- 1,443
- 191
Does light bend around black holes like a satellite "slingshotting" around Jupiter? If so, would there be a need to recalculate the true positions of stars from all the bending of light around black holes on the way to the telescope?
Yep, it does. Light travels the shortest distance, and the shortest distance is a bend around a black hole.benorin said:Does light bend around black holes like a satellite "slingshotting" around Jupiter? If so, would there be a need to recalculate the true positions of stars from all the bending of light around black holes on the way to the telescope?
I am not sure of that, but I do know black holes have photon rings, which is light that orbits the black hole.benorin said:So is there a configuration of black holes that we could use to see the other side of the earth like shaving the back of your head with mirrors? lol
Well, that depends. If you apply Euclidean Geometry to spacetime (where is does NOT apply), then yes, it curves/bends. If you use the actual geometry of spacetime (pseudo-Reimannian) then it travels in a straight line (a "geodesic").benorin said:Does light bend around black holes like a satellite "slingshotting" around Jupiter?
The gravitational lensing always occcurs. The reason the eclipse was needed was that without it the background stars would be drowned out by sunlight.AlexB23 said:In 1919, during an eclipse of the sun, gravitational lensing occurred, moving the apparent position of the stars. The same concept happens around black holes.
Light can u-turn around one black hole, so one in front and one behind is enough in principle, same as conventional mirrors. But the aberration is horrible and the image will be badly distorted.benorin said:So is there a configuration of black holes that we could use to see the other side of the earth like shaving the back of your head with mirrors? lol
Yes, that is true, I could have elaborated more, as the eclipse was needed so the stars could be visible.Orodruin said:The gravitational lensing always occcurs. The reason the eclipse was needed was that without it the background stars would be drowned out by sunlight.
Classically, Fermat's principle states that light travels between two points along the path that requires the least time. That's not necessarily the path with the shortest distance. In a vacuum it would, however, be a straight line.AlexB23 said:Yep, it does. Light travels the shortest distance, and the shortest distance is a bend around a black hole.
One could use existing known black holes. However, all of those are far enough away that any light you detected (good luck with that after two black hole rim shots on a 3000+ light year round trip) now would have left Earth long before your head existed. Any light emerging from the back of your head now would arrive back at your eyes at a time well after your eyes had ceased to exist.Vanadium 50 said:To turn light completely around so you can see tbe back of your head takes a LOT of mass. This may be theoretically possible but never actually happen,.
Continents move at centimetres per year. There's no meaningful change in 3000 years, even if you could resolve a distorted image at that distance.benorin said:what about a 3000 year old snapshot of the Earth? What would the detail describe? Continents? Would it be valuable from a geological standpoint?
How do you plan to install a mirror 1500 years ago?benorin said:what about a 3000 year old snapshot of the Earth?
Everything is moving relative to everything else, so there's no realistic possibility of light from the Earth naturally returning to Earth.benorin said:@Vanadium 50 read post #12
I don't think you are grasping quite how bad a mirror a black hole is. I would expect that there is a null path connecting the Earth back to itself via orbits around two arbitrarily chosen black holes. But the acceptance angle for light that does a half orbit (give or take) is small, and that light is spread across half the sky after the interaction, not spread over the same angle as before the reflection like you would expect with a mirror. So you're looking at orders of magnitude of dimming on each interaction, even before you worry about accretion discs and any radiation they put out.benorin said:What about spectroscopy at 3000 years old?
Effectively a black hole looks like a circular convex mirror - or rather a series of concentric such mirrors.Ibix said:I don't think you are grasping quite how bad a mirror a black hole is. I would expect that there is a null path connecting the Earth back to itself via orbits around two arbitrarily chosen black holes. But the acceptance angle for light that does a half orbit (give or take) is small, and that light is spread across half the sky after the interaction, not spread over the same angle as before the reflection like you would expect with a mirror. So you're looking at orders of magnitude of dimming on each interaction, even before you worry about accretion discs and any radiation they put out.
I'm not quite sure what you are imagining here. I would expect that if you were perfectly aligned between the sun and a non-rotating black hole, you could (in principle) see a ring of sunlight around the hole, because I think there's an infall approach that causes light to u-turn. Verifying that is relatively straightforward, although numerical integration is needed. You just have to see what an open orbit grazing the photon sphere does: if it's at least a 180 degree turn then you can get back-scattered light from some infall.snorkack said:Effectively a black hole looks like a circular convex mirror - or rather a series of concentric such mirrors.
Right. Maybe a logical approach would be to start from a bundle of parallel rays travelling towards a Schwarzschild black hole, and figure out their fate. You could mark the rays, for example with wavelength (gravitational deflection of electromagnetic waves should be independent of wavelength so long as it is much smaller than Schwarzschild radius) and the setup has axial symmetry around the path directly to singularity.Ibix said:I'm not quite sure what you are imagining here. I would expect that if you were perfectly aligned between the sun and a non-rotating black hole, you could (in principle) see a ring of sunlight around the hole, because I think there's an infall approach that causes light to u-turn. Verifying that is relatively straightforward, although numerical integration is needed. You just have to see what an open orbit grazing the photon sphere does: if it's at least a 180 degree turn then you can get back-scattered light from some infall.
Working out how much power is returned is rather harder, because you need to think about ray bundles and how they spread. In principle that's easy, but I suspect it's very sensitive to how good your numerical integration is, because the angles are so small.
Are there circles that reflect the Sun behind the viewer? As explained, they have to be outside the optical edge ((√27)/2*R), but there must be infinitely many of them, converging to the optical edge of the hole.Orodruin said:On this topic, here is an animation I created some years back. It shows how an idealised Schwarzschild black hole would bend the (far) background - here represented by a star map based on Earth's location. The animation shows how the view would look for a stationary observer and the elapse of the video represents different positions of that observer.
The black circle in the middle represents the optical size of the black hole, i.e., if you send a light signal in that direction, it will end up inside the black hole. By time reversal, no light can come from that direction (unless emitted by something in between the black hole and the observer). The yellow circle is an Einstein ring - it is light from an object that is directly behind the black hole (in this case Sadalmelik, aka ##\alpha##-Aquarii).
Those would not be visible at this resolution.snorkack said:Are there circles that reflect the Sun behind the viewer? As explained, they have to be outside the optical edge ((√27)/2*R), but there must be infinitely many of them, converging to the optical edge of the hole.
I am not sure about the resolution mattering here. Sun is very bright compared to stars.Orodruin said:Those would not be visible at this resolution.
And the exponent:In Fig. 2 the results can be seen for positive (where the angle ϕ is the unwrapped deflection angle) and negative perturbations (with the angle ϕ being defined as the angle orbited around the black hole at the time when photons cross the event horizon). For large perturbations (|δ0|>10−2) the relationship between angle and distance is not simply exponential. However in the small perturbation regime (|δ0|<10−2) a tight exponential relationship is visible.
At 1π (which is backscattering), a small deviation from exponential line is visible.Inverting this expression for δ0 implies that to achieve another orbit requires being a factor of f=e2π=535.60±0.45 closer to the optical edge of the black hole.
The Sun is not in the image … it is a projection of background stars only.snorkack said:Sun is very bright compared to stars.
The light from Earth obviously naturally returns to Earth, and that despite everything moving. Look at earthlight on Moon at crescent Moon. It is there despite Moon orbit.PeroK said:Everything is moving relative to everything else, so there's no realistic possibility of light from the Earth naturally returning to Earth.
Solar irradiance is about ##1.4\mathrm{kWm^{-2}}##, so about ##60\mathrm{\mu W}## falls on your annulus. Bear in mind that this is spread across half the sky (from 90 to 270 degrees deflection) if I'm following your argument, so the inverse square law at 400,000km takes this to something like ##6\times 10^{-23}\mathrm{Wm^{-2}}## at Earth's surface, or about magnitude 36.snorkack said:So, 0,02 mm wide reflective ring with inner diametre 0,52 mm, and outer diametre 0,56 mm. How bright do you figure it is? How much detail does reflection in it show?
It depends upon how good your telescope is. For example, you can see huge numbers of stars with the James Webb Space Telescope in places where inferior older telescopes saw nothing but black emptiness. It would not be valuable from a geological stand point, because it would be distorted and because there are much less cumbersome ways to accurately make the same determinations.benorin said:what about a 3000 year old snapshot of the Earth? What would the detail describe? Continents? Would it be valuable from a geological standpoint?
Distortion would not be inherent problem because gravity of black hole would act like a smooth curved mirror - mere geometric distortions could be interpreted.ohwilleke said:It depends upon how good your telescope is. For example, you can see huge numbers of stars with the James Webb Space Telescope in places where inferior older telescopes saw nothing but black emptiness. It would not be valuable from a geological stand point, because it would be distorted and
No, light bends inside event horizon of black holes. So it won't affect our observation. Even light can't escape black holes immense gravity.benorin said:Does light bend around black holes like a satellite "slingshotting" around Jupiter? If so, would there be a need to recalculate the true positions of stars from all the bending of light around black holes on the way to the telescope?
Gravitational lensing around stars has been observed, and it could also be seen near black holes. It's just not an effect that makes much difference to our astronomical observations unless we specifically go looking for it.L Drago said:No, light bends inside event horizon of black holes. So it won't affect our observation. Even light can't escape black holes immense gravity.
