Does mass physically bend space or is time being bent?
In summary: This is a bad example because the surface of the Earth is curved regardless of whose theory of gravity you adopt.
  • #36
1977ub said:
Have I got all that right?
Yes, all this looks right.
  • #37
The "warped graph paper" diagrams of GR - they seem almost entirely intended to convey that that space-TIME is warped, i.e. to suggest gravitation as a result of curvature of space-time. But the space graph paper is warped as well it seems. Structures brought to the presence of high gravitation are subjected to forces other than what is expected from gravity itself, i.e. acceleration toward the body and tidal forces. I think it's odd that this isn't mentioned more often.
  • #38
Yes, this is true (provided "tidal forces" means forces due to objects *resisting* tidal deformation, not the tidal deformation itself--tidal deformations, not resisted by internal forces of the body, *are* due to gravity). We've assumed that any effects from these forces would be negligible in our discussion here, but of course they often won't be.
  • #39
PeterDonis said:
You're mistaken.
No problem, but could you demonstrate it? It would be helpful.
During integration how do we handle the pressure component?
Also for the interior Schwarzschild solution there is actually more mass for a given area compared to the Ricci flat Schwarzschild solution. Thus the Schwarzschild radius rs < 2M/c2 for the interior solution, how does that tie in if at all? After all in a region where the Ricci tensor does not vanish, and that is the case for the interior solution, do we not have a volume reducing effect?
  • #40
I don't understand why Peter says 'yes', then describes effects of gravity.
Gravity can be so strong as to cause electron and neutron degeneracy...and even
crush mass to the point of a black hole...all part of GR...
  • #41
I thought I had done so in my post #34.
Passionflower said:
For the internal Schwarzschild solution there is actually more mass for a given area.
I don't understand what you mean by this.
Passionflower said:
Thus the Schwarzschild radius rs < 2M/c2, how does that tie in if at all?
It doesn't. We're talking about a stable massive object with a radius greater than 2M (actually it has to be greater than 2.25M to be stable), so there is no horizon anywhere.
Passionflower said:
After all in a region where the Ricci tensor does not vanish do we not have a volume reducing effect?
The volume of a small sphere of freely falling test particles decreases with time, yes. But that's not the effect being described by the non-Euclideanness of space we've been talking about.
  • #42
PeterDonis said:
What you and A.T. are calling the "sign" of the curvature determines, roughly speaking, the *gradient* of [itex]g_{rr}[/itex],
Actually I was talking in terms of triangle angles and circumference/radius ratio, not distance between two shells. Du you agree with the cases I describe in post #32?
  • #43
I was trying to describe both. If I lower an object into a gravity well and then hold it static, the force it feels is not an effect of gravity; it's an effect of whatever is holding it static. It's true that it only takes a force to hold it static because it's in a gravity well, but that's not the same as saying the force itself is an "effect of gravity"; objects can be in a gravity well and not be static.
Similarly, if I lower an object into a gravity well and it deforms, the deformation may not be due to gravity; it may be due to the forces I am applying to it to place it where I want it.
Naty1 said:
Gravity can be so strong as to cause electron and neutron degeneracy...and even crush mass to the point of a black hole...all part of GR...
Yes, I wasn't intending to deny any of this.
  • #44
Actually most diagarms show the spatial curvature, which misleading because it has only minor effect, compared to the time dimension. Here a super simple overview:
http://www.physics.ucla.edu/demoweb..._and_general_relativity/curved_spacetime.html
The major effects come from the the space-time curvature. Space curvature doesn't even affect objects at rest.
1977ub said:
Structures brought to the presence of high gravitation are subjected to forces other than what is expected from gravity itself, i.e. acceleration toward the body and tidal forces..
Acceleration towards the mass and tidal forces are also mainly due to space-time curvature. Only objects moving fast relative to the gravity source are significantly affected by the spatial curvature. For photons, which move very fast, the effects are comparable. Huge rigid structures build in flat space would be crushed by curved space, but this is not what is typically meant by tidal forces.
  • #45
In the Schwarzschild solution mass is actually a length unit of measure, do you agree with that? This length is related to mass in the following formula: rs = 2M/c2 because the Ricci tensor vanishes in empty space.
However inside an object that is no longer the case because the Ricci tensor does not vanish. Unless there is exotic negative pressure the proper mass is always larger than the mass as described by the above relationship.
To get the proper mass for the interior Schwarzschild solution we need to integrate.
Of course a star does not have an event horizon but it does have a Schwarzschild radius.
See for instance: http://en.wikipedia.org/wiki/Tolman–Oppenheimer–Volkoff_equation#Total_Mass
Am I mistaken?
  • #46
A.T. said:
Do you agree with the cases I describe in post #32?
I don't think so. I think you are confusing space curvature with spacetime curvature. To briefly recap the general facts about space curvature vs. spacetime curvature:
Outside the gravitating body, spacetime curvature is negative in the radial direction (freely falling objects increase their radial separation with time) and positive in the tangential direction (freely falling objects decrease their tangential separation with time). (Note that this is Weyl curvature we're talking about; there is zero Ricci curvature, since we're in vacuum. That means a small sphere of freely falling particles will distort radially and tangentially, as above, but will not change its volume.)
Inside the gravitating body, spacetime curvature is positive everywhere. Ricci curvature is positive since there is positive stress-energy present; that means a small sphere of freely falling particles will decrease in volume. Weyl curvature is positive tangentially for the same reason it is outside the body: freely falling radial geodesics converge. But it is also positive radially because the gradient of [itex]g_{rr}[/itex] is reversed; freely falling particles that are radially separated will converge, not diverge, because the "acceleration due to gravity" gets smaller as they fall, not larger.
However, neither of the above tells us about *space* curvature, which is what your triangle scenarios refer to. To talk about space curvature, we have to first decide how we will slice up the spacetime into space and time. The most obvious way to do that is to use the slicing that matches up with the static nature of the spacetime; i.e., we use slices of constant time according to static observers, who stay at the same radius forever. This is the slicing that produces the Flamm paraboloid that you gave a picture of.
If we use that slicing, then space curvature is *positive* everywhere; a triangle's angles sum to greater than [itex]\pi[/itex], and the circumference of a circle is less than [itex]2 \pi[/itex] times its proper radius. This may seem confusing since the paraboloid does appear to "change the direction it curves" at the body's surface. But that only changes the *gradient* of [itex]g_{rr}[/itex]; it doesn't change the curvature, which is, as I noted before, the *second* derivative of the metric, not the first.
Draw some triangles on the paraboloid; you will see that regardless of whether you are inside or outside the body's surface, the triangles will work like triangles drawn on a spherical surface. A negatively curved surface would be shaped like a saddle, bending one way in one direction and the other way in a perpendicular direction at a single point. The paraboloid doesn't do that.
(Actually, a triangle that straddles the body's surface *may* behave differently, since it would straddle the change in gradient of [itex]g_{rr}[/itex]. I have been unable to find an explicit computation of the spatial curvature of a constant-time slice in Schwarzschild coordinates, and I haven't done the full computation myself.)
  • #47
PeterDonis said:
This is the slicing that produces the Flamm paraboloid that you gave a picture of. If we use that slicing, then space curvature is *positive* everywhere;
Are you sure about this? Here they say Gaussian curvature of Flamm's paraboloid is negative:
http://books.google.de/books?id=75r...flamm's paraboloid gaussian curvature&f=false
To me it looks like it does exactly that.
  • #48
Geometrically, the Gaussian curvature at a point of an embedded 2 - surface is the product of the principal curvatures at that point, which are the eingenvalues of the shape operator (classically called the Weingarten map). You can picture the principal curvatures at a point ##p## on the surface ##S## as follows: choose a normal ##N## to ##S## at ##p## and consider a plane going through ##p## that contains ##N##. This plane (called a normal plane) will "slice" out a curve ##\gamma ## on ##S##. At ##p##, ##\gamma## has some curvature and we assign it a sign based on if it is turning away or towards ##N##; this is called a signed curvature. Do this for all such normal planes through ##p## containing ##N##; the principal curvatures are the maximum and minimum signed curvatures so obtained.
You can picture this for Flamm's paraboloid and see that there is one direction where the curve would locally turn away from the normal and another direction where it would locally turn towards it (the principal directions); it isn't too different locally from a hyperbolic paraboloid. I'm being hand wavy here but take a look at chapter 3 in "Differential Geometry of Curves and Surfaces" - Do Carmo if you are interested.
  • #49
I'm understanding that a structure can be brought into the presence of larger gravitation, held in place, and experience 2 types of deformation: one from tidal forces, and a 2nd due to these "space bending" effects.
Oh, do the tidal forces only come into play as the structure is moving toward the gravitational body?
  • #50
Yes. In curved 4D-space-time this gets mangled together a bit. But if you have a long free falling stick aligned with the radial direction it will be stretched by tidal forces, while spatial curvature imposes no strains on it. You need a 2d of 3d structure to experience deformation from spatial curvature.
  • #51
Yes, I see what you mean. I'm working on computing the principal curvatures from the metric to verify this.
  • #52
I don't suppose this bending of space has experimental verification? I'm still stunned that it is not more widely popularized.
  • #53
The effect, as I said, is about 7 parts in 10 billion at the Earth's surface, and you would have to make measurements covering a substantial fraction of that surface to see it at that magnitude. So I don't think we'll get a direct measurement any time soon.
  • #54
Considering that the most common popularization is the infamous rubber-sheet picture... I wish it weren't as widely popularized :smile:
  • #55
In every case I have seen, this is a popularization of the curvature of space-TIME, not of space. Can you find an example where it is curvature of space which is being described?
  • #56
Nugatory probably refers to pictures like this:
http://2.bp.blogspot.com/_vqRjMx6Pk...C3M/iVVaGjIJ17U/s1600/Spacetime_curvature.png
And which dimension of the above surface is supposed to be time? They might talk about "space-time curvature" as they show you that picture, but both dimensions of the sheet are spatial. So the picture obviously just shows the spatial curvature with dents like the one in the picture I posted in post #27. That's why it is so misleading.
Space-time embedding diagrams look like this:
http://www.relativitet.se/spacetime1.html
  • #57
I don't know about an isolated test, just for space curvature. But the spatial distortion around the Sun affects the bending of light and the orbit precession of Mercury. To get the best predictions compared to observed values you have to take space curvature into account.
  • #58
A.T. said:
Nugatory probably refers to...
Yep - said it better than I would have - thanks.
  • #59
  • #60
Have you ever seen it done this way - i.e. spatial curvature added with the space-TIME curvature in discussing perihelion movement or light deflection?
  • #61
Passionflower said:
Question for me remains that since the proper mass is larger due to pressure should we not adjust the Schwarzschild radius accordingly in the formulas?
I know it seems like it ought to, but as equation (6) in the paper shows, the mass as a function of radial coordinate r, [itex]m(r)[/itex], which is the parameter that appears in the metric and therefore determines the Schwarzschild radius, only includes a contribution from [itex]\rho[/itex], not [itex]p[/itex]. I've seen this same derivation in MTW.
However, I agree that there is still a question of how to reconcile this result with the Komar mass integral, which does include a contribution from [itex]p[/itex]. I think MTW at least touches on this issue; when I get a chance to pull my copy I'll take a look.
  • #62
When GR is used those two are not considered separately. You could try to compare Einsteins 1911 paper with his 1915 complete version of GR. If I remember correctly the 1911 prediction didn't consider spatial curvature:
http://mathpages.com/rr/s6-03/6-03.htm
The idea of bending light was revived in Einstein's 1911 paper "On the Influence of Gravitation on the Propagation of Light". Oddly enough, the quantitative prediction given in this paper for the amount of deflection of light passing near a large mass was identical to the old Newtonian prediction, d = 2m/r0. There were several attempts to measure the deflection of starlight passing close by the Sun during solar eclipses to test Einstein's prediction in the years between 1911 and 1915, but all these attempts were thwarted by cloudy skies, logistical problems, the First World War, etc. Einstein became very exasperated over the repeated failures of the experimentalists to gather any useful data, because he was eager to see his prediction corroborated, which he was certain it would be. Ironically, if any of those early experimental efforts had succeeded in collecting useful data, they would have proven Einstein wrong! It wasn't until late in 1915, as he completed the general theory, that Einstein realized his earlier prediction was incorrect, and the angular deflection should actually be twice the size he predicted in 1911.
  • #63
Well there you go. Ok.
“half of this deflection is produced by the Newtonian field of attraction, and the other half by the geometrical modification (‘curvature’) of space caused by the sun” - Einstein, 1916
http://mathpages.com/rr/s8-09/8-09.htm
  • #64
Just google "curvature of space" and see all the pages which seem unrelated to the curvature of space.
"Einstein's theory of general relativity describes space as curved, with the "curved space" being the four-dimensional space-time conceived of by Minowski. The curvature of space results in the effects of gravity. "
http://www.fi.edu/learn/case-files/einstein/curved.html
Ugh. Here's another one.
"Curvature of Space
A hallmark of gravity is that is causes the same acceleration no matter what the mass of the object. For example, a baseball and a cannon ball have very different masses, but if you drop them side-by-side, they accelerate downward at exactly the same rate. To explain this, Einstein envisioned gravity as being caused by a curvature of space. " - http://library.thinkquest.org/C0116043/generaltheory.htm?tql-iframe#formation
This seems to be conflating the two types of curvature of light caused by the Sun:
http://www.universetoday.com/38858/new-way-to-measure-curvature-of-space-could-unite-gravity-theory/
  • #66
Generally these sources go on to describe how the curvature of "space" is responsible for gravity, so they're not discussing this topic. The only discussions of the curvature of space that I'm coming across are referring to Einstein's change in 1915.
  • #68
Both integrals give the same end result at infinity, but the distribution of "mass" is different.
I'm not aware of any papers on the topic - mostly one has to work this out for oneself. This leads to a lot of wrangling and tends not to convince people who can't follow the arguments.
An interesting case to consider is a relativistic gas or a photon gas enclosed in a rigid exotic matter shell which has rho=0. (It's exotic because it's tension is greater than it's density).
In the Komar formalism, the shell contributes a negative mass to the total. (The shell's base contribution is proportional to (rho+3P), and P is negative).
In the Schwarzschild m(r) formalism the shell doesn't contribute anything (because rho=0). However, if you compute the "mass" of the entire system "at infinity" both approaches give the same answer.
(Obviously they don't give the same answer inside the shell - the distribution of mass is different.)
There is a direct tie in between the Komarr mass enclosed by a surface and the surface integral of the force-at-infinity (see the thread https://www.physicsforums.com/showthread.php?t=679255 or the section in Wald on "Energy")
NOte defining the "force-at-infinity" requires a static metric, though.
There is no such direct tie with the m(r) and any sort of "force", though you can solve Einstein's equations to find the 4-accelearation (and hence the local force), or the 4-accleration and the killing vectors (and hence the force-at-infinity - assuming the problem has killing vectors.)
14K
