kutta-Joukowski theorem relates the net circulation around an object moving at a constant speed through a uniform fluid to the lift on that object. Not every object needs to have a sharp trailing edge. For example, a rotating cylinder has no trailing edge but generates lift, which can be calculated using the Kutta-Joukowski theorem. The flow does meet back up somewhere, but not at a traditional trailing edge.
I just don't think Kutta-Joukowski applies to your design because it doesn't fulfill these requirements. It isn't lift generated through movement through the air. It is lift generated by directing thrust downward.
Likes godilocks9999
I would agree with you, I've done test and no lift augmentation was generated when i compare lift results from propeller only configuration and propeller plus coanda fuselage configuration.
The only positive behaviour i observed was that there was lesser lift losses than what i would expect from such a buff object in the wake of the propeller, about 6-8% loss. The skin friction drag should be a big contributor which would cause the latter configuration to differ largely from the 'propeller only' configuration.
which could mean that the coanda effect fuselage is efficient in facilitating the airflow downwards well enough to not cost major lift losses, despite its larger than propeller size. or the widely mentioned effect of air entrainment contributed lift to the aircraft which compensated for the drag loss, but this is hard to confirm experimentally.
Oh yes, I will like to confirm again on the Kutta condition that an flow over an object has to fulfil in order for KJT to be applicable:
Kutta condition is when flow from top and bottom surfaces must meet again?
Well it would be literally impossible for the top and bottom flow over an object to not meet, as there would be a vacuum, so yes, it is a requirement for the Kutta-Joukowski theorem to apply.
Maybe I am just both following what you are trying to describe?
Related to Does Kutta Joukowski Theorem applies to Coanda effect (UAV)?
1. What is the Kutta Joukowski Theorem?
The Kutta Joukowski Theorem is a fundamental concept in aerodynamics that relates the lift generated by an airfoil to its circulation. It states that the lift force is equal to the product of the air density, the airfoil velocity, and the circulation around the airfoil.
2. How does the Kutta Joukowski Theorem apply to the Coanda effect?
The Coanda effect is a phenomenon in which a fluid flowing along a curved surface tends to follow the surface rather than continue in a straight line. The Kutta Joukowski Theorem can be applied to the Coanda effect by considering the curved surface as an airfoil and analyzing the circulation around it to determine the lift force.
3. Can the Kutta Joukowski Theorem be used to predict the lift of a UAV using the Coanda effect?
Yes, the Kutta Joukowski Theorem can be used to predict the lift generated by a UAV that utilizes the Coanda effect. By analyzing the circulation around the curved surface of the UAV, the lift force can be determined and used to predict the overall aerodynamic performance of the UAV.
4. Are there any limitations to the application of the Kutta Joukowski Theorem to the Coanda effect?
While the Kutta Joukowski Theorem can provide a good estimation of the lift generated by a UAV using the Coanda effect, it does have limitations. It assumes that the airfoil is infinitely thin and has a constant circulation. In reality, the Coanda effect is affected by factors such as surface roughness and boundary layer separation, which may not be accurately accounted for by the theorem.
5. How does the Kutta Joukowski Theorem compare to other methods of analyzing the Coanda effect in UAVs?
The Kutta Joukowski Theorem is a simplified method of analyzing the Coanda effect in UAVs, but it is still widely used due to its effectiveness in predicting lift. Other methods, such as computational fluid dynamics (CFD) simulations, can provide more detailed and accurate results but are more time-consuming and resource-intensive.
  • Mechanics
  • STEM Academic Advising
44K
