Does ln(x - √(1 + x^2)) really have a real part?
  • MHB
  • Thread starter SweatingBear
In summary: No, the outputs of the inverse hyperbolic sine function cannot be interpreted as areas. The area interpretation only applies to the outputs of the inverse hyperbolic functions that have the "ar" prefix (such as arsinh). The outputs of the inverse hyperbolic sine function (sinh^-1) do not have this prefix and therefore cannot be interpreted as areas.
SweatingBear
119
Hello forum. In my studies of hyperbolic functions, I stumbled upon this guy
\(\displaystyle \ln \left( x - \sqrt{1 + x^2 } \right) \, .\)
Trying different values for \(\displaystyle x\) in my head, I confidently concluded that this function does not have any outputs in the real numbers. I attempted to plot it in Maple but Maple showed me a blank coordinate system (expectedly). However, this is what WolframAlpha outputs.
It looks like a flipped hyperbolic sine, but is WolframAlpha even displaying correctly to begin with?
You require that \(\displaystyle \displaystyle \begin{align*} x - \sqrt{ 1 + x^2} > 0 \end{align*}\), so
\(\displaystyle \displaystyle \begin{align*} x - \sqrt{ 1 +x^2} &> 0 \\ x &> \sqrt{1 + x^2} \\ x^2 &> 1 + x^2 \\ 0 &> 1 \end{align*}\)
This is an obvious contradiction, so that means you are correct, there is no real part to this...
It is immediate to verify that...
$$\ln (x - \sqrt{1+x^{2}}) = \ln \{-1\ (\sqrt{1+x^{2}} - x)\} = \ln (\sqrt{1+x^{2}} - x) + \pi\ i\ (1)$$
... so that the plot of 'Monster Wolfram' is perfectly plausible... Kind regards$\chi$ $\sigma$
In studying hyperbolic functions, you may have come across the fact that inverse hyperbolic functions can be expressed as logarithms. In particular, $\sinh^{-1}x = \log\bigl(\sqrt{1+x^2}-x\bigr)$. Your logarithm has the negative of that one, so $$\log\bigl(x-\sqrt{1+x^2}\bigr) = \log\bigl((-1)\bigl(\sqrt{1+x^2}-x\bigr)\bigr) = \log(-1) + \log\bigl(\sqrt{1+x^2}-x\bigr) = i\pi + \sinh^{-1}x.$$ That agrees with the WolframAlpha output.
@chisigma, Opalg: Ok, but nevertheless, the function clearly cannot have a real part as WolframAlpha purports?
Let us say the following :
\(\displaystyle \ln(z_1 z_2) = \ln(z_1)+\ln(z_2) \)
Proof :
\(\displaystyle \ln(z_1 z_2) = \ln|z_1z_2|+ i \arg(z_1z_2) =\ln|z_1z_2|+ i arg(z_1)+i \text{arg}(z_2) \)
\(\displaystyle \ln|z_1|+i \text{arg}(z_1) + \ln|z_2|+ i \text{arg}(z_2) = \ln(z_1)+\ln(z_2) \, \square \)
Generally this is not true in the case of principle logarithm
\(\displaystyle \text{Log}(z_1 z_2) \neq \text{Log}(z_1)+ \text{Log} (z_2) \)
\(\displaystyle \text{Log}(z_1 z_2) = \ln|z_1 z_2| + i \text{Arg}(z_1 z_2) \)
Now in order to be able to do that we must have
\(\displaystyle -\pi < \text{Arg}(z_1 z_2) \leq \pi \)
That means using polar coordinates
\(\displaystyle -\pi < \theta_1 \,+\theta_2 \leq \pi \)
\(\displaystyle \text{Log}(-1 \cdot -1) =0 \)
\(\displaystyle \text{Log}(-1 \cdot -1) \neq \text{Log}(-1) + \text{Log}(-1) = 2i\pi \)
This is completely justifiable since \(\displaystyle \text{Arg(-1)}+\text{Arg(-1)}= 2\pi \)
In contrast that example might work perfectly if we use another branch cut i.e. \(\displaystyle \text{Log}_{0}\)
But I still cannot get why W|A draws the imaginary part near 3 , it should be at an integer , does anybody know ?
WA interprets the logarithm as a complex-valued function and evaluates it as $ i\pi + \sinh^{-1}x$ (see my previous comment). It then renders the real part as $\sinh^{-1}x$ (the blue curve in the WA plot) and the imaginary part as the constant $\pi$ (the orange line in the plot).
That was stupid of me :eek: , I completely discarded \(\displaystyle \pi\) !
So if we take the principle logarithm \(\displaystyle \text{Log}(z) \)
\(\displaystyle \text{Log}\left(-1 \cdot (\sqrt{x^2+1} -x ) \right)\)
Now since \(\displaystyle -\pi < \text{Arg}\left(-1 \cdot (\sqrt{x^2+1} -x) \right) \leq \pi \)
We can rewrite it as
\(\displaystyle \text{Log}\left(-1 \cdot (\sqrt{x^2+1} -x ) \right) = \text{Log}\left(-1 \right)+\text{Log}\left( \sqrt{x^2+1} -x \right)\)
\(\displaystyle \text{Log}\left(-1 \right)= \ln|1|+ i\pi = i\pi \)
\(\displaystyle \text{Log}\left(\sqrt{x^2+1} -x\right) = \ln \left|\sqrt{x^2+1}-x \right|+i 0 = \ln \left( \sqrt{x^2+1}-x \right)\)
Hence we have :
\(\displaystyle \text{Log}\left(x-\sqrt{x^2+1}\right) = \ln \left( \sqrt{x^2+1}-x \right) + i\pi \)
@Opalg: Is not WolframAlpha plotting \(\displaystyle \text{arcsinh} (-x)\) as opposed to \(\displaystyle \text{arcsinh} (x)\)?
Yes. Naturally, WA is right and I was wrong. The logarithm form of $\sinh^{-1}x$ is $\ln\bigl(\sqrt{1+x^2}+x\bigr)$, which is equal to $-\ln\bigl(\sqrt{1+x^2}-x\bigr)$. So I should have used $-\sinh^{-1}x$ (with a minus sign) in my previous comments.
Just for the record, from wiki:
The abbreviations arcsinh, arccosh, etc., are commonly used, even though they are misnomers, since the prefix arc is the abbreviation for arcus, while the prefix ar stands for area.[1][2][3]
So it should be $\text{arsinh }x$, which is how I've learned it.
Thanks, but does this mean that the outputs of the inverse hyperbolic sine can be interpreted as areas of some sort or what?
Yes.
From wiki:
Yes. This link should help
https://en.wikipedia.org/wiki/Hyperbolic_angle
EDIT:
oops, I guess I like Serena had it covered.
Yeah. I've got the area. ;)
Oh, ok! Sorry for my lack of Googling-skills... I will read up on the hyperbolic sine soon. Thanks!
FAQ: Does ln(x - √(1 + x^2)) really have a real part?
What does "ln(x - √(1 + x^2))" mean?
The "ln" in this expression stands for the natural logarithm function, which is the inverse of the exponential function. The expression within the parentheses is the argument of the natural logarithm, and the entire expression means to take the natural logarithm of the value obtained when subtracting the square root of 1 plus x squared from x.
Why is the real part of ln(x - √(1 + x^2)) important?
The real part of this expression is important because it can help determine whether the overall expression has a complex or real value. In some cases, complex numbers can arise when taking the natural logarithm, so it is important to understand the real part of the expression to accurately interpret the results.
Can the real part of ln(x - √(1 + x^2)) ever be negative?
Yes, the real part of this expression can be negative. This means that the overall expression has a complex value, meaning that it has both a real and imaginary component. In these cases, it is important to consider both the real and imaginary parts to fully understand the value of the expression.
What values of x make ln(x - √(1 + x^2)) have a real part?
The values of x that make ln(x - √(1 + x^2)) have a real part are those that result in a positive argument for the natural logarithm. This means that the value of x must be greater than or equal to the square root of 1 plus x squared.
How can I calculate the real part of ln(x - √(1 + x^2))?
There is no simple formula for calculating the real part of ln(x - √(1 + x^2)). It will depend on the specific value of x and may require using a calculator or computer program to obtain an accurate result. Alternatively, you can use mathematical techniques such as Taylor series or calculus methods to approximate the real part of this expression.
