Does levitation distance increase as Fg increase???
The discussion focuses on an experiment to measure magnetic field strength by analyzing levitation distances between two magnets while varying the mass used to anchor them. The participant uses the formula mg = Fg = Fm = A*B^2/u0, where Fg represents gravitational force and Fm represents magnetic force. They observe an unexpected relationship between gravitational force and levitation distance, questioning why an increase in mass does not lead to a decrease in levitation radius as anticipated. Additionally, they seek clarification on the definition of area (A) in the equation and how levitation distance is incorporated. The conversation highlights the complexities of magnetic and gravitational interactions in experimental setups.
tanmays1
need help with mag lev equation
The formula I am using for this is mg = Fg = Fm = A*B^2/u0 (permeability constant); B = magnetic field strength. Manipulated is Fg, and responding is A (the area).
I'm trying to conduct an experiment where I calculate the magnetic field strength of a magnet, by comparing the levitation distances between two magnets. My experiment involves using different masses to anchor down magnetic repulsion between 2 magnets. Fg = Fm.
The problem is I see a weird relationship between the force of gravity and levitation distance. I assume that as the mass increases Fg increases, therefore, the radius should decrease as well. This isn't true for this equation. Can anyone explain why or suggest a different approach to what I am doing?
What is A the area of, and where does the "levitation distance" feature in your equation?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
